Anyone own a Krell 2250 or 3250?
12346»
  • CH46E
    After putting the new tubes in the Anthem pre amp, I'm very happy with it. I decided to purchase a Schiit Lokius 6 band eq. The only thing i don't like on the Anthem is a lack of tone controls. I just want to be able to adjust (TO MY LIKING) recordings I find lacking in some areas of the spectrum. Like bass and or treble. Should have it in a few days. I also need to get this new stylus installed so I can start playing records again.
    Anyone else using a Schiit eq?
  • CH46E
    Played with the system a little bit tonight. So far I'm happy with the results.
  • CH46E
    edited April 2024
    A little before and after some silver cleaner wipes. Now I have to find a screw driver small enough to open the battery packs. 😡
  • Joey_V
    I thought the packs used AAA, but they use something different.
  • CH46E
    Joey_V wrote: »
    They use "123" batteries.
  • CH46E
    CH46E wrote: »
    Joey_V wrote: »
    Correction!! They use 23A 12v batteries. Not 123 3v. Sheesh.
  • CH46E
    msg wrote: »
    I will do that and report back! Lol. That was great!!
    For the record, I dont hear a damn bit of difference with the batteries in vs out. 😢
