sda srs 2.3 modifications
13»
    F1nut Posts: 52,382
    edited October 2017
    Please for the love of God, it's RESISTOR.
  • Iamtheslime
    Ha - noted !
    pitdogg2 Posts: 27,884
    Resisters get beat about the head and neck by the po po B)
    Viking64 Posts: 7,805
    If Charlize Theron tried to get me in bed, I would not resisther.
  • Iamtheslime
    Sweet sound of success ! Received the custom Gimpod boards from David at DHS. These were a joy to work with, lots of space for everything. Most importantly, the upgraded XO's sound amazing. I've read in places that they require a break-in period, not sure if this is true, but in any event I honestly can't imagine them getting any better.
    Thanks all for the advice and patience with this. I'm really enjoying the 2.3's again !
  • westmassguy
    westmassguy Posts: 6,850
    glad they worked out. 200+ hours burn-in minimum.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • machone
    machone Posts: 1,586
    They will get better.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • RandyCroissant
    I was amazed at the improvement
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • Hergy
    Hergy Posts: 3
    Started my project on my 2.3 (non TL) many years ago. Completely stripped down the cabinets regaled all of my seams, glued all of the magnets on the drivers, Dynamatted the frames of all of the drivers, purchased all of the new circuitry including the lager more roomy circuit board and the back hole material. Then I came to a scratching halt! Between having someone in my ear telling me to have someone experienced do the mods and not being able to find the correct black galaxy granite for the top and bottom caps my project went on the back burner? Since then I have misplaced (lost) both my circuit board schematic and the placement guide for the back hole sound deadening material. Can anyone out there send me in the right direction for that circuit board diagram (and remember that it is the non TL earlier model)
    Thanks, Lost Tom hopefully not looser Tom!
    F1nut Posts: 52,382
    Never existed.
    Gimpod's site is no longer. Perhaps someone here that has done their 2.3's with his boards will see this and help you out.
    VR3 Posts: 29,731
  • cincycat13
  • cincycat13
    https://forum.polkaudio.com/discussion/118701/gimpod-sda-boards-for-2-3
    This was my build years ago. There is a jumper that is needed on the board that is easy to overlook
