XSchop's modded 5jr
First off, apologies to you as I referred to you as Polksda in a few previous comments. I need more coffee.
On page 2 of the glue pic, It is most important that the glue completely surrounds old woofer, tweet, and port hole. The bridge between woofer and tweeter is rock solid on the previous set now as I checked with a screwdriver on the re-foam process. The edges alone would hold the plate with no issue as this glue is mega strong.
That said, I am taking your advice and removing the old woofer instep/base on this set as I know that the bridge will still be rock solid.Don't take experimental gene therapies from known eugenicists. -
Another mod previously not posted....
My Bosche right angle with 90° countersink I machined the shank to fit,
worked a charm at fluting the inside port. Smoothed it off with 220 sandpaper by hand.Don't take experimental gene therapies from known eugenicists. -
Last but not least, on this second billet plate set, I opened the ports up another 0.025" to 1.150 Diameter.
Reason being, the best tool to open up the factory port hole is a longer serrated-edge hole saw using the faceplate as a guide. Serrated edges are not accurate however. My new plates have a show quality finish that I don't want scarred when re-drilling the port.....
New Caps and resistors showed up. I'll start X-over mod tonight. Belt sanded the edges smooth with factory baffle and removed MW instep. I had to get new fine-tooth blades for my jig-saw. This MDF will chip easy if you use a coarse blade.....
Looks like fun !
I still have an extra pair of 5 Jr's that are a little more scratched up than my good pair and I'm thinking of changing out the stock tweeters for some 1962 Jensen horns that have lived in my closet for years.
I'll have to make an adapter ring to cover the stock hole. as it's too wide, but I figure if it doesn't work out, I'll just keep the woofers and crossovers for spares.
I just finished re-wiring the whole rig with pro cables and re-introduced my equalizer into the mix. -
What diameter is each horn where it would slip thru box?
The smaller diameter of the oval in the MDF is 2.85"
The top-bottom width of the SL-1000 plate is 3.05"
IMO this is a faux pas on Polk's behalf also.Don't take experimental gene therapies from known eugenicists. -
The interior flange hole would be 2"x6 1/4" , but the plate itself would have to be 4"x 6 3/8".
That would not only cover the original tweeter hole, but also the two grill snap holes, which would have to be removed anyway to accomodate the horn's flange.
If I was running your machine, I'd just make a whole new face plate and countersink the horn's flange an 1/8" and do likewise with the woofers.
(only another 1/8" for those)
More than likely though, I'll just go down to Michaels and make a couple out of 1/8" plywood doll house stock, then break the edges and paint them black. -
Ah OK. I thought you were talking about one of those small dia. Horn tweets that you just drill a hole to mount.
The only non "cheated" time aligned Polks are the RTA-12's
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Nice and substantial, I take it you don't need -6° stands for those either?
How would those compare to the 11T's?Don't take experimental gene therapies from known eugenicists. -
Much easier and cleaner. I'm going to wrap them in foam this time.
Does it matter if the resistors are physically touching capacitors?
Found my old thread thru Duckduckgo lol.
I'll post my progress here on this side project. Got an old set of these back with a blown tweeter, gouged cabinet and slight dent on the woofer. They were set up in a game room near a pool table.
Herculiner works better than Rustoleum for sure...
Soldered in new tweeter leads...
This one I carefully sanded around baffle edge and added water putty to area that particle board got gouged. Luckily no metal was nicked. Rest of it looks good.
Cabs are done. I'll have to throw the other one together in the morning and have a listen. Only spare plugged 6502 I have on hand has the 8 hole mod and a carbon fiber one....
Wonder what Mr. Polk would say @ what I do to his classics...
Bless your heart🖤Wonder what Mr. Polk would say @ what I do to his classics. -
Really could care less what anyone thinks. Best sounding vintage midrange from these. Just gotta dial in the highs. Looks like this tweeter just needs an extra 0.5 ohm on the circuit.Don't take experimental gene therapies from known eugenicists.
I like the look of the aluminum bezel. How thick is it?Political Correctness'.........defined
President of Club Polk -
All of them were 5/8" 6061-T6. Think I stated it before. The KSi of the alloy versus the particle board is a huge difference.
Got a couple 2 ohm resistors to swap out later this evening. It's really hard to say if its even needed.
Amazing the bass these put out too with the extra air space and port size.
WAF factor is a hit too and I like I dont have to build stands...bonus
I'll let the forum decide. Billet face CRS+ this go round?
Tweeter burn-in is real. These things are smoothing out. They already have 2 ohms resistors on the tweeters.Don't take experimental gene therapies from known eugenicists.
Made newer gaskets from 0.070" self-adhesive neoprene foam rubber material.
Also will install 6" diameter sound absortive foam on top of X-overs as they sit right behind MWs in these models....
And these drivers I put in already had @Gardenstater
foam frame mod done to them as well...
I think it looks great.
Given the interaction I had with Matt Polk he would probably look at them and listen this talk to you about wine and coffee 😅- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well, we're cut from the same cloth then. I got more excited about the new 100% Angus burger place in my hood...
He talked to us for about a hour or so and none of it was about audio lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Installed the focus ringed and plugged mids from donors that @toolfan sent me a while back.
Was on a Hiroshima binge late evening. These are the best sounding mids I've heard from all the Polks I've experienced including R200's.
Found some cool stands too and set them up in guest bedroom to do critical listening....
Jeezus.
Nice.
[no more words]The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage -
I like it, a set of Billet Aluminum Monitor 7’s would be the shite IMO..
Looks really good.
When my XS-CRS are done, I'll let these go and fund the billet baffle 8TL upgrade.Don't take experimental gene therapies from known eugenicists. -
My CRS+ will be here next week, so packing these up. I'll let them go for $500 if anyone here is interested. I'll split shipping for a fellow Polkie too. Just holler.Don't take experimental gene therapies from known eugenicists.
