sda srs 2.3 modifications
Please for the love of God, it's RESISTOR.
Resisters get beat about the head and neck by the po po
If Charlize Theron tried to get me in bed, I would not resisther.
Sweet sound of success ! Received the custom Gimpod boards from David at DHS. These were a joy to work with, lots of space for everything. Most importantly, the upgraded XO's sound amazing. I've read in places that they require a break-in period, not sure if this is true, but in any event I honestly can't imagine them getting any better.
Thanks all for the advice and patience with this. I'm really enjoying the 2.3's again ! -
glad they worked out. 200+ hours burn-in minimum.Home Theater/2 Channel:
dhsspeakerservice.com/ -
They will get better.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
I was amazed at the improvementYamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Started my project on my 2.3 (non TL) many years ago. Completely stripped down the cabinets regaled all of my seams, glued all of the magnets on the drivers, Dynamatted the frames of all of the drivers, purchased all of the new circuitry including the lager more roomy circuit board and the back hole material. Then I came to a scratching halt! Between having someone in my ear telling me to have someone experienced do the mods and not being able to find the correct black galaxy granite for the top and bottom caps my project went on the back burner? Since then I have misplaced (lost) both my circuit board schematic and the placement guide for the back hole sound deadening material. Can anyone out there send me in the right direction for that circuit board diagram (and remember that it is the non TL earlier model)
Thanks, Lost Tom hopefully not looser Tom! -
Never existed.not being able to find the correct black galaxy granite for the top and bottom caps
Gimpod's site is no longer. Perhaps someone here that has done their 2.3's with his boards will see this and help you out. -
Im on my phone but this may work possibly
https://web.archive.org/web/20211022192421/http://gimpod.com/partsp23tl.html#- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
https://forum.polkaudio.com/discussion/195747/gimpods-site-download
This is the thread with the gimpod site rar -
https://forum.polkaudio.com/discussion/118701/gimpod-sda-boards-for-2-3
This was my build years ago. There is a jumper that is needed on the board that is easy to overlook
