XSchop's modded 5jr
124»
    xschop Posts: 5,652
    edited February 2016
    First off, apologies to you as I referred to you as Polksda in a few previous comments. I need more coffee.
    On page 2 of the glue pic, It is most important that the glue completely surrounds old woofer, tweet, and port hole. The bridge between woofer and tweeter is rock solid on the previous set now as I checked with a screwdriver on the re-foam process. The edges alone would hold the plate with no issue as this glue is mega strong.
    That said, I am taking your advice and removing the old woofer instep/base on this set as I know that the bridge will still be rock solid.
    xschop Posts: 5,652
    Another mod previously not posted....
    My Bosche right angle with 90° countersink I machined the shank to fit, c2uvdss7xygo.jpg
    worked a charm at fluting the inside port. Smoothed it off with 220 sandpaper by hand.
    Post edited by xschop on
    xschop Posts: 5,652
    Last but not least, on this second billet plate set, I opened the ports up another 0.025" to 1.150 Diameter.
    Reason being, the best tool to open up the factory port hole is a longer serrated-edge hole saw using the faceplate as a guide. Serrated edges are not accurate however. My new plates have a show quality finish that I don't want scarred when re-drilling the port.....
    xschop Posts: 5,652
    New Caps and resistors showed up. I'll start X-over mod tonight. Belt sanded the edges smooth with factory baffle and removed MW instep. I had to get new fine-tooth blades for my jig-saw. This MDF will chip easy if you use a coarse blade.....
  • Looks like fun !
    I still have an extra pair of 5 Jr's that are a little more scratched up than my good pair and I'm thinking of changing out the stock tweeters for some 1962 Jensen horns that have lived in my closet for years.
    I'll have to make an adapter ring to cover the stock hole. as it's too wide, but I figure if it doesn't work out, I'll just keep the woofers and crossovers for spares.
    I just finished re-wiring the whole rig with pro cables and re-introduced my equalizer into the mix.
    xschop Posts: 5,652
    What diameter is each horn where it would slip thru box?
    The smaller diameter of the oval in the MDF is 2.85"
    The top-bottom width of the SL-1000 plate is 3.05"
    IMO this is a faux pas on Polk's behalf also.
  • The interior flange hole would be 2"x6 1/4" , but the plate itself would have to be 4"x 6 3/8".
    That would not only cover the original tweeter hole, but also the two grill snap holes, which would have to be removed anyway to accomodate the horn's flange.
    If I was running your machine, I'd just make a whole new face plate and countersink the horn's flange an 1/8" and do likewise with the woofers.
    (only another 1/8" for those)
    More than likely though, I'll just go down to Michaels and make a couple out of 1/8" plywood doll house stock, then break the edges and paint them black.
    xschop Posts: 5,652
    Ah OK. I thought you were talking about one of those small dia. Horn tweets that you just drill a hole to mount.
  • Nightfall
    Nightfall Posts: 10,083
    The only non "cheated" time aligned Polks are the RTA-12's
    afterburnt wrote: »
    Village Idiot of Club Polk
    xschop Posts: 5,652
    Nice and substantial, I take it you don't need -6° stands for those either?
    How would those compare to the 11T's?
    xschop Posts: 5,652
    Much easier and cleaner. I'm going to wrap them in foam this time.
    Does it matter if the resistors are physically touching capacitors?
    xschop Posts: 5,652
    Found my old thread thru Duckduckgo lol.
    I'll post my progress here on this side project. Got an old set of these back with a blown tweeter, gouged cabinet and slight dent on the woofer. They were set up in a game room near a pool table.
    Herculiner works better than Rustoleum for sure...
    xschop Posts: 5,652
    Soldered in new tweeter leads...
    xschop Posts: 5,652
    This one I carefully sanded around baffle edge and added water putty to area that particle board got gouged. Luckily no metal was nicked. Rest of it looks good.
    xschop Posts: 5,652
    Cabs are done. I'll have to throw the other one together in the morning and have a listen. Only spare plugged 6502 I have on hand has the 8 hole mod and a carbon fiber one....
    Wonder what Mr. Polk would say @ what I do to his classics...
    pitdogg2 Posts: 27,538
    Bless your heart🖤
    xschop Posts: 5,652
    Really could care less what anyone thinks. Best sounding vintage midrange from these. Just gotta dial in the highs. Looks like this tweeter just needs an extra 0.5 ohm on the circuit.
    F1nut Posts: 52,138
    I like the look of the aluminum bezel. How thick is it?
    xschop Posts: 5,652
    edited March 22
    All of them were 5/8" 6061-T6. Think I stated it before. The KSi of the alloy versus the particle board is a huge difference.
    Got a couple 2 ohm resistors to swap out later this evening. It's really hard to say if its even needed.
    Amazing the bass these put out too with the extra air space and port size.
    WAF factor is a hit too and I like I dont have to build stands...bonus
    I'll let the forum decide. Billet face CRS+ this go round?
    xschop Posts: 5,652
    Tweeter burn-in is real. These things are smoothing out. They already have 2 ohms resistors on the tweeters.
    xschop Posts: 5,652
    edited March 24
    Made newer gaskets from 0.070" self-adhesive neoprene foam rubber material.
    Also will install 6" diameter sound absortive foam on top of X-overs as they sit right behind MWs in these models....
    And these drivers I put in already had @Gardenstater
    foam frame mod done to them as well...
    VR3 Posts: 29,626
    I think it looks great.
    Given the interaction I had with Matt Polk he would probably look at them and listen this talk to you about wine and coffee 😅
    xschop Posts: 5,652
    Well, we're cut from the same cloth then. I got more excited about the new 100% Angus burger place in my hood...
    VR3 Posts: 29,626
    He talked to us for about a hour or so and none of it was about audio lol
    xschop Posts: 5,652
    Installed the focus ringed and plugged mids from donors that @toolfan sent me a while back.
    Was on a Hiroshima binge late evening. These are the best sounding mids I've heard from all the Polks I've experienced including R200's.
    Found some cool stands too and set them up in guest bedroom to do critical listening....
  • Jeezus.
    Nice.
    [no more words]
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
    Toolfan66 Posts: 18,283
    I like it, a set of Billet Aluminum Monitor 7’s would be the shite IMO..
  • Looks really good.
    xschop Posts: 5,652
    Toolfan66 wrote: »
    When my XS-CRS are done, I'll let these go and fund the billet baffle 8TL upgrade.
    xschop Posts: 5,652
    My CRS+ will be here next week, so packing these up. I'll let them go for $500 if anyone here is interested. I'll split shipping for a fellow Polkie too. Just holler.
