Mini models of the SDA SRS. i need help with crossovers.
I sent a photo of your first sculpture to Matthew Polk and he replied:
"3D printed? Very cool.
I'm honored. -msp"
I'll send him the white lab coat version, I'm sure he'll get a kick out of it. Well done! -
SeleniumFalcon wrote: »I sent a photo of your first sculpture to Matthew Polk and he replied:
I'm honored. -msp"
What!! -
Lerjebrink wrote: »
Some progress on the tweeters!
How will you make them a progressive point source like the "real" SDA's?
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Lerjebrink wrote: »
I use almost the same HF components as the original. Hopefully it sounds better than just 4 straight tweeters with the same components.
Lerjebrink wrote: »Lerjebrink wrote: »
But they aren't the same drivers, so using the same electrical parameters is sort of moot. I predict lots' of lobing issues as well as phase issues and combing issues. The spacing of drivers and baffle angle on original SDA's is pretty critical to SDA success.
Not trying to be a downer, just curious about critical elements of the SDA's and how well you've considered them.
Who knows. I mostly make them to look like the big ones. Just a bonus if they sound ok. I think i have better chances with 4 differently tuned tweeters than just 4 straight wired onesLerjebrink wrote: »Lerjebrink wrote: »
The closer drivers are together the less lobing and comb filtering. Kind of by definition. And he copied the crossover so they aren't playing the same bandwidths.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Lerjebrink wrote: »
I'd be interested how they would perform as near-field monitors too. Overkill would be welcomed.Don't take experimental gene therapies from known eugenicists. -
👎Lerjebrink wrote: »Lerjebrink wrote: »
H9I disabled signatures. -
Lerjebrink wrote: »
Way cool.
What will be the dimensions of the finished minis? -
Ok how do we order the Matt Polk statue- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Hahaha wait a little! I will think about this and actually make some more. Hold on -
skipshot12 wrote: »Lerjebrink wrote: »
Way cool.
Outside dimensions in mm will be 248Wx635Lx158D
Time for some soldering on the inside -
I do applaud your vision. Very cool even if they don't turn out to sound like SDA's. If they do, then that's a bonus.
woah woah woah, are those dimensions in Celsius or Kiloliters or something?Lerjebrink wrote: »
Outside dimensions in mm will be 248Wx635Lx158Dskipshot12 wrote: »Way cool.
Millimeter.
MM is more scientifically and mathematically advanced. Millimetre
French Scientists / French Academy of Sciences Invented in 1790 during the French Revolution to create a unified, rational system based on the natural world (originally derived from the Earth's circumference).
Inch Ancient Romans / Anglo-Saxons Originally based on human anatomy—the width of a human thumb. The Ancient Romans introduced the uncia (meaning "one-twelfth" of a foot). King Edward II of England later standardized it in the 14th century as the length of three grains of barley placed end-to-end.VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it! -
The metric sytem finds a constant of mass and volume within pure water.Don't take experimental gene therapies from known eugenicists.
Measurements to nearest picometer or go home.
Seriously, enjoying watching your project come together.Jay
If you're not using 64th's then.....
https://forum.polkaudio.com/discussion/198981/you-re-doing-it-wrong#latest -
You guys count in feet… 🦶🏼
Along the equator or the poles? They are different dimensions.Gustard X26 Pro DAC
Lerjebrink wrote: »You guys count in feet… 🦶🏼
Feet fingers and toesGustard X26 Pro DAC
Yep, they used the pole-to-equator distance, which is just one-quarter of the polar circumference. Same math, just a specific slice of the globe.
Looking forward to a price on the 3d Matthew polk Figurine with flag ship SRS.
I bet,@Lerjebrink ,will soon be bombing out the big boys in the near future.
Yea probably, adult money is very dangerous.
