Building a Dedicated Audio Room
  • Ricardo
    Ricardo Posts: 10,634
    edited May 2007
    How much for you to come to Miami and build mine out?:D
    Lodging will be fine; will work from 8 AM to 10 AM and rest from the hard work lying at the beach the rest of the day. Sounds fair????
    SOPA
  • adam2434
    adam2434 Posts: 995
    edited May 2007
    Just lookin' out for you, but sounds like you've considered the pros and cons for your particular situation.
    By the way, you probably know that a sanding sponge can be used to eliminate/minimize the dust generated by normal sanding. I hate sanding too!
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2007
    HTrookie wrote: »
    You buy the materials and it's a deal!:D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • engtaz
    engtaz Posts: 7,672
    edited May 2007
    Lol !!!
    engtaz
  • Ricardo
    edited May 2007
    Hmmmm.....If I tell you I'm the "anonymous donor" will you throw in a little extra??? :)
    SOPA
  • engtaz
    engtaz Posts: 7,672
    edited May 2007
    man, Darla sure can take a guy attention away from a project. No updates for almost two weeks. Darn Darla I did not know you were this good.:D ;) :eek:
    the man can't finish his signature either. Dang LOL
    engtaz
  • Ricardo
    edited May 2007
    What did you expect...it's 18 hours each way to Miami :eek: :eek: :p
    SOPA
  • schwarcw
    schwarcw Posts: 7,360
    edited May 2007
    Looks good Ricardo! You did a pretty good job for an engineer!;) I hear you about the drywall work. It helps if you have a friend or someone with those plaster skills. Are you going to get some Day-Glo paint and some black lights?:D Put up some posters of Janis Joplin and Iron Butterfly. Turn on the Electric Prunes music and light up a . . . . :eek: nevermind. I'm still stuck in the early '70's.
    Carl
  • Ricardo
    edited May 2007
    Ok; here goes an update.
    I painted the ceilings and put some crown moldings; I had a very hard time with the tapered edges...didn't think I would (Yes...I'm stubborn....). It looks really good though, and what you see is effect of the flash; in normal light it looks pretty uniform.
    So....I decided to mud the walls; just enough to cover screws/edges, but without the need of sanding. I also built the sump pump enclosure and the "dummy" on the other side. I will make the covers with plywood and stain to match the speakers.
    Next step: flooring and base board, then paint the walls. I'm using the same laminate I used for the rest of the basement....but I don't have enough, and the finish was discontinued, so I bough a lighter one and will have to combine them. Should look good.....
    Not sure I'll finish on target; this weekend is Chicagofest :cool: :cool: :cool:
    SOPA
    SCompRacer Posts: 9,159
    edited May 2007
    schwarcw wrote: »
    You still got your roach clip? Gonna let your daughter take it to school for show and tell?:eek: :D
    Looking good Ricardo. Maybe you should throw a room finishing fest.
  • Ricardo
    edited May 2007
    Carl, Rich, I have no idea what you two are talking about....:confused::confused::p:p
    SOPA
  • schwarcw
    edited May 2007
    Ricardo, you might have had a hard time with the tapered edges if your walls aren't straight;)
    Seriously, looks good! I liked those corner blocks because you don't have to do the compound cut on the molding. A little caulking cleans up everything nice:)
    Carl
    Carl
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2007
    Well, you are well ahead of mine Ricardo, good job.
    RT1
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2007
    Coming along great :)
    Ted, Move your A$$ ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • engtaz
    engtaz Posts: 7,672
    edited May 2007
    Looking good. I like the trim.
    engtaz
  • george daniel
    george daniel Posts: 12,096
    edited May 2007
    for the wall
  • Ricardo
    edited May 2007
    Please help me select the flooring pattern!!!!
    http://www.polkaudio.com/forums/showthread.php?t=52916
    SOPA
  • Ricardo
    edited May 2007
    Flooring set. Next steps...base boards (I hate cutting those corner angles :mad: ), paint the walls, get the gear in here and start playing with room treatments.
    SOPA
  • reeltrouble1
    edited May 2007
    Ricardo,
    looking good my man. you are making me want that wood, you know wood!!!
    I seem to be having a union labor issue on my new woodshed, so feel free to drive on down if you work for beer!!!!
    Did you buy your green glue local or internet supply???
    RT1
  • unc2701
    unc2701 Posts: 3,587
    edited May 2007
    You're going to totally hate yourself for putting down the floor before you painted :)
    But at least you won't have to do quarter round in addition to the baseboards.
    Backburner:Krell KAV-300i
  • engtaz
    engtaz Posts: 7,672
    edited May 2007
    But that was not in the final poll picks. How did you have time after Chicagofest '07 and recover from it. LOL
    Looks great
    engtaz
  • Ricardo
    edited May 2007
    PM sent
    SOPA
  • Ricardo
    edited May 2007
    unc2701 wrote: »
    The only reason I am doing it this way is that I'm using textured paint; putting the base board over textured paint would be a pain...I'd rather tape the BB and put up lots of plastic film to cover the floor :)
    SOPA
  • Ricardo
    edited May 2007
    engtaz wrote: »
    Looks great
    Putting up laminate flooring is VERY easy; this room had only a couple of tricky cuts, so I spent maybe 3 hours total.
    SOPA
  • engtaz
    engtaz Posts: 7,672
    edited May 2007
    Great work.
    engtaz
  • wingnut4772
    edited May 2007
    Ricardo,
    :D:D:D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited May 2007
    Rock on. Good looking stuff right there.
  • halo
    halo Posts: 5,619
    edited May 2007
    Ricardo, you don't think all this is work you are doing could be considered unnecessary, do you? ;):p:D
  • Ricardo
    edited May 2007
    I don't, but the "boss" for sure does ;)
    SOPA
  • engtaz
    engtaz Posts: 7,672
    edited May 2007
    More pics more pics oh and progress report.
    engtaz
