You’re doing it wrong…
1383941434474
    There's a strap on/nuts joke in there somewhere.
    He's going to break the rachel. With any luck, the strap will
    Snap back and it will scratch the door. I would almost pay
    To watch that.
    sucks2beme wrote: »
    To watch that.
    I don't think rachel will break, she's a tough girl. ;)
    sucks2beme wrote: »
    To watch that.
    I bet he got the lug nut off with no damage. Put some tension on the ratchet and give it a good solid kick to finish it. Run what you brung if don't have what you need.
    This is nothing compared to what a resourceful paving crew can do with limited tools when there's a flat or other issue on the company truck headed home after a long day.
    I keep a breaker bar and 19 mm socket in the "trunk".
    Stuff does, indeed, happen.
    I am still (relatively) strong.
    OK, I have no idea how ratchet became Rachel. Best guess
    Is the typed t didn't take and it auto corrected. So much for
    Typing on small screens with thumbs.
    I keep a 24" breaker bar and an impact socket in both cars.
    Full size spares as well. I had a flat in the Mustang years ago
    and found a can of goo and a mini compressor instead of
    an idiot spare. Had to wait for a tow and to get a new tire
    Installed for hours. I keep a jump box in the trunk as well.
    Seems modern cars don't like jumper cables.
    Toss in a can of AeroKroil
    for good measure to
    A heads up to those that are always prepared. Far more important than the breaker bar-right sized socket and Aerokroil is to make sure the key or special socket to unlock the locking lug is with you.
    sucks2beme wrote: »
    OK, I have no idea how ratchet became Rachel..
    Perhaps with the help of WD40 and some duct tape? We shouldn’t judge..
    sucks2beme wrote: »
    I would like to know more about how Rachel became ratchet.
    RE: Rachels/Ratchets
    I'm not touching that with a 10' pole. ,🤫
    for good measure to
    In my part of the world, rust isn't much of an issue.
    I did pull the goofy anti-theft lug nuts off on the wife's car.
    But lately it seems like a bullet proof vest would be a good
    idea for highway driving around here. Welcome to modern
    America.
    Ratchet?
    No? Close, though.
    Ratchet; batch it; a smelly old ...........ahh nevermind banilla won't let it thru anyways.
    for good measure to
    Kroil's great stuff for easing old fasteners. An old machinist recommended it to me once.
    For anyone who works on their own stuff, a light coat of anti-sieze compound on the threads of all the wheel lugs is the real preventive for lug nut issues. Good to put a little on the wheel to lug nut interface as well.
    I was just going to ask why you guys are all using breaker bars instead of the supplied tire changing tools, but then I just remembered that I use a long ratchet for wheel work. Definitely more convenient. 4" extension, as well.
    Also not mentioned but always proves useful is the excessive use of foul and profane language to the point that would make a sailor blush.
    Also works in getting them sammiches made in a more prompt and timely manner.
    Try it, you'll see the difference 👍
    msg wrote: »
    Dammit. Seize!
    context:
    We need a "Fabulous" button 🤔
    Ab Fab
    Outrageous program.
    Wow, that float switch is incredible
    CottageChz wrote: »
    The fellow was also thinking safety as that appears to be a GFCI box.
    CottageChz wrote: »
    I'm rather impressed, actually.
    Damn.
Welcome!
Welcome!
