1228229230231232234»
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,932
    Harry / Marietta GA
    mhardy6647 Posts: 35,390
    edited 7:55AM
    msg wrote: »
    And somewhere @Tony M, some dude has a project on hold, half completed for weeks, or years, maybe, perpetually about to go to the store for an 18mm socket, toiling, "I KNOW I have one, I just don't know where the #$%* it could have gone!" :DB)
    Old Steven Wright joke:
    “In my house there's this light switch that doesn't do anything. Every so often I would flick it on and off just to check. Yesterday, I got a call from a woman in Madagascar. She said, 'Cut it out.'”
    B)
    PS We live in a house that we had designed and built. We have one of those switches.
    My wife tells me that she and the builder decided to install it (in our mudroom) in case we ever wanted to add path lighting outside. So she tells me...
    billbillw Posts: 7,963
    edited 8:52AM
    It's the 3/32" hex key that I can never find when I need it. For low torque applications, I've found a T10 torx bit works well enough :D Perhaps I should head to Horrible Freight for a cheap new set of keys in a holder so I don't have to sort through a drawer of random hex keys that are anywhere from 25-75 years old with various coatings of rust.
  • BlueBirdMusic
    Harry / Marietta GA
    msg Posts: 10,546
    edited 10:42AM
    billbillw wrote: »
    For stuff like Allen wrenches, I'll splurge for quality. I've found these to be very good, close tolerance, hardened, and don't deform with use. Handy holder to help keep track after use.
    (That said, yes, I still have all my old Allen wrenches, too. You know, just in case. Or if I wanna keep my good ones good; another stupid notion :DB) )
    https://www.amazon.com/dp/B000E7XJSY
    https://www.amazon.com/dp/B00012Y38W
    msg wrote: »
    billbillw wrote: »
    yeah, me, too (FWIW). Nothin' worse than cheap hex keys. :/
    I have my good ones squirreled away in my tool chest. So far, I've consistently remembered to put them back, too. :)
  • BlueBirdMusic
    Harry / Marietta GA
    Tony M Posts: 11,870
  • sucks2beme
    sucks2beme Posts: 5,697
    I did finally organize my sockets with those plastic trays from harbor freight,
    as well as my wrenches. I have 18mm in deep,shallow and impact.
    I even bought bigger sizes for those odd jobs. What's scary is my selection
    Of oil filter tools. Small,large, pliers, adjustable and even that special weird
    one Toyota uses. I just got rid of the Camry, so I guess it's just junk now.
  • sucks2beme
    I just looked. I have a timesert kit for fixing blown out spark plug threads in
    Old 4.6l and 5.4l Ford motors. I bought it 20 years ago. It came with 10 inserts
    and I have 8 left. Why am I holding on to it, other than it cost me $300.
    It's sitting next to my tube tester. I guess ebay is the answer?
