Which Dedicated Circuit to Install
might wanna change the runs from the poles first. they are only aluminum. dont see why one short run from panel will make something better when main is not even copper.
He is right.
99% of the mains I've seen are aluminum. I'm sure you can run copper instead, I think you'd need something like 4/0-3C twist with an aluminum runner to carry it. I'm pretty sure you'd also HAVE to get the power company to do it, too, for insurance. That's gonna be pricey... -
That's what friends are for.
Michael
NORTH of 60° -
never seen 4/0 copper, I pulled aluminum to the sub-panel for the HT room you heard Mike, the amp line in the shed comes from the same sub-panel.
Works great, sounds great.
DJ7--your receptacle is loose and it does not produce any current.
RT1 -
I seen 4/0 copper before, but my receptacle isn't the only thing loose
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I see it all the time. They don't use much aluminum industrially anymore...
It ain't cheap, that much I can tell ya. -
r u saying u have become industrius now Ant.............
RT1
