The 1.2TL, Project Monolith
1…789101113»
  • Unknown
    edited November 10
    xschop Posts: 5,932
    What about the Unknown engineer?
    Surely he knows or has knowledge of all things inert.
  • Gardenstater
    Gardenstater Posts: 4,991
    I don't think the heat shrink would do much to lower the resonant frequency from around 2.2 kHz. It might lower it maybe 3% to 6% mostly from the small additional mass. It won't effect the flexural rigidity much at all.
    The adhesive layer will add a small amount of damping, but the resonant frequency is still well above any of the standing wave modes in that enclosure so it shouldn't really be an issue.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • skipshot12
    skipshot12 Posts: 2,177
    edited November 11
    ptrooper wrote: »
    Wrapping them in this should do the job! What do you think?
    Was thinking the same thing.
    Or wrap it with dynamat?
    xschop Posts: 5,932
    I could actually fit all 20 in a medium International flat rate.
    Final glue up before they head to the land down under.
    Pound each assembled, not bad...
    xschop Posts: 5,932
    The orange hue addition looks very nice.
    I never post dimensions to your plates cause they are 1-offs, but IIRC I tapped them 8-32 on the back.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,224
    Change "Supra cables Rondo" to "Supra Rondo Cables"
    SDA SRS 2.3TL's
    SDA 2B TL's
    Viking64 Posts: 7,836
    Just don't blow some rando's cable in a Supra!
  • Unknown
    edited November 18
    VR3 Posts: 29,763
    That photo is hilarious, Ai either works great or exactly like that lol
