You’re doing it wrong…
1383941434474
    Viking64 Posts: 7,241
    There's a strap on/nuts joke in there somewhere.
  • sucks2beme
    sucks2beme Posts: 5,599
    He's going to break the rachel. With any luck, the strap will
    Snap back and it will scratch the door. I would almost pay
    To watch that.
    F1nut Posts: 51,015
    sucks2beme wrote: »
    To watch that.
    I don't think rachel will break, she's a tough girl. ;)
  • motorstereo
    motorstereo Posts: 2,185
    sucks2beme wrote: »
    To watch that.
    I bet he got the lug nut off with no damage. Put some tension on the ratchet and give it a good solid kick to finish it. Run what you brung if don't have what you need.
    This is nothing compared to what a resourceful paving crew can do with limited tools when there's a flat or other issue on the company truck headed home after a long day.
    mhardy6647 Posts: 34,184
    I keep a breaker bar and 19 mm socket in the "trunk".
    Stuff does, indeed, happen.
    I am still (relatively) strong.
  • sucks2beme
    OK, I have no idea how ratchet became Rachel. Best guess
    Is the typed t didn't take and it auto corrected. So much for
    Typing on small screens with thumbs.
    I keep a 24" breaker bar and an impact socket in both cars.
    Full size spares as well. I had a flat in the Mustang years ago
    and found a can of goo and a mini compressor instead of
    an idiot spare. Had to wait for a tow and to get a new tire
    Installed for hours. I keep a jump box in the trunk as well.
    Seems modern cars don't like jumper cables.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Toss in a can of AeroKroil
    for good measure to
  • motorstereo
    A heads up to those that are always prepared. Far more important than the breaker bar-right sized socket and Aerokroil is to make sure the key or special socket to unlock the locking lug is with you.
    nooshinjohn Posts: 25,552
    sucks2beme wrote: »
    OK, I have no idea how ratchet became Rachel..
    Perhaps with the help of WD40 and some duct tape? We shouldn’t judge..
    sucks2beme wrote: »
    I would like to know more about how Rachel became ratchet.
  • mrbigbluelight
    RE: Rachels/Ratchets
    I'm not touching that with a 10' pole. ,🤫
  • sucks2beme
    for good measure to
    In my part of the world, rust isn't much of an issue.
    I did pull the goofy anti-theft lug nuts off on the wife's car.
    But lately it seems like a bullet proof vest would be a good
    idea for highway driving around here. Welcome to modern
    America.
    Ratchet?
    No? Close, though.
  • motorstereo
    Ratchet; batch it; a smelly old ...........ahh nevermind banilla won't let it thru anyways.
    msg Posts: 10,450
    for good measure to
    Kroil's great stuff for easing old fasteners. An old machinist recommended it to me once.
    For anyone who works on their own stuff, a light coat of anti-sieze compound on the threads of all the wheel lugs is the real preventive for lug nut issues. Good to put a little on the wheel to lug nut interface as well.
    I was just going to ask why you guys are all using breaker bars instead of the supplied tire changing tools, but then I just remembered that I use a long ratchet for wheel work. Definitely more convenient. 4" extension, as well.
  • mrbigbluelight
    Also not mentioned but always proves useful is the excessive use of foul and profane language to the point that would make a sailor blush.
    Also works in getting them sammiches made in a more prompt and timely manner.
    Try it, you'll see the difference 👍
    msg Posts: 10,450
    msg wrote: »
    Dammit. Seize!
    context:
  • mrbigbluelight
    We need a "Fabulous" button 🤔
    Ab Fab
    msg Posts: 10,450
    Outrageous program.
  • CottageChz
    CottageChz Posts: 404
    Wow, that float switch is incredible
  • motorstereo
    CottageChz wrote: »
    The fellow was also thinking safety as that appears to be a GFCI box.
  • OleBoot
    OleBoot Posts: 2,927
    CottageChz wrote: »
    I'm rather impressed, actually.
    treitz3 Posts: 19,475
    Damn.
