Building a Dedicated Audio Room
wingnut4772 wrote: »How much for you to come to Miami and build mine out?:D
Lodging will be fine; will work from 8 AM to 10 AM and rest from the hard work lying at the beach the rest of the day. Sounds fair????_________________________________________________
Just lookin' out for you, but sounds like you've considered the pros and cons for your particular situation.
By the way, you probably know that a sanding sponge can be used to eliminate/minimize the dust generated by normal sanding. I hate sanding too!5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
You buy the materials and it's a deal!:DSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
wingnut4772 wrote: »You buy the materials and it's a deal!:D
Hmmmm.....If I tell you I'm the "anonymous donor" will you throw in a little extra???
man, Darla sure can take a guy attention away from a project. No updates for almost two weeks. Darn Darla I did not know you were this good.:D
:eek:
the man can't finish his signature either. Dang LOLengtaz
What did you expect...it's 18 hours each way to Miami :eek: :eek:
Looks good Ricardo! You did a pretty good job for an engineer!;) I hear you about the drywall work. It helps if you have a friend or someone with those plaster skills. Are you going to get some Day-Glo paint and some black lights?:D Put up some posters of Janis Joplin and Iron Butterfly. Turn on the Electric Prunes music and light up a . . . . :eek: nevermind. I'm still stuck in the early '70's.Carl
Ok; here goes an update.
I painted the ceilings and put some crown moldings; I had a very hard time with the tapered edges...didn't think I would (Yes...I'm stubborn....). It looks really good though, and what you see is effect of the flash; in normal light it looks pretty uniform.
So....I decided to mud the walls; just enough to cover screws/edges, but without the need of sanding. I also built the sump pump enclosure and the "dummy" on the other side. I will make the covers with plywood and stain to match the speakers.
Next step: flooring and base board, then paint the walls. I'm using the same laminate I used for the rest of the basement....but I don't have enough, and the finish was discontinued, so I bough a lighter one and will have to combine them. Should look good.....
Not sure I'll finish on target; this weekend is Chicagofest :cool: :cool: :cool:_________________________________________________
You still got your roach clip? Gonna let your daughter take it to school for show and tell?:eek:
Looking good Ricardo. Maybe you should throw a room finishing fest.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Carl, Rich, I have no idea what you two are talking about....
Ricardo, you might have had a hard time with the tapered edges if your walls aren't straight;)
Seriously, looks good! I liked those corner blocks because you don't have to do the compound cut on the molding. A little caulking cleans up everything nice:)
CarlCarl -
Well, you are well ahead of mine Ricardo, good job.
RT1 -
Coming along great
Ted, Move your A$$
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Looking good. I like the trim.engtaz
Please help me select the flooring pattern!!!!
http://www.polkaudio.com/forums/showthread.php?t=52916_________________________________________________
Flooring set. Next steps...base boards (I hate cutting those corner angles :mad: ), paint the walls, get the gear in here and start playing with room treatments.
Ricardo,
looking good my man. you are making me want that wood, you know wood!!!
I seem to be having a union labor issue on my new woodshed, so feel free to drive on down if you work for beer!!!!
Did you buy your green glue local or internet supply???
RT1 -
You're going to totally hate yourself for putting down the floor before you painted
But at least you won't have to do quarter round in addition to the baseboards.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
But that was not in the final poll picks. How did you have time after Chicagofest '07 and recover from it. LOL
Looks greatengtaz
reeltrouble1 wrote: »Did you buy your green glue local or internet supply???
PM sent_________________________________________________
The only reason I am doing it this way is that I'm using textured paint; putting the base board over textured paint would be a pain...I'd rather tape the BB and put up lots of plastic film to cover the floor
Looks great
Putting up laminate flooring is VERY easy; this room had only a couple of tricky cuts, so I spent maybe 3 hours total._________________________________________________
reeltrouble1 wrote: »Ricardo,
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Rock on. Good looking stuff right there.
Ricardo, you don't think all this is work you are doing could be considered unnecessary, do you?
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
I don't, but the "boss" for sure does
More pics more pics oh and progress report.engtaz
