The 1.2TL, Project Monolith
This is quick and simple ,they will be completely inert, Ai told me so
Best to run it past the site Engineer @Gardenstater VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it! -
What about the Unknown engineer?
Surely he knows or has knowledge of all things inert.Don't take experimental gene therapies from known eugenicists. -
I don't think the heat shrink would do much to lower the resonant frequency from around 2.2 kHz. It might lower it maybe 3% to 6% mostly from the small additional mass. It won't effect the flexural rigidity much at all.
The adhesive layer will add a small amount of damping, but the resonant frequency is still well above any of the standing wave modes in that enclosure so it shouldn't really be an issue.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Thanks @Gardenstater ,I'll try not to overthink it , do it once ,do it right. I like OVERKILL .VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
Wrapping them in this should do the job! What do you think?
Was thinking the same thing.
Or wrap it with dynamat? -
@skipshot12 Or both?
Ill look into the sleeve sizes.It would remove a little internal vibe reflectivity from the dynamite aluminium I believe.Maybe a 1/4" butyl wrap like a barber pole under the sleeve ? There's still a bit of time until they go in.
I'm dreading shipping !
I was looking at a Mobile fidelity cd for $ 24 and $44 shipping
I could actually fit all 20 in a medium International flat rate.
Final glue up before they head to the land down under.
Pound each assembled, not bad...
Can’t wait thx Rob !
Has any one dealt with this company ? Or , is there somewhere in the states that can do?
https://audiotechnology.dk/
Exciting stuff! When the dowels go in , I’ll be having the crossover plates and tweeter bezels
Anodised .
I been using AI with its free 3 daily attempts and am close but still deciding on the tweet colour , it’s the duelund cap colour!
What do you think?
The orange hue addition looks very nice.
I never post dimensions to your plates cause they are 1-offs, but IIRC I tapped them 8-32 on the back.Don't take experimental gene therapies from known eugenicists.
