You’re doing it wrong…
Stud conversion kits. Now available with or without nuts.
@WilliamM2 - the nuts in that photo appear to be straight out of Home Depot's bolt section....not what was pictured on the website you linked. If that is the case? The dudes a dumb a**.
They look just like these, acorn wheel lug nuts:
https://www.amazon.com/White-Knight-M12x1-5-Select-Factory/dp/B0D1LTQ69H?crid=2JX5JLA0FH37X&dib=eyJ2IjoiMSJ9.JtL_okQqysPVHyj2UAUaDMlGg3CvLenuadk1ib34Y_n5BWa6Ir67NTs7vp-G-iHo_1yb15HoqmcDDCZIILhJUlqRrJkjw8TYsivdftQIEHzPGpNjwqW_48gQTE5s8EOFM7dpdz6iLOzk3Mg6Kh7to1UwNg_jQ0qGETzO-LZeof3JMX5YhhNirJRi6BVUGT2tzLzFFWX76BY7Wp4thy4PBNYrC9aXB6rtZBCfQ2ZlvjnHeLLDZB__euOVbSPE24ss3359G16zzkX8h8WB-1Or1KvZZPP2T27JJZSDn0T1yOQ.hwYsHvk2-BvbItzObBTnGYMdZ0TSLCFi3DKz0kMKR8M&dib_tag=se&keywords=honda+Open+End+6-Point+lug+nuts&qid=1733291336&s=automotive&sprefix=honda+open+end+6-point+lug+nuts,automotive,96&sr=1-6
Found the original pic here:
https://www.s2ki.com/forums/s2000-modifications-parts-193/arp-extended-wheel-studs-matching-lug-nuts-978641/
nooshinjohn wrote: »Stud conversion kits… is that what happened to Bruce Jenner?
Yes, but it does come with a free oil change and lube.
Sal Palooza -
mrbigbluelight wrote: »nooshinjohn wrote: »Stud conversion kits… is that what happened to Bruce Jenner?
Comes with lots and lots of lube. If they run out head to Costco. Oh...wait, don't! they are all out of stock. -
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Believe it or not, there is nothing "wrong" with that setup. Supposedly the lugs are stronger, and they sell them for performance.
https://www.systemmotorsports.com/products/arp-m12x1-5-stud-conversion-kit-for-wrx-sti-gr86-brz-frs-gt86
Perhaps there's nothing *functionally* wrong, other than missing the valve cap.Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
― Aleksandr Solzhenitsyn -
Wind sail.
Might as well as get a trike, Mickey Mouse T-Shirt, sandals with black socks, and a subscription to Cosmopolitan magazine
🫣Sal Palooza -
That's definitely one way to get the magic smoke...
^^^^ Now I understand why I found bacon on the motherboard of one of my old computers.
Photo taken on Nov 1, 2024
I shudder at the thought. In my meager time with A/V, I've owned two receivers and two processors. My first AVR dispersed the magic blue smoke right before my eyes....you can never unsee that and hope you never see it again.....Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
I have only gotten it twice in my life. One with an 8 watt tube amp and the the other one knocked out 2 amplifiers that had JUST gotten back from service. A lightning strike was the cause for the second one....the system was on when it hit, so the electronics that were frying while the speakers were going?.....well, it amplified the system frying through the speakers.
That's a sound one never forgets.
Yeah, why weren't they consistent in their use of fractions and say 3 Laps was 1 1/5 Miles? Sheesh.
😉Brian -
Or metric to the thousandths place would be preferable.I disabled signatures.
Had to be ai- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Fun fact: the decimal equivalent of 1/23 is 0.0434782608695652173913, repeating.
Wild- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I've seen that in person. The look on the customers face when the cart gave up was priceless. -
Brian
