The 1.2TL, Project Monolith
Updated the design to omit one of the pointed detents. This will let the other end self-align perpendicular while pressure is increased. Will make install a breeze....
Don't take experimental gene therapies from known eugenicists. -
Hey Sean, version 2 can be accomplished by machining the large bolt head flat. A 9/16-18 bolt head would have same contact area as 1" round dowel....
Plan on using 7075 alloy and Grade 8 zinc plated bolts and nyloc nuts with copper anti-sieze.
you'll just need a 13/16" (21mm for you Blokes) wrench to install after a good dab of Loctite Powergrab or Liquid Nails.
A spring-loaded punch will make for pinpoint placement accuracy as well.Don't take experimental gene therapies from known eugenicists. -
The point would be pointless as it wouldn't penetrate the particle board under compression. Would be a smudgey affair I'm afraid.
Think I'll go the extra trouble to butyl wrap the alloy rods just for good measure.
Rebellion to tyrants is obedience to God.
From the bloke on my hunnerds.
@ 1/2" or less when installed. Why I need a good measurement from you.
Looking back, I remember an old thread/post that stated there was a thicker front baffle between later and earlier 1.2's.
I'm going to build a set for my XS-8TLs too.Don't take experimental gene therapies from known eugenicists. -
Started prototypes. Still waiting on new tap and nylocs....
Shop neighbors are the best...
Now just waiting on some locknuts from Fastenal...
When all said and done, hex heads are still 0.950 apex to apex....
How will you be attaching it to the inside, pressure?
Would putting some type of rubber damping material on the ends help with the cabinet resonance? -
Yes, pressure set by hand-twist of the dowel. These will attach with PowerGrab or Liquid Nails once set just like a wooden dowel, but be simple to install and remove. I plan on pinpointing this set right between top MW and tweeter on the 8TLs as it is the weak spot from factory.
I just tested the dimple in a piece of plywood. Too easy and won't budge laterally without glue. The old particle board will provide a little more resistance before bottoming out at interface.Don't take experimental gene therapies from known eugenicists. -
That looks like all the weak points are addressed given the orientation of the semi-rings.
Final testing. Temp. Installed one in the 8TL right between top MW and tweeter. Point facing forward, adjustable bolt in rear, it self aligns perpendicular EASILY with a simple twist of the rod holding the hex steady. Main design goal achieved. I Rasped on it before and after. Even with only a 9" wide baffle, it stiffened right up and sounds much more inert.
I still haven't received the locknuts, but once location is decided, all would be needed is Blue Loctite and the PowerGrab/Liq. Nails...
They are almost dead silent without butyl wrap. Even when I hit them with a metal punch, they have a short clink, but no ringing.
With butyl wrap....Dead silent....
Not so sure that'd be necessary. Even with ear up to them, they are silent when rung.
When you get me that final dimension, I'm curious what the front baffle thickness is also on the Monoliths, 3/4" or 1" ?Don't take experimental gene therapies from known eugenicists. -
Sounds like a plan. I remembered GM added a bell weight to the C5 Vette torque tube to stop it from ringing but it is hollow and 6 Ft long. Dropped right in the 928 with a carriage and custom axles.
FYI... C=πD but I had to add extra quarter inch length to the butyl mat when I rolled it on due to the dual layers. Easy Peasy.
Have a good trip and let us known how the local beer is.
What an impressive build!
I cannot help but ask mate, as these speakers are 40 bloody years old. Why spend so much quid on these
when you could have had a bloody set of Magico and still had money left over? -
Do the Magicos produce a massive enveloping SDA soundstage?Don't take experimental gene therapies from known eugenicists.
Nothing much I have heard does. We like it, but some say it's not natural. Let them spend more for less enjoyment. SDAs always put a smile on my face when good recording hits the preamp. -
Excellent 😎 this will lock that tweeter array in solid as a rock ,10 in each enclosure ?
Neutral pressure will be my goal !
Tuned to 17 Hz
I'm thinking little corner braces between both the front baffle and the back of the enclosure and the enclosure sides. Let us know what thicknesses Polk used if you can and whether they are MDF (I think people have reported MDF but there are different densities) or particle board. These 1 in. dia. braces will help to increase baffle stiffness, obviously, by coupling front baffle to the stiffer rear of the enclosure, but there is still some flex there. The little corner braces wouldn't decrease enclosure volume by much but would be big bang for the buck in stiffness.
Also we can't forget the poor coupling of the midwoofers to the baffle with only 4 tiny head mounting screws on a fairly flimsy basket, although later models of midwoofers that Polk built had thinner still gauge of steel. That's why I use #10 1/8 in. thick steel square nuts under the heads of my mounting screws. You can really feel them tighten up and they stay tighter over time as well. Going to 8 holes in the basket is a no brainer if you are wanting to really couple well. Yeah 6 holes is probably a huge improvement but there is no way geometrically possible to just drill 2 more holes and have them be uniformly space so why not go 8.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Do these speakers already have effective and sufficient corner bracing? Been a while since I saw a photo of the interior. But what I was thinking was just some 1 x 1 with a 1/4 roundover hardwood pieces cut on a 45 at each end and glued in wherever there seems to be a need, if anywhere.
I see a brace in this pic (looks like particle board?) that accomplishes what I am referring to and presumably there are more than this one.......just above the tiny capacitors
George / NJ
iFi nano iDSD DAC
iPurifier3
Yeah the 1/4 in. thick (brilliantly designed) braces do complicate things when doing the 8 hole mod. Why I haven't gotten around to doing my 7Bs yet. Just a little more involved since they have to be drilled and tapped in place. I think one of those portable mini drill press accessories would help a lot with the process. For drilling the driver you just have to make sure no metal chips enter the basket windows by taping them off and I'd tape the magnets too so no ferromagnetic dust attaches there as well that can't be vacuumed off easily. If you (I mean others) have done the phase plug mod you also have to make sure nothing enters between the cone and the plug. I still swear by these #10 steel square nuts used as a pressure plate between the screw head and the basket. It basically triples the contact area especially with the oversized holes in the basket. Hasn't caught on and as far as I know nobody has tried it. The only PIA aspect is I had to mill down one side for clearance at the surround side rather than cut the rubber out.
PS: OMG the flash photography makes the Polk trilayer pixie dust really stand out. Prior to cleaning.
George / NJ
iFi nano iDSD DAC
iPurifier3
