Anyone own a Krell 2250 or 3250?
After putting the new tubes in the Anthem pre amp, I'm very happy with it. I decided to purchase a Schiit Lokius 6 band eq. The only thing i don't like on the Anthem is a lack of tone controls. I just want to be able to adjust (TO MY LIKING) recordings I find lacking in some areas of the spectrum. Like bass and or treble. Should have it in a few days. I also need to get this new stylus installed so I can start playing records again.
Anyone else using a Schiit eq? -
Played with the system a little bit tonight. So far I'm happy with the results.
A little before and after some silver cleaner wipes. Now I have to find a screw driver small enough to open the battery packs. 😡
I thought the packs used AAA, but they use something different.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
They use "123" batteries. -
I will do that and report back! Lol. That was great!!
For the record, I dont hear a damn bit of difference with the batteries in vs out. 😢
https://youtu.be/od1WdSLQwe8?si=HLbtxoGcxRD82coF
