1…210211213215216…243
    pitdogg2 Posts: 27,914
    edited October 20
    My buddy calls his granddaughter, Charlotte, “Chuck.” 🙂
    Actually pretty common
    nooshinjohn Posts: 26,178
    Took me a sec but I figured it out....
    Def. the worst case I've seen.
    (ASR)
    I bet his shoe fittings are hilarious 😂
  • Willow
    Willow Posts: 11,370
    Care to dance.
    Viking64 Posts: 7,830
    Walking up/down stairs would suck.
    mhardy6647 Posts: 35,562
    Willow wrote: »
    Care to dance.
    On the bright side, he doesn't -- necessarily -- have two left feet.
    Although, of course, we can't be sure of that.
    Well the bright side is his partner would need to be over the top terrible to step on his toes 😂
  • Willow
    He'd never see it coming
    audioluvr Posts: 6,079
    Does he walk backwards or forwards? Inquiring minds want to know.
    edited June 22
    audioluvr wrote: »
    exactly.
    Reminds me of the classic experiments of Roger Sperry on "chemical imprinting" (edit) "chemoaffinity" using frogs. The image projected onto the retina in an eyeball is, of course, upside down. If one flips they eyeball upside down (surgically) and also severs the optic nerve (which, in a frog or tadpole, can regenerate), does the regenerated nerve "see" the eye as inverted or not? Turns out, the experimental subjects saw the world upside down after the nerves regenerated! Classic developmental biology stuff -- my wife has a background in developmental biology :blush:
    https://people.uncw.edu/puente/sperry/sperrypapers/50s/58-1956.pdf
    So... this foot guy... someone could do the same sort of experiment on him.
    msg Posts: 10,650
    jeez. what a joke to play on your frog friends after a night out.
  • ken brydson
    ken brydson Posts: 9,107
  • agingboomer
    agingboomer Posts: 697
    F1nut Posts: 52,406
    ^A Learing Center graduate^
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,137
    Harry / Marietta GA
  • agingboomer
  • ken brydson
    I will abstain from comment on all of the examples given :#, save one.
    Did you notice there's no black paint in that image?
    Hmm...
    B)
  • agingboomer
    Hose Water: The Official Sports Drink of Summer 1960
    msg Posts: 10,650
    11/15!
    Tony M Posts: 12,029
    13/15 :s
    I've got everything but the expired coupons... but I really didn't need to tell anybody that, did I?
    :blush:
    edited June 25
    We have two tranches of plastic bags stuffed into other plastic bags.
    One tranche is to use to line trash cans.
    The other tranche is set aside to take to the store and put in a container they have there, hoping that the store will magically find a way to recycle them. This, I believe, is called virtuecycling. :#
    :blush:
    Maybe. I think everyone would have been certain that you had expired coupons as well. :p
    well... I mean... a few... but not a collection.
  • motorstereo
    motorstereo Posts: 2,428
    Yep all 15 here to and the one I'm most proud of isn't listed. My precious 5 gallon pail full of plumbing and compressed air fittings. I've known for a long time I won't ever use any of them but there they are within my grasp in just a few seconds.
    I... umm... shared that list @ hifihaven.org :blush:
    Here's one of the responses (detoxed a little bit since Nanny Vanilla is so sensitive :#):
  • sucks2beme
    sucks2beme Posts: 5,703
    It's all useless until you throw it out. Then you'll suddenly need that odd fitting.
    15 years years and you missed it by a week. So you buy another pack at the
    hardware store and start the process over again.
    billbillw Posts: 8,367
    I raid my tubs of random saved fasteners at least 6 times a year. I really wish I had leftover paint for the house I'm in. So many little scuffs that could be touched up. Mixing a new batch will never match. I have at least three old, unused android phones and probably have an old Moto RAZR somewhere. I use my old Pixel 3 every time I use the smoker to run the app for my wireless temp probe. Wood scraps always get used at some point. About the only things I don't do are keeping expired coupons, or half filled note books. I try to purge keys if I know the lock is gone or destroyed, but there might be a few in the bottom of my key jar.
