Anyone own a Krell 2250 or 3250?
After putting the new tubes in the Anthem pre amp, I'm very happy with it. I decided to purchase a Schiit Lokius 6 band eq. The only thing i don't like on the Anthem is a lack of tone controls. I just want to be able to adjust (TO MY LIKING) recordings I find lacking in some areas of the spectrum. Like bass and or treble. Should have it in a few days. I also need to get this new stylus installed so I can start playing records again.
Anyone else using a Schiit eq? -
Played with the system a little bit tonight. So far I'm happy with the results.
A little before and after some silver cleaner wipes. Now I have to find a screw driver small enough to open the battery packs. 😡
I thought the packs used AAA, but they use something different.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
They use "123" batteries. -
Correction!! They use 23A 12v batteries. Not 123 3v. Sheesh. -
I will do that and report back! Lol. That was great!!
For the record, I dont hear a damn bit of difference with the batteries in vs out. 😢
