Head unit so many choices
1234568»
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited June 2008
    Is it worth spending the extra money for a alpine hu when I'm going to be using the dual pre-outs to pass the signal to a factory amp (harman/kardon) in the back of my 95 range rover?
    I would replace the amp or bypass it but I've checked the range rover sites and no one knows how to do it without running new wires to all the speakers since it's currently a common ground speaker system.
  • exalted512
    exalted512 Posts: 10,734
    edited June 2008
    You should get a little better sound as you're using better quality preouts. the real advantage, though, is the tuning capabilities and being able to add aux sources such as ipod,usb,cdchanger, or satellite radio.
    -Cody
  • candyliquor35m
    edited June 2008
  • thumpin07
    thumpin07 Posts: 217
    edited June 2008
    well fellows i might put the system on hold this year. I convinced the old lady into letting me buy a motorcycle. I'm thinking about getting a Suzuki gsxr-750 my buddy has one he is selling for 3,300 bucks.
    tyler birch
    ht system
    denon avr-1907
    monitor 70 towers-polkaudio
    nakamichi bx -100 tape deck
    sony 5 disc cd/dvd player hdmi ready
    velodyne dps-12 subwoofer
    Car audio
    AMP: FUSION EN-AM8001 800 watts max 368 watts rms x 1 channel @ 2 ohms stable
    SUB: 12 INCH 1000W DVC VOLFENHAG 2 Ohm stable useable ohms 2-8ohms
  • exalted512
    edited June 2008
    Watch out for stupid cagers, they're everywhere.
    -Cody
  • black magic
    black magic Posts: 669
    edited June 2008
    thumpin07 wrote: »
    I plan on getting a bike in a year or two. Since I'm a novice, I think I'll be starting off with a sbr250, ninja 250 or something else in that class. I don't think I'd be willing to start off with anything larger than a 500 or 650cc engine.
  • exalted512
    edited June 2008
    Get a ninja 500. Fantastic starter bikes. I don't recommend the 250s.
    -Cody
  • black magic
    edited June 2008
    exalted512 wrote: »
    -Cody
    Thanks for the input. One of my friends has a ninja but I'm not sure if its the 500. I was also considering a sv650. if I can find an old cbr600 or ninja 500/650, I'd probably consider them. The reason I want a 250 is because they're light and I don't want to drop 6-7k on a bike that I might end up wrecking. Need a beater to learn on first :p
  • thumpin07
    edited June 2008
    exalted512 wrote: »
    -Cody
    what do you mean by cagers
    tyler birch
    ht system
    denon avr-1907
    Car audio
  • thumpin07
    edited June 2008
    I like the gixxers but thats me i guess a gsxr-750 is about as good of an all around sport bike you could get imo.
    tyler birch
    ht system
    denon avr-1907
    Car audio
  • thumpin07
    edited August 2008
    yeah got my motorcycle license the other day
    tyler birch
    ht system
    denon avr-1907
    Car audio
  • B2Bomber
    B2Bomber Posts: 24
    edited August 2008
    thumpin07 wrote: »
    car (or anything not bike-related) drivers. ;)
  • exalted512
    edited August 2008
    Little late now, but my 500 was purchased around august of 07, its an 2005 model with 2300 miles on it, got it for $3500. The ninja 250s are great bikes, but IMO, the 500s are safer and a better representation of a bigger bike, if thats what you want to get later on.
    Reason why I think the 500 is safer is because sometimes you need some power to get out of the way, 500 is more apt to give you that power.
    Its also a little larger, which gives you more experience with a bike that can actually go highway speed comfortably. I would consider getting a liter bike after a 500, a liter bike after a 250 is a GIANT step with a huge learning curve.
    -Cody
  • black magic
    edited August 2008
