Post a video... any video
1…100101102103104106»
    billbillw Posts: 8,249
    That's literally the same video I posted, and then found it was AI generated. I was wondering why the person was pedaling the bike for no reason.
  • Unknown
    edited October 7
    That "Community Note" was added after I first saw and shared the video. That thing has gone viral today. The number of views has gone up by more than 25 million since earlier today.
  • ptrooper
    ptrooper Posts: 731
    I don't believe what I see on the net nowadays,Its probably done by a 8 year old. lmao.
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
  • ptrooper
    ptrooper Posts: 731
    edited October 8
    https://www.youtube.com/shorts/S2M_yL3a-Zw
    Go the Alpha dog pack mentality!
  • ptrooper
    ptrooper Posts: 731
    edited October 11
    Tony M Posts: 12,015
    ptrooper wrote: »
    I worked for a Plumbing and drain cleaning Co. for 7 years.
    I've seen some stuff similar to those videos and ALOT more. This Co. had pressure hose power 50 times that little homeowner thing he was using. The big pressure cleaner was mounted in a box-truck, with it's own water tank that was filled by a fire-hydrant. the nozzle pressure, like that in the videos above would slice through skin like butter. In those seven years, nobody got hurt. You RESPECT the nozzle!
    It was an experience everybody should see, like a Police ride-along.
    7 years seeing that happen off and on. I did mostly carpentry but if none was to be done, I was beside the owner and others doing major drain cleaning and water heater replacements. A lot of commercial pipe cleaning too.
  • ptrooper
    ptrooper Posts: 731
    edited October 11
    I was a licensed and registered plumber/gas fitter for over 20 years , me mate there as you can see is still going .We have to be here ,just to change a tap washer or anything plumbing...........Highly regulated.
    High-Pressure Water Jetting: Operating high-pressure water jet systems for drain cleaning requires specific competency training (such as units under AS/NZS 4233.1:2013), and if the work alters or repairs the drainage system itself, it must be performed or overseen by a licensed plumbing contractor.
    • What you CAN do without a licence: Recent WA legislative reforms allow an unlicensed person or homeowner to clear a basic, localized blockage (like a clogged sink or toilet) using a standard hand plunger.
    • Why pressure jetting is restricted: Using a high-pressure water jet system to flush out structural sewer or stormwater lines falls squarely under trade drainage maintenance. Doing this commercially without a WA Plumbers Licensing Board licence carries severe legal penalties and voids the homeowner’s insurance if a pipe is damaged.
    The standard pressure washers (hydro-jetters) used by professional plumbers for blasting out domestic and commercial drains in Australia are typically operating in the 3,500 to 5,000 PSI range.
    Don't be fooled by that little jet, Tissue and Bone Destruction: A direct blast at close range acts like a kinetic hammer. It can instantly shred flesh, strip muscles away from the bone, and shatter small bones in the hand
    The pressures that you used(50 times more) would cut our upvc ,earthenware and steel pipes in half... 200 000 psi is allot.......scary stuff.
    I seen a painter look into a blocked spray gun and squeeze that trigger = stimpy, he shot a lump of paint into his tongue and his heart stopped 3 times on the way to hospital.A CPR day.
    I've stood for many hours looking down at this happening down in the hole. That orange hose is what we used. That spray coming out is intense, too. POWER! ;)
    Similar truck setup.
