Let’s see some Tube Glow!
12345679»
    heiney9 Posts: 25,712
    Dared 2000
    Bendix 6106 rectified
    2x GE 6201 triple mica black plate
    taj9icjacb66.jpg8fz62853wz43.jpgtyr6dglvvzoa.jpgOut with the Bendix 6106
    In goes
    1950 Brimar 5z4g black plate. I got two of these during covid from Australia both N.O.S.
    This thing is a beast, it's twice the weight as the brown base on the right
    The 1950 Brimer (left) is much sweeter on the ears than the later brown based version on the right. The weight tells the difference, thicker glass and heavier plates and guts.
    Early 1950s vs 1972. The tube hey days are starting to wind down by the middle to late 70s
  • Unknown
    edited September 18
  • Butter
    Butter Posts: 66
    I haven’t got a chance to roll many tubes with that one yet. It paired up really well with the RCA triple Mica black plates I have. I have a pair of Mullards that came with it that I haven’t tried yet. I have a pair of platinum Raytheon 6414 triple Mica’s that really sound really deep and wide. I just love how you can totally change your sound. Trying to figure out which combinations sound best with different types of music!
    edited September 18
    The early 50's Brimar had the deepest more organic bass texture and widest sound staging compared to anything, including the Bendix 6106. The 6106 is so cool to look at though.
    All the other 50's rectifiers are great, but the Brimar is the King in the Dared SL2000, IMO.
    I kept one in my stash (always keep some of the rarer hard to find tubes for a rainy day or if you run across gear in the future) I also kept 2 of 3 Mullard 5AR4's (older f31 Fat Bottle and newer f32 5 notch standard bottle)
    I bought this for use as a pre-amp, which uses a 5Z4P. I put in the trusty Brimar CV1863 and it sounded excellent. Put in the Mullard f32, 5 notch 5AR4 (GZ34) and it is sublime!
    I don't suggest using a GZ34/5AR4 in the Dared. The moral of the story is, trying different tubes can be a revelation. What works well in one scenario doesn't always work the best in another. I could easily live with the Brimar, but after hearing the Mullard I won't go back.
    ***When I said "I won't go back", that's referring to the Xduoo TA20Plus, not the Dared SL2000.
    Just wanted to clarify.
  • Unknown
    edited September 20
    I have a pair of the 3 mica 6060's coming for my Galion.
    Actually I was mistaken. I am getting a NOS pair of 1954 CV455 smooth anode, horse shoe getter made in Eindhoven Holland w/Mullard label.
    And a pair of NOS 1956 Brimar CV455, 3 mica, black box plate, double post square getter KB/FB date code ^MC
    If you are in need of true NOS 12AT7, ECC81, CV4024, CV455, etc. I have a source. They aren't cheap, but they aren't uber expensive either. PM me
  • Butter
    Butter Posts: 66
    Rolling my mullard 12AT7’s with the RCA JAN CRC 5G4Z👍
