Pure disapointment.........Polk LSi15
123457
  • Jstas
    Jstas Posts: 14,985
    edited April 2008
    sucks2beme wrote: »
    How did a lsi thread turn into a Carver thread???
    How about we stop asking questions like this and let it go back to an LSi thread. Although, the distinction has also been tenuous and dubious from the start.
    Expert Moron Extraordinaire
    treitz3 Posts: 19,999
    edited April 2008
    Jstas wrote: »
    I mean treitz3 says that is how it is so it MUST be true!
    You said it, not I. :D
  • markmarc
    markmarc Posts: 2,309
    edited April 2008
    First, EarlyB's term of "audio impotence" isn't a bad idea.
    High current receivers are a bit of a misnomer, yes, they can apply a large reserve of power, but only for a split second. But to dismiss all receivers would be silly. A Bryston would have no problem with the LSi15's.
    I will debate that it doesn't take 200wpc to make the LSi sing, as it's all about quality power, not massive power. If your amp section has a truly serious power supply it won't have any problem digging deep. Paul DiComo heard the LSi9's sound killer on a 70wpc Arcam.
    Former Staff Member TONEAudio
    2 Ch. System
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2008
    If I remember my psycho-acoustics correctly, isn't the 'just noticable difference' in sound pressure levels (decibels) = 3db?
    And that with every 3db increase it requires x2 the power (watts)?
    If the LSis have an efficiency of 89db -measured at 1 meter with one 1 watt input can't the output be mapped against what the amp should be rated at?
    89db = 1 watt
    92db = 2 watts (just noticable difference of +3db)
    95db = 4 watts
    98db = 8 watts
    101db = 16 watts
    104db = 32 watts
    107db = 64 watts
    I guess it depends on whether the speaker in question has an output that follows this progression or if it is a less efficient climb in output -if so then the power demands on the amp are even greater.
    And you need to account for what your "average" listening preference is to then estimate how much reserve (power or current) your amp needs to keep you from clipping and damaging the drivers.
    So, if you had a +6db transient (like a boom or crash) and your average listening level was at 104db - then the amp would need to provide x4 power or 128watts for however long the transient is - without clipping of course.
    And isn't efficiency measured at 1 meter from the driver so that if you were listening 10 ft back, the spl at that distance is lower than 104db?
    I guess it depends on what 'sing' means in relation to user preference in loudness and size of the room?
    Just stirring the pot...
    Erik
    tonyb Posts: 33,072
    edited April 2008
    Yaaaawn !!!!!!!!!!!!!!
  • Erik Tracy
    edited April 2008
    tonyb wrote: »
    Sorry - I'm an engineer by trade.
    Numbers are needed when designing stuff :D
    Just thought that some sort of rationale could be confirmed for a general rule that "LSIs typically need **** watts to sing".
    Erik
    tonyb Posts: 33,072
    edited April 2008
    Quality over quantity my man.Current delivery over wattage.Loudness has absolutely nothing to do with making them "sing".
  • Systems
    Systems Posts: 14,873
    edited April 2008
    Erik Tracy wrote: »
    1 db or so is close to the threshold of being perceptable,a 3 db
    difference would be very noticeable.
    Testing
    Testing
    Testing
  • Erik Tracy
    edited April 2008
    GV#27 wrote: »
    I see that a google search does indicate that the jnd is at 1db and that 3db is now considered 'clearly noticable'. Although I did find one college website that listed the 3db measure as the 'jnd'.
    But, anyway the scale still applies as far as absolute db vs power.
    And as a reference point, a nightclub is measured at about 110db - that's pretty darn 'loud'.
    The point I was attempting to illustrate is that power demands go up quickly the louder you push a speaker to play - so that it's initial efficiency rating is a factor to consider in possible pairings between speaker and amp and one's listening habits.
    But you guys all know that....which is why I expect I got the "yawn" reply (no harm no foul).
    And, c'mon, don't we all get that devilish grin on our faces when you 'crank it up' and you see that your amp is hardly breathing :p
    Erik
  • Systems
    edited April 2008
    Erik Tracy wrote: »
    Agreed, good point Erik.
    Testing
    Testing
    Testing
  • olilugo
    olilugo Posts: 405
    edited April 2008
    Here are my findings on limited research:
    1. most avr's will not be able to drive 4ohm speakers, I will go further to say if the avr is not design to handle 4 ohm then an extra amplifier will make little to no difference that I would say wow now I appreciate this.
    2. If you buy a avr that can handle 4 ohm speakers like NAD or even Yamaha, then adding an external amp will have a very appreciative increase in all the different words that most of us use: greater soundstage, clear, etc.
    3. Probably the best approach is to have a pre amplifier and an external amplifier (most people call this separates).
    On a side note having a pre or an avr that have higher sensitivity, adding an external amplifier will give you a more appreciative increase in power/performance, while if the avr has a lower sensitivity, adding an external amp will seam as you have not done anything since the volume will still be at -10 as before adding the external amp.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
    F1nut Posts: 51,782
    edited April 2008
    Huh?
  • Sami
    Sami Posts: 4,634
    edited April 2008
    olilugo wrote: »
    An AVR is an integrated package, think of it as a preamplifier and an amplifier in one package. If an AVR isn't capable of driving 4ohm loads, it's the amplifier section that is lacking. If you add an external amplifier (that handles 4ohm), you're bypassing the AVR's internal amplifier (that wasn't able to drive 4ohm loads). Now you have a preamplifier and an amplifier that is capable of driving the 4ohm speakers.
    Hope that helps.
    tonyb Posts: 33,072
    edited April 2008
    Sorry Erik,didn't mean to come off as a ****.[ shut up the rest of you].The point you were trying to make was well taken.Just that sometimes the same stuff gets beaten to death around here on a daily basis,hence the "yawn".
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2008
    markmarc wrote: »
    Excellent. Seems as though the idea of an amplifier clipping has been lost somewhere in the spin of watts stats. I can assure anyone looking at NAD as their power choice that the company is an excellent choice. Arcam should be on anyone's list, actually the short list.
    RT1
  • Erik Tracy
    edited April 2008
    tonyb wrote: »
    No prob...I'm a noob here.
    I figure that the 'veterans' here will from time to time either smile and quaintly think "isn't the noobie cute" or "here we go again".....
    It's all good....enjoy the sound...
    But, suffer me this one question in regards to 'quality' power.
    The ability to move a driver is measured in power or watts.
    And if a user is asking his/her setup to deliver more that what is 'rated' - in watts - how does the power supply behind the amplication circuitry mitigate overdriving beyond an amps rated power rating?
    Thanks,
    Erik
  • garnier
    garnier Posts: 116
    edited April 2008
    I am listening to my system consisting of all LSi speakers in 7.1 mode, except the subwoofer, with my Outlaw 7700 300 wpc @4-ohm, and I am not sure if it sounds better than with my previous Polk Audio Monitor series speakers with my Denon receiver! It sure is a little bit better, but not very noticeably. Am I doing anything wrong? I am using 12 guage speaker wires I got from Wal-Mart for $20/50ft and Monster power surge protector/conditioner. I am not sure if it was worth the money spent! I can't play it loud anyway either, because I live in an aprtment complex. I will keep what I have; but to be honest, I was expecting more from these! :(
  • nebborjk
    nebborjk Posts: 425
    edited April 2008
    garnier,
    How long have you had these speakers? They will need some time to break in. This is usuallly around 100 hours.
    Proud SOPA Member since 2005!
  • reeltrouble1
    edited April 2008
    Erik, its about power as measured in amperes. Without enough electrons flowing down the pipe (lack of power) the amp will clip the wave frequency distorting what you hear. You also need reserve power to handle something called transient sounds which are very short in duration but draw lots of power. You need am amp with around 25 amperes peak to peak rating minimum, however the more the better. There is no magical number of watts a device should put out to make you speakers sound this way or that.
    RT1
  • dkg999
    dkg999 Posts: 5,647
    edited April 2008
    garnier wrote: »
    Having moved up the Polk Audio food chain in my HT, from SDA's to Monitors (vintage) to RTi, then to LSi ...... if you can't hear a difference between the new Monitor series and the LSi's, then either something in your system isn't right, or you just aren't able to appreciate the differences (not a critical comment, not everybodys ears hear the same things!). If you are comparing to vintage Polk Monitors, then the difference vs the LSi will be smaller, but still should be noticeable.
    DKG999
  • Ron Temple
    Ron Temple Posts: 3,212
    edited April 2008
    dkg999 wrote: »
    Hopefully that isn't the case...
    What are you primarily listening to music or HT? What's your room like/size?.
    Your gear looks fine, so it's either expectation or setup. You should be hearing a noticeable change in the soundstage, larger and more open, deeper, with pinpoint imaging. Macro and micro detail should manifest better within the stage. When you close your eyes, you should be able to place the individual instruments (imaging). The Monitors are decent speakers, but should sound slightly smeared in comparison.
    In my experience, when I hear a superior speaker, I can tell immediately what it does better. The really great ones, hit you with the "I've got to have that" feeling. I'd think the LSis would do that for garnier.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • MGPK
    MGPK Posts: 88
    edited April 2008
    System:
    H/K AVR430 Receiver
    Samsung DVDHD841 Dvd player
    Yamaha CDC506 5 Disc changer
    Jamo E855 Tower speakers
    Wharfdale Pacific P-10 Bookshelf speakers
    Acoustic Research Master Series Interconnects
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2008
    He doesn't say what Denon he has, I wonder if he has calibrated everything.
  • Systems
    edited April 2008
    Erik Tracy wrote: »
    The power supply is the limiting factor ,if it can no longer provide the current and voltage required by the output transistors to reproduce the signal then clipping (severe distortion)will occur.The actual power output obtained depends on the load the speaker presents to the amp.
    Testing
    Testing
    Testing
    tonyb Posts: 33,072
    edited April 2008
    Erik- I believe RT1 nailed it.Along with a good answer by GV#27.What exactly do you design and/or build as an engineer?Curious is all,anything audio related? Numbers have their place in the design stage to meet a certain criteria,but thats not all there is to a good amp.
  • AudioFilet
    AudioFilet Posts: 235
    edited April 2008
    I'm wondering now if my HK AVR745 would be able to handle 4 ohm loads? It seems to have the specs for it, but who knows?
    Any thoughts on that?
    2 Channel rig:
    LSi9"s (modified xover's) & HSU Sub
    Harman Kardon HK 990 Amp
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
    HK AVR-745 & Polk Monitor Series
  • SKsolutions
    SKsolutions Posts: 1,820
    edited April 2008
    ^It should^ I wouldn't drive (7) 4 Ohm speakers for very long, but in two channel @4 Ohm, it will perform quite well. It'll be the bees knees -until you get a solid separate amp. Then you will wonder why you waited. Nice warm sound with that combo. It'll open up a bit if you upgrade.
    -Ignorance is strength -
  • garnier
    garnier Posts: 116
    edited April 2008
    I use my setup mostly for watching movies, and I calibrated the system using an automatic calibrator of a receiver.
    I do notice a difference now that I am using an external amplifier compared to just using a receiver. So I souldn't regret spending money if there are even a little bit of improvement.
    So, I guess I shouldn't complain, because there are some improvements. Maybe I expected too much.
    But I am content with what I have now! Thank you! :)
  • Sami
    Sami Posts: 4,634
    edited April 2008
    AudioFilet wrote: »
    It should.
  • Erik Tracy
    edited April 2008
    tonyb wrote: »
    Computer Systems (aka System Architect).
    Nothing audio related.
    But even in audio, I would guess every audio engineer agonizes over numbers in their design and that listening tests involve gathering 'data' and subjected to 'analysis'. ;)
    Ultimately, in the end, it comes down to us, as listeners, and whether we get that sublime smile of satisfaction of sweet enveloping sound.
    But - the numbers get you there! :D
    Erik
