One can dream, can't they? - Audio Exotics
Deleted User wrote: »
Sproingggg -
Needs bigger meters on the amps... -
That rack is epic!
Probably uses it to watch The Wiggles on TV with his kids...Gustard X26 Pro DAC
WOW!!
That is how an attenuator should be built!
I believe they need thicker cables- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Well, its a nice start at least. Always room for mods...
no doubt. I guess he could slide them inside of pool noodles and then wrap the pool noodles in tech flex.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Needs more gold and rhodium....
Looks like an early generation Dalek—pre-plunger arm.The arc of the moral universe is long, but it bends towards justice.—Martin Luther King Jr.
Somewhere there is a cable company laughing all the way to the bank.Gustard X26 Pro DAC
That reminds me; Christmas is coming and I need to start working on the train garden.
I'm guessing that one of those speaker cables cost more than my entire system.Stan
Main 2ch:
HT:
Other stuff:
SeleniumFalcon wrote: »
No cable risers? Rookie!! -
Is everything completely reflected sound? Or am I missing something- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The speakers are the Harold Beverage model III speakers which are electrostatic speakers with a wave guide to create an extremely wide dispersion pattern. The designer, Harold Beverage, was an audiophile who was an expert on radar and used his knowledge of radio frequency antennas to model the guide. The original speaker used an output transfomerless tube amplifier connected directly from the output tube's plate to the electrostatic stator, no transformers at all. When a tube amplifier is connected to an electrostatic speaker the output tube's high impedance is stepped down by the output transformer. Then inside the speaker the incoming signal is stepped up to provide the stators high polarizing voltage (2,000 Volts in this case). Kind of like first making tea, then using the tea to make coffee; lots of changes happen. The Beverage amplifier was designed by Roger Modjeski, a true tube expert and was located in the bottom of the speaker. The speakers were intended to be placed on the two side walls facing each other. The stereo image would be suspended in the middle, eerily suspended actually. I remember hearing a Laurindo Alemeida direct-to-disc recording on Crystal Clear records with these speakers and the guitar was right in front of me. No kidding it was there, "know what I mean, Vern?"
The version in the photo is the model III, I believe which doesn't have the internal amplifier and can be powered externally. If anyone is interested there's a pair for sale in Baltimore:
https://www.facebook.com/marketplace/item/938120197677000?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp:6784a4f4-8baf-4214-8800-1fbc33cd80a6
Very cool, would be a fun demo!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I wouldn't mind hearing those, with the internal amp. Interesting design.
One of the best systems I’ve ever heard.
My friend’s Kharma system. Exotic cabling to boot.
Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
He definitely has some high dollar cables there. From Schnerzinger, Shunyata and AudioQuest, with what I can recognize. My question is this.....why are they just laying there, apparently just strung up over the back of a chair?
Never mind, I found out why. Apparently, he now has a full loom of Turnbull Audio cables. These were the ones he took out of the system.
I’ve had the pleasure of hearing the Turnbull cables in couple of different presentations. They are magical…2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Signature 21 w/Hana Umami Red, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
I would love to listen to a shootout between Turnbull and the new SRA Takshaka's someday.
Can someone tell me what the thing on the top right is? It looks like a fancy photo copier...Enjoying the journey while never attaining the destination.
Taiko Olympus and IO according to Google Lens search. Some over the top music server stuff from the WBF world.Can someone tell me what the thing on the top right is? It looks like a fancy photo copier...
It is basically a standard server put into a very fancy custom case with custom passive cooling and a custom linear power supply. Price is pushing €90k.
My current server cost me about $1000 to build including 32TB (4x8TB) of SAS drives, plus a spare drive. I use my server for more than just audio though. It hosts my entire movie collection and 20+ years of digital photos. -
Some additional reading on that particular model (Olympus) finds they also went to a proprietary digital connection called XDMI (are there any XDMI DACs yet?) and use battery packs to create the low noise power supply setup. It doesn't actually have the linear power supply that the original model had.It is basically a standard server put into a very fancy custom case with custom passive cooling and a custom linear power supply. Price is pushing €90K.
All that said, the Motherboard, CPU, DDR5 ECC Memory and Intel Optane storage that are the heart of this server would cost you less than $3000 from Microcenter...
A 24 core/48 thread CPU for a music server is so ridiculously over-powered...That is the type of system that is designed for very heavy multi-threaded operations like CAD rendering, video rendering, etc. Its roughly double the CPU capability of my desktop Intel 12th Gen i7 on multi-threaded, but very close on single threaded, which is most audio streaming operations.
Anyway, they are selling them as fast as they can build them apparently.
