1180181183185186198
    VR3 Posts: 29,384
    I can smell your part, that sucks! Sorry to hear it. Happens to the best of us
    treitz3 Posts: 19,945
    Oh, chit! Sorry to hear that bro'. That bites.
  • CH46E
    CH46E Posts: 3,595
    $200 mistake. 😢
  • CH46E
    CH46E Posts: 3,595
    I pick up some new Monolith stand last week from a member here. Did not know he was a member here until the meet up.
    Thanks to @dorian (hope I got the right one there)
    These are much better than the wood stands I was using. Now I don't worry about my dog knocking them over.
  • gmcman
    gmcman Posts: 1,839
    edited April 2024
    I lowered the center shelf of the A/V stand.
    This is because I finally pulled the trigger on a PSA Directstream Mk1...need to make it fit. Factory Refurbished from TMR, been really going back and forth with either a preamp or DAC to take this setup a few more feet down the rabbit hole.
    I was debating a R2R, either the Pontus 2 or a Venus 2 but the DS with it's current pricing seems like a no brainer....have to finally get ears on one.
    Was scheduled to arrive monday, but I double checked today and it has moved to Sunday... B)
  • machone
    machone Posts: 1,551
    Switched from Tidal to Qobuz. Tidal no longer works with LMS/Picoreplayer or is beyond my understanding as how to make it work.
    So goodbye Tidal.
    To my delight I can confirm without a doubt that Qobuz sound quality is better.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    billbillw Posts: 7,446
    CH46E wrote: »
    Have you mass loaded them yet? I have the same set. I filled all the legs with aquarium gravel. It was tedious, but probably took no more than an hour to do both. It helped to take the ring away from the legs (if you tap them). Just a dead thunk now. It has to help, right?
  • CH46E
    CH46E Posts: 3,595
    billbillw wrote: »
    CH46E wrote: »
    They are filled with sand. Not sure what kind. There were filled before I picked them up. They are pretty heavy
    pitdogg2 Posts: 26,922
    Beautiful table, I've always admired those.
  • tratliff
    tratliff Posts: 1,762
    The DP-59L is a very nice table. I also have one of the American versions.
  • skipshot12
    skipshot12 Posts: 1,775
    I have a Sony PS-x75.
    It’s close to the same as a Denon DP-47f me thinks.
    Servo tonearm, full auto along with record size and speed detection.
  • xsmi
    xsmi Posts: 1,801
    tratliff wrote: »
    Do you still use the built-in RCA cables or have you switched it to RCA jacks?
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • tratliff
    xsmi wrote: »
    tratliff wrote: »
    Mine has the original. Would like to upgrade it but I don't use the table much. Its my secondary table and not even hooked up currently.
  • xsmi
    xsmi Posts: 1,801
    It'll be my secondary as well. As soon as I get my pre-amp up and running I will be hooking it up.
  • tratliff
    xsmi wrote: »
    I like the semi automatic functionality of it. When I am not paying as close of attention as normal I don't have to worry about getting the tonearm at the end of a side.
    Also, I have a MM cart on it and a MC on my other table. My phono pre has 2 inputs and I can flip back a forth.
  • invalid
    invalid Posts: 1,441
    Are those kt150's?
    edited May 2024
    So what is that a little 100 watt tube amp?
    That's pretty BA!
  • invalid
    It's actually a hybrid, the kt150's are driving a mosfet output stage.
  • Wardsweb
    Wardsweb Posts: 942
    I got a Hickok 6000A tube tester
  • JCL
    JCL Posts: 168
    Picked up the matching Musical Fidelity preamp today for the 2.3’s. Just need to upgrade the cables and some of the source components now.
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • gmcman
    gmcman Posts: 1,839
    Two things here....I have been spending time with the recently acquired Directstream DAC, so far it definitely sounds better than the DAC in the Marantz SA8005. Vocals are very well reproduced, midrange is cleaner, overall it might be a keeper. Still need more time with it, need to test the I2S input.
    Secondly, with that going on, I have been debating on purging some components, I have a vintage stack of Yamaha gear, CX-1000, MX-1000, and the TX-1000 tuner. I haven't turned on the amp in about 3 years, so I wanted to make sure all works.
    Last time I listened to it, I was comparing it to the McCormack DNA-1 I had upgraded back in 2018....the DNA had a bit more soul so the MX was just taking a break.
    Tonight, I am running the SA-8005 into the Directstream, then McCormack RLD-1 to the Yamaha.
    Well.....my thoughts have changed now....lol. The MX-1000 with a nice clean signal sounds really good, and that's with no warmup time. Granted it has some age on it, I don't think it would dethrone the DNA, but I'm impressed given it's age. The previous owner didn't use it much, I think he was the original owner. Now it's a tough call, it drives the SDA's nicely.
  • rainbow1919
    rainbow1919 Posts: 12
    I have a big board that ends with a Line 6 Stomp, so I can set it up to run stereo amp sims, two real amps in stereo, or even one real amp and one amp sim direct to a mixer / recording interface. At home I have 3 amps to choose from: PRS Archon 50 with a 2x12" cab, a Fender DRRI, and a Vox AC15. I mostly use the Fender DRRI and Vox in stereo these days, if I'm not practicing with amp sims through my studio monitors.
    SCompRacer Posts: 9,078
    Wardsweb wrote: »
    Nice!
    This is what it looks like if you have to replace a well worn 9 pin socket in one. :o Some folks use socket savers in the high use sockets.
    Yes socket savers are a godsend. Be sure to get a good one, too many cheap Chinese junk socket savers out there.
  • newbie308
    newbie308 Posts: 800
    Keep in mind that most cartridges go through a break in period. The suspension and stylus go through micro changes as they are played. Expect the sound to improve after the first 20 to 30 hours of use. There's probably some wire break in with the coil wires, too. Like you would have with a new cable.
  • gmcman
    gmcman Posts: 1,839
    The Oppomod I2S card arrived today for the 103D. Going to try this option to feed the Directstream. I wish the Marantz had this feature, bit will obviously need to use the Oppo as the transport if all works out. So far the Directstream has been sounding very good but I need to exploit this feature before I can give it a final verdict.
