Upgradeitis. Need some advice on Cinenova Grande
124»
  • Gaara
    Gaara Posts: 2,415
    edited July 2007
    Do a google search for chip amp and you will see what I am talking about. A while back class D amps may have been called chip amps, but after 47 Labs released their Gaincard and all the gainclones started coming out the term changed.
    I will agree with you on the Sunfire, it is not the best amp out there even though I did enjoy my time with it. I have tried a good amount of amps over the last 6 months and it is one of my least favorites. Another FYI, the Sunfire isn't class D, it is A/AB design with a very different kind of power supply...which is where the efficiency is.
    I have never been a fan of Class D amps until I tried a icepower amp. Definitely changed my mind...so much so that I am replacing my Cinenova with a amp that is 2x the power at less then 10% the size.
  • olilugo
    olilugo Posts: 405
    edited July 2007
    Gaara, which amp do you have today?
    what kind of receiver or pre-pro do you have?
    Regards,
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • ben62670
    ben62670 Posts: 15,969
    edited July 2007
    Gaara wrote: »
    Thanks for the info. I just did a little reading on Sunfire, and Outlaw amps. It appears both use high speed switching power supplies compared to traditional transformer-cap style.
    Ben
  • Gaara
    Gaara Posts: 2,415
    edited July 2007
    olilugo,
    I am currently using a pair of Nuforce 8.02 monoblocks.
    I have a pair of EVS 500Ms coming in the mail which I hope to be my final amps. They are ~550-600wpc icepower amps using the 1000asp module.
    My pre-pro for surround sound is a B&K Reference 50. For 2 ch it is a Promitheus Audio Reference 3 TVC.
