Worth $1300, sure IMO, but they don't go for that on ebay...
Only three 2.3 tl's in my files. They went for $800, 900, and 1000. The $800 ones were a bit nasty, but the others were nice looking.
Plain 2.3's ran from low $600's to 800, with a couple outliers in the 900's. I've eight data points there.
More later, Tour... Vox Copuli Better to remain silent and be thought a fool, than to open your mouth and remove all doubt. - Old English Proverb
While the new tweeters have leveled that field to a large degree and upgrading the crossovers results in a much improved speaker vs. stock, the TL still means something. The TL series have better built cabinets, the bass brace option, the AI-1 option and a more refined crossover.
Not true. The 1.2's and TL models are the same except for the tweets and crossover values. It is only the SDA-SRS which has a slightly different enclosure design and a more complicated crossover.
madmax
Vinyl, the final frontier...
Cabinet structure and 6510 drivers for mid-woofers would mean 2A, not that I could tell any difference between 2A and early 2B I owned though. For this vintage, I don't think it matters. The "real" 2B's with the end caps are the only ones I'd value now, and then only for appearance.
1. Polk LSiM-707, LSiM-704C, LSiM-702FX; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A31 and A23 amps; Oppo 205; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables 2. JM Labs Electra 920.1; Parasound JC2 and JC5; Sony HAP-Z1ES; Marantz SA8004 SACD; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables 3. Polk LSiM703; Anthem Pre-2L SE; Parasound A21; Sony 48" 4K TV; Wyred4Sound DAC 2; Oppo 203; Squeezebox Touch; PS Audio Power Director 4.7; MIT S3 cables
Wadia 301 transport | MacBook Air | PS Audio Digital Link III DAC with Cullen Level IV mods | Bluenote Bellavista turntable with Boston Audio Design "The Mat 1", B5 Signature Arm and DV-20X2H | The Clamp | PS Audio GCPH phono preamp | PS Audio GCP-200 preamp with external PS | Innersound active crossover/bass amp | Sanders Sound ESL panel amp | SVS PB12-Ultra/2 sub | Innersound Eros MK III Hybrid ESL speakers horizontally bi-amped | PS Audio PerfectWave P3 Power Plant | All cabling MIT Shotgun S1 | GIK acoustic treatments
someone should grab those.....
I talked to Scott and his buddy that needed a pair found some already.
Cmon CA POLKIES Step up these are a bargain.....I bet there gone by the morning.
With a SN in the 1800's, these are (were) SRS's...
We've seen these on ebay before...
Tour...
Vox Copuli
Was that an auction?
Tour...
Vox Copuli
Tour...
Vox Copuli
Tour...
Vox Copuli
BD(but everything has a price)T
madmax
Tour...
Vox Copuli
No affil...
http://cgi.ebay.com/POLK-AUDIO-STEREO-DIMENSIONAL-ARRAY-SDA-2A-SPEAKERS_W0QQitemZ5846740299QQcategoryZ71571QQrdZ1QQcmdZViewItem
Tour...
Vox Copuli
JT
JT
Original 2's in the Austin/ San Antonio area... Very blonde...
http://cgi.ebay.com/POLK-SDA-2-TOWERS-CUSTOM-ASH-CAB-NO-RESERVE_W0QQitemZ5847034212QQcategoryZ14992QQrdZ1QQcmdZViewItem
Tour...
Vox Copuli
Sda Srs
http://cgi.ebay.com/POLK-SDA-SRS-1-2-Tower-Speakers-The-Big-Ones_W0QQitemZ5850180889QQcategoryZ50597QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
no affil.
Anything under $1k these days is rare.
Tour...
Vox Copuli
Zach
