1184185187189190200
  • Wardsweb
    Wardsweb Posts: 942
    newbie308 wrote: »
    @Wardsweb Wow! The wood on those speakers is really pretty! Nice rig!
    Thank you.
    billbillw Posts: 7,538
    Wardsweb wrote: »
    newbie308 wrote: »
    Thank you.
    Hey Ward, are those custom cabinets filled Altec horns/drivers or something else?
    Clipdat Posts: 13,095
    Wardsweb wrote: »
    newbie308 wrote: »
    Thank you.
    I don't know but let's quote the photo again. Third times a charm.
    Clipdat wrote: »
    Normally, I do edit those out, but these are so pretty, why not keep it going?
    I find it more annoying to see posts from certain forum members that have a signature that takes up half a page, or, a certain someone who doesn't seem to understand how to use the enter/return key and uses it after every line.
    Haha. Yeah, good point about the wall of text signatures.
  • Wardsweb
    Wardsweb Posts: 942
    billbillw wrote: »
    Altec 802-8G fitted on 511 horn, JBL 077 tweeter and JBL 2235H woofer
    edited July 2024
    Wardsweb wrote: »
    billbillw wrote: »
    I think you and my brother cruise the same horn/SET shopping channels. He's RadioX over at AK.
  • jdjohn
    jdjohn Posts: 3,356
    @Wardsweb beautiful setup. Is that a Clearaudio tt with an SME arm?
  • Wardsweb
    Wardsweb Posts: 942
    jdjohn wrote: »
    Clearaudio Champion II, SME 309 arm and Dynavector XV-1 cart. Also have a Benz Micro Glider as a backup.
  • jdjohn
    jdjohn Posts: 3,356
    Wow...I kinda nailed that :) Very nice! B)
    nooshinjohn Posts: 25,925
    Today, I turned it on and let it all warm up. Several hours later, it was clear that I would not hear even a single note played, so I dejectedly turned it all off.
    VR3 Posts: 29,427
    I understand
  • newbie308
    newbie308 Posts: 803
    So, I have been wanting to run a dedicated 20A 120v line to my amplifier for a while, but it's a nightmare to get wire pulled from my listening room (upstairs second floor) to the breaker panel in the basement. I had been planning to do this for at least a year, so knowing that I had a long weekend, I ordered everything to do this. The wire is something I found on Ebay. It's a 12-3 oxygen free copper, silver plated conductors, with Teflon insulation. The wire is aircraft rated and at 600v 200c, so 120v is a cake-walk for it. The termination is a hospital grade hanging receptacle, and a brand new 20A breaker at the panel. What I'm hearing is by far the greatest improvement I have heard from my system to date. Wow! I should have done this a long time ago!
  • WilliamM2
    WilliamM2 Posts: 4,807
    newbie308 wrote: »
    I hope you mean 12/2 with ground. 12/3 would have 4 conductors.
    And plain Romex is also rated for 600v, just in case you didn't know.
    treitz3 Posts: 19,992
    Did some reconfigured of the rig incoming power supply on the streaming portion of the rig. I lost the Richard Grey Power Supply and swapped it out with an AQ Niagara that has been sitting in a closet for what seems to be about a year or so ago.
    This required that I change out one of the connectors on the SRA Cottonmouth from a 20 amp C-19 to a regular IEC connector. It also allowed me to move the Snubway to the outlet that feeds the AQ. That brings it closer to the power source, right before it powers the streaming portion of the system. After swapping everything out, I powered the system back on.
    She is warming back up now.
  • newbie308
    @WilliamM2 what you said is true for Romex, but this is not Romex. It is 12-3 cable with Teflon insulation on all three stranded conductors and an overall Teflon jacket. It's similar to SOOW 12-3 cord than Romex, but much stiffer than SOOW.
    Dan
    pitdogg2 Posts: 27,047
    newbie308 wrote: »
    Dan
    Okay but the question was, is it 12/3 with ground which would have two positive cables, neutral and ground. Are you calling it 12/3 because it has 3 12ga cables, positive, neutral and ground?
  • WilliamM2
    newbie308 wrote: »
    Dan
    Got a link? I've never used stranded wire to outlets, don't think I would trust the connections to screw terminals or wire nuts.
    Does it meet code?
    edited July 2024
    WilliamM2 wrote: »
    newbie308 wrote: »
    Dan
    Does it meet code?
    Meets code here, it's all they use(stranded individual conductors) at work now. It pulls through conduit much easier than solid.
  • newbie308
    @WilliamM2 the cable has three conductors. There's no bare copper wire, just three insulated conductors. There are no wire nuts in this run, and the hospital grade hanging receptacle is suitable for stranded conductors.
  • invalid
    invalid Posts: 1,455
    edited July 2024
    newbie308 wrote: »
    Did you twist it? Some people twist it to help eliminate noise. Three separate conductors is actually the better way to go over romex style.
    edited July 2024
    newbie308 wrote: »
    That would be 12-2 with ground, no matter which jacket material it's made from. You just happen to have an insulated ground wire.
  • invalid
    newbie308 wrote: »
    I thought he was using individual conductors instead of a jacketed wire like Romex.
  • WilliamM2
    newbie308 wrote: »
    Is there a link? I'd like to check it out.
    newbie308 wrote: »
    Congrats on your upgrade! 20a dedicated circuit is a must.
  • HzTweaker
    HzTweaker Posts: 959
    Severe weather forecasted here for the next few days, so I unplugged everything.
  • newbie308
    WilliamM2 wrote: »
    newbie308 wrote: »
    https://www.ebay.com/itm/296124364484
    This is what I used. I think they only have one 23 foot length remaining.
    newbie308 wrote: »
    WilliamM2 wrote: »
    newbie308 wrote: »
    Looks like there's another.
    I do not see in any of the descriptions about oxygen free. It does appear to be nice wire however.
    https://www.ebay.com/itm/305372370403?
  • WilliamM2
    newbie308 wrote: »
    I can't see any markings/labels on the outer jacket of that wire, not even gauge? That would be a code violation here.
    Not sure about the non standard wire colors. No green or black.
    What made you go with a completely unknown wire? Safety first.
