Hey Ward, are those custom cabinets filled Altec horns/drivers or something else? -
I don't know but let's quote the photo again. Third times a charm. -
Normally, I do edit those out, but these are so pretty, why not keep it going?
I find it more annoying to see posts from certain forum members that have a signature that takes up half a page, or, a certain someone who doesn't seem to understand how to use the enter/return key and uses it after every line.
Haha. Yeah, good point about the wall of text signatures.
Altec 802-8G fitted on 511 horn, JBL 077 tweeter and JBL 2235H woofer -
I think you and my brother cruise the same horn/SET shopping channels. He's RadioX over at AK. -
@Wardsweb beautiful setup. Is that a Clearaudio tt with an SME arm?"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Clearaudio Champion II, SME 309 arm and Dynavector XV-1 cart. Also have a Benz Micro Glider as a backup. -
Wow...I kinda nailed that
Very nice!
Today, I turned it on and let it all warm up. Several hours later, it was clear that I would not hear even a single note played, so I dejectedly turned it all off.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »Today, I turned it on and let it all warm up. Several hours later, it was clear that I would not hear even a single note played, so I dejectedly turned it all off.
I understand- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So, I have been wanting to run a dedicated 20A 120v line to my amplifier for a while, but it's a nightmare to get wire pulled from my listening room (upstairs second floor) to the breaker panel in the basement. I had been planning to do this for at least a year, so knowing that I had a long weekend, I ordered everything to do this. The wire is something I found on Ebay. It's a 12-3 oxygen free copper, silver plated conductors, with Teflon insulation. The wire is aircraft rated and at 600v 200c, so 120v is a cake-walk for it. The termination is a hospital grade hanging receptacle, and a brand new 20A breaker at the panel. What I'm hearing is by far the greatest improvement I have heard from my system to date. Wow! I should have done this a long time ago!Enjoying the journey while never attaining the destination.
Congrats!
I hope you mean 12/2 with ground. 12/3 would have 4 conductors.
And plain Romex is also rated for 600v, just in case you didn't know. -
Did some reconfigured of the rig incoming power supply on the streaming portion of the rig. I lost the Richard Grey Power Supply and swapped it out with an AQ Niagara that has been sitting in a closet for what seems to be about a year or so ago.
This required that I change out one of the connectors on the SRA Cottonmouth from a 20 amp C-19 to a regular IEC connector. It also allowed me to move the Snubway to the outlet that feeds the AQ. That brings it closer to the power source, right before it powers the streaming portion of the system. After swapping everything out, I powered the system back on.
She is warming back up now.
@WilliamM2 what you said is true for Romex, but this is not Romex. It is 12-3 cable with Teflon insulation on all three stranded conductors and an overall Teflon jacket. It's similar to SOOW 12-3 cord than Romex, but much stiffer than SOOW.
DanEnjoying the journey while never attaining the destination. -
Dan
Okay but the question was, is it 12/3 with ground which would have two positive cables, neutral and ground. Are you calling it 12/3 because it has 3 12ga cables, positive, neutral and ground? -
Dan
Got a link? I've never used stranded wire to outlets, don't think I would trust the connections to screw terminals or wire nuts.
Does it meet code? -
Meets code here, it's all they use(stranded individual conductors) at work now. It pulls through conduit much easier than solid.@WilliamM2 what you said is true for Romex, but this is not Romex. It is 12-3 cable with Teflon insulation on all three stranded conductors and an overall Teflon jacket. It's similar to SOOW 12-3 cord than Romex, but much stiffer than SOOW.
Dan
Does it meet code?
@WilliamM2 the cable has three conductors. There's no bare copper wire, just three insulated conductors. There are no wire nuts in this run, and the hospital grade hanging receptacle is suitable for stranded conductors.Enjoying the journey while never attaining the destination.
Did you twist it? Some people twist it to help eliminate noise. Three separate conductors is actually the better way to go over romex style. -
That would be 12-2 with ground, no matter which jacket material it's made from. You just happen to have an insulated ground wire. -
I thought he was using individual conductors instead of a jacketed wire like Romex. -
Is there a link? I'd like to check it out. -
Congrats on your upgrade! 20a dedicated circuit is a must. -
Severe weather forecasted here for the next few days, so I unplugged everything.2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
https://www.ebay.com/itm/296124364484
This is what I used. I think they only have one 23 foot length remaining.Enjoying the journey while never attaining the destination. -
Looks like there's another.@WilliamM2 the cable has three conductors. There's no bare copper wire, just three insulated conductors. There are no wire nuts in this run, and the hospital grade hanging receptacle is suitable for stranded conductors.
I do not see in any of the descriptions about oxygen free. It does appear to be nice wire however.
https://www.ebay.com/itm/305372370403?
I can't see any markings/labels on the outer jacket of that wire, not even gauge? That would be a code violation here.
Not sure about the non standard wire colors. No green or black.
What made you go with a completely unknown wire? Safety first.
