The 1.2TL, Project Monolith
1…5678911»
  • ptrooper
    ptrooper Posts: 704
    Ok. I’ve ordered a tape measure. Check out the 1970’s remaster from another Aussie classic band .
    Sounds extraordinary on SDA’s
    https://www.youtube.com/watch?v=oYSdjCu_lC4
    SDA SRS 1.2TL VR3 Duelund Monoliths<3,Lumin u2x,LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb...Working on it!
  • ptrooper
    ptrooper Posts: 704
    treitz3 Posts: 20,357
    What do you have that going from/too?
  • ptrooper
    ptrooper Posts: 704
    edited September 24
    From the Luminu2x -to the Soon to be replaced Jlti oppo205 ! New dac will be a ???
    This SInope SE cable is replacing an Audioquest diamond .75
    After ten hours I’m very impressed,sounds more dynamic with very Airy highs , tighter deeper textured bass and the midrange is very holographic becoming effortless ,Liquid almost
    I’m finding the more upgrades I’m doing ,the better control the Monoliths bottom end has , it feels like more energy and control is focusing into the midrange and top end.
    The Audioquest is no slouch though ,I feel it’s a bit more analytical and in my face than the SInope,I loved the AQ for the 6 weeks I had it and highly recommend it !
    xschop Posts: 5,811
    treitz3 wrote: »
    That'd fix my printer problem.
  • ptrooper
    ptrooper Posts: 704
    edited September 27
    xschop wrote: »
    treitz3 wrote: »
    That'd fix my printer problem.[/hrt5lsc242kv.png
    Will .75 be long enough for your printer?
    xschop Posts: 5,811
    Lol. My printer needs an audio grade USB so it can make the annoying sound clearer. :D
    xschop Posts: 5,811
    edited September 29
    Updated the design to omit one of the pointed detents. This will let the other end self-align perpendicular while pressure is increased. Will make install a breeze....
    xschop Posts: 5,811
    Hey Sean, version 2 can be accomplished by machining the large bolt head flat. A 9/16-18 bolt head would have same contact area as 1" round dowel....
  • ptrooper
    ptrooper Posts: 704
    Nice work Rob B) . I'll get that measurement soon ,What materials will you use and which glue do you recommend?
    xschop Posts: 5,811
    edited October 1
    Plan on using 7075 alloy and Grade 8 zinc plated bolts and nyloc nuts with copper anti-sieze.
    you'll just need a 13/16" (21mm for you Blokes) wrench to install after a good dab of Loctite Powergrab or Liquid Nails.
    A spring-loaded punch will make for pinpoint placement accuracy as well.
  • ptrooper
    ptrooper Posts: 704
    edited October 5
    xschop wrote: »
    Im looking into using 1.25-1.5 Dia. Black Delrin too for damping and resonant characteristics vs. sand filled alloy.
    You given up on this idea Xschop?
    Sinope SE usb Hitting 200 hours, wowza ,I wouldn't recommend using bypass caps!......Upwards and onwards.
    xschop Posts: 5,811
    The point would be pointless as it wouldn't penetrate the particle board under compression. Would be a smudgey affair I'm afraid.
    Think I'll go the extra trouble to butyl wrap the alloy rods just for good measure. B)
