You’re doing it wrong…
16667697172113
  • PSOVLSK
    PSOVLSK Posts: 5,390
    skipshot12 wrote: »
    What’s a kex?
    Answers to this could be gold.
    mhardy6647 Posts: 35,058
    kex is base 16, isn't it?
    B)
  • daddyjt
    daddyjt Posts: 3,088
    Someone from Kekistan…?
    ― Aleksandr Solzhenitsyn
    msg Posts: 10,452
    Bill W. and Will B. are both to be avoided.
    daddyjt wrote: »
    I think it is actually plural; i.e., one Kek, two Kex.
  • Jstas
    Jstas Posts: 14,985
    Keep it up! You doofuses are gonna say his name too many times and then he's gonna show up and you'll be sorry
    Expert Moron Extraordinaire
    treitz3 Posts: 20,017
    I already am.
    nooshinjohn Posts: 25,933
    Kexigeuise, Kexigeuise, Kexigeuise....
    VR3 Posts: 29,448
    Y'all should see the connector that Boulder amps require. It's HUGE!
    .....coming from a 15 amp C-13 that plugs into the wall. There are things in audio that one just cannot explain.
    In all fairness....The MF PS I have does the same daggum thing. C-13 at the wall, yet a C-19 at the input. Say what? Cray-cray, if you ask me....
    VR3 Posts: 29,448
    Looks like it's basically a stove cord? 32 amp so probably running a 50 Amp circuit?
    ....plugged into a normal 15 amp outlet....
    See what I mean?
    VR3 Posts: 29,448
    Ah ok, many amps that require 30 amps or more offer compromise versions that work on 15 and 20 amp circuits but they don't perform near as well and suffer at resale
    Here's my beef, Trey...
    If you are gonna build it? Well, freakin' BUILD IT!!!
    If something requires 30 amps? Well, make the plug that goes into the wall reflect that. Same daggum thing with a 20A amp. Who cares if it kills sales. This is already a niche hobby. The people who buy 30-50A amps? They are WELL beyond a C-13 (15A plug) and usually have dedicated circuits already installed in anticipation of said system (if the room wasn't already built specifically for it!)
    Just sayin'...
    VR3 Posts: 29,448
    Now to be fair, a 20amp cable using a 15 Amp c13, the plug itself is rated for many more amps than 15 so it doesn't make sense for manufactures to make a plug with a sideways pin
    pitdogg2 Posts: 27,079
    VR3 wrote: »
    Sure it does, If your product pulls 16-20amps you do not want that in a 15 amp circuit. On the other end I've seen fires from DYI'ers that will just switch out outlets and breakers to 20amp on 14ga romax wiring.
    billbillw Posts: 7,596
    Speaking of Butter...
    msg Posts: 10,452
    billbillw wrote: »
    After close to 70 pages, I can't remember whether this was posted before or not...
    treitz3 wrote: »
    similarly...
  • Geoff4rfc
    Geoff4rfc Posts: 2,855
    billbillw wrote: »
    Waaaaay too much slack in that chain, but I see he's running one of those newfangled steel belted radials. Dude is missing his air intake ducts (hole in the fairing under his left hand grip). Looks like an ex-race bike; frame sliders, access bolts for a rear jack stand, aftermarket rearsets....what a complete POS
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • daddyjt
    edited February 2025
    Geoff4rfc wrote: »
    billbillw wrote: »
    Not to mention he is using the floating rear suspension arm as a tie down for a power saw.
  • Geoff4rfc
    billbillw wrote: »
    Geoff4rfc wrote: »
    billbillw wrote: »
    RIGHT!!! What a noodle head. No doubt his tire looks like that from the abusive amounts of smoke shows he's tried to impress himself with.....those are guys we used to call squids.....dudes that think they are the top of the heap and the coolest thing since manscaping, but in reality, have absolutely no potential talent
    Set up:
