The 1.2TL, Project Monolith
1…5681011…13
  • Unknown
    xschop Posts: 5,932
    They'll get over it. Aussie away I say. Looking forward to the updates Sean.
  • skipshot12
    skipshot12 Posts: 2,177
    Cheered back at ya.
  • skrol
    skrol Posts: 3,500
    You can tell when the dad is left with the kids at home and mom is out for the evening.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    xschop Posts: 5,932
    edited August 9
    ptrooper wrote: »
    lightman1 wrote: »
    "The!" best pair I've ever heard.
    @lightman1 This is a very generous comment considering they only had around 100 hours of burn-in. Trey informed me of this just before your listening session. These are currently in the process of another upgrade; when done, I will post the pics.
    The room acoustic treatments are so close to being perfect right now, and the Monoliths are truly like a fine wine, getting better with age—they will have to be clawed away from my dead body. Thanks again to everyone for helping get my Polk dream this far.
    I’ll try to keep the Aussie vocabulary to a minimum so I don't confuse the sensitive folk."
    Shorty 1.2TL's on the horizon?
  • Unknown
    edited August 9
    xschop Posts: 5,932
    Master Po would be proud. B)
  • Unknown
    edited August 22
    treitz3 Posts: 20,367
    What kind of footers are you using on the Lumin?
  • Unknown
    edited August 25
    edited August 25
    No, those are both clock inputs. The Lhy and the Lumin both have internal clocks. If you were to get a better clock, then you would use the cables to connect from that Master clock into both the Lhy and the Lumin. That way both units would be synced and clocked in the same time reference.
    They would both have to have the same Hz as well, otherwise you would have to run separate clocks for each one. The majority of clock inputs operate at 10MHz, but you would have to check and see what each inputs Hz rating is to be 100% sure.
    Adding an external master clock defeats the KISS theory, because it adds more components and cables, but the case for sound makes a Master clock invaluable to the KISS theory because it lessens the amount of jitter, noise and unwanted artifacts when it synchronizes both units to the exact same time domain and it also tells each unit exactly when to send the sample rate for perfect synchonization of both units. This results in a much cleaner sound.
    There is a lot more to it, and I hope I explained this good enough for folks to understand, but this should give you an idea of why just adding a cable between them won't do anything. Both units would still be using their internal clocks.
    On another note, Audio Sensibilities makes a great umbilcal cable for inbetween the PS and the Lumin. It costs less than the Westminster and offers an estimated 95% of what the Westminster offers. It was a good uptick in sound quality for me.
    Just food for thought as you transition from HT to 2 channel audio.
  • Unknown
    edited August 25
    Actually, I stand corrected. (Sorry, I am not familiar with your switch) It appears as if your AS8 Pro switch has both an external clock input AND output. So, you could connect the switch to the Lumin. You would want to weigh in on which clock is better and which one has a lower noise factor. This is usually measured three ways, but most manufacturers unfortunately only list one at that certain frequency.
    You always want to use the better clock, and just getting an external clock just to have one may not be an improvement, It could actually make it worse. My Mutec REF 10 SE 120 has the lowest of all the internal clocks in my rig, so I use it. It has a -120 dBc at a 1 Hz offset from the 10 MHz carrier, but again, that's just one parameter that needs to be paid attention too.
    At your reported rating of -112 dBc/Hz at a 1Hz offset, the internal clock appears to be pretty good - BUT you would need to compare that to the performance of the internal clock in the Lumin to figure out which one is better. If the Lumin's internal clock is better than the switch, I wouldn't even bother with hooking up the cable.
    ptrooper wrote: »
    Using SPF between the two then adding a clock or clock cable breaks their galvonic connection and defeats the purpose of fibre connection completely.
    It does not, if all channels on a Master clock are galvanically isolated and completely separate as well. Just an FYI. You just can't use the same PS for the switch and the clock, as that will loop it all in together and defeat the fiber isolation. FWIW.
  • Unknown
    edited August 25
  • Unknown
    edited August 25
    Cool deal. Sounds to me like LHY has been paying attention to John Swenson. I have the same thing in my switch, albeit a different type of "moat" that does not convert to fiber, and then convert back. That can add noise (not much, but still measurable). The second moat in my system is using Wi-fi to get the packets of information back to the listening room. The third moat is that everything on the streaming portion of the rig is plugged into a power conditioner that also offers galvanic isolation from the incoming A/C. The end result is a VERY clean signal and ultra low noise. My noise floor is very close to yours as well. That is awesome!
    It appears as if we are doing the same thing, albeit in different ways to go about it. What you have done let's me know what level you are playing on, and the types of sounds you are experiencing. Very nice.
    ptrooper wrote: »
    Where do we stop
    I don't think guys like you and I ever do. LOL. I like to keep pushing the envelope. Sounds to me like you are in the same boat. Nothing wrong with that at all! Heck, to me, that's half the fun.
  • Unknown
    edited August 25
  • Unknown
    xschop Posts: 5,932
    All this audio goodness has me inspired.
  • Unknown
    xschop Posts: 5,932
    Not sure about how the tweeter rows are braced on yours. You can probably leave those factory or update. However, orientate your steel semi-rings (red) horizontally and use 1" dia. solid oak dowels (yellow) front to back. This will fix any baffle flex and not take up much air volume. I'd even swap out the rectangular brace/s between the Passive and X-over plate...
  • Unknown
    edited August 28
    xschop Posts: 5,932
    10 or 11 1" dowels wouldn't even take up half a cu. ft.
  • Unknown
    xschop Posts: 5,932
    edited August 29
    Plan on leaving the semi-rings as is. Take a pic and measurement between MW edges.
    Draw out the "cup" design you have in mind and go from there.
    Ponder it over a VeggieMite sandwich.🤔
    Also never heard back from you on your listening impression I requested...😅
    https://www.youtube.com/watch?v=RY7S6EgSlCI
  • Unknown
  • Unknown
    edited August 30
  • Gardenstater
    Gardenstater Posts: 4,991
    edited August 30
    It always amazes me when it comes to audio that you don't know what you're missing until you know it.
    BH5 isn't supposed to effect the enclosure volume because of the floating vinyl layer with the closed cell underneath. That floating layer tends to help with preventing sound transmission prevention. The No-Rez stuff does away with that layer.
    There have been a few ways people have done the braces, joebass3 made them out of square stock with v-blocks on the front and back so that the braces could be screwed into them. I think xschop and tool just power grabbed them into place with a slight clearance I guess, and SCompracer used a pocket hole jig and screwed and glued them into the front and back. I think another way might be with one end cut short (I'd use square stock with the corners rounded off at the router table) and at a slight angle and you could have a wedge that jams it and you could (maybe?) even listen to the configuration before gluing everything in place or maybe just tack glue with a few dabs of super glue that could be cut through (or just run a JB Weld fillet around everything) for the permanent glue. I'd use epoxy but I know that is overkill. I like overkill.
    https://www.youtube.com/shorts/YTGGRGbOGNs
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
