1178179181183184198
    nooshinjohn Posts: 25,875
    audioluvr wrote: »
    How many friggen times do we have to post pictures of your stupid amps!!!
    As many times as I damn well please, when and where I feel like it.
    treitz3 Posts: 19,942
    Spoken like a true Marine.
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    edited March 2024
    I wouldn't say fabulous........uh, tube-ulous????
    DAMMIT John, you got me looking in places I have no place being......Hey, LOOK, it's ELVIS..(snatches the C2300 and runs).....
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • CH46E
    CH46E Posts: 3,595
    treitz3 wrote: »
    Finally broke down and ordered some acoustical treatment for the room. Hopefully, it's worth the investment. Ceiling, 1st reflection points and behind the listening position. I figure that's a good start to see what they can actually do.
    The panels I got are a combo of diffusion and absorption, so I don't deaden the sound too much....which is a fear of mine. We shall see...
    Currently listening to anything that is on my list, switching to physical music every once in a while.
    I also have Jonny working on building another custom cable for me. This one he normally doesn't sell but I would like to try out something. Hopefully, it will work out. Based on prior experience with his other offerings? I think I'll be a happy camper.
    I'm just happy to not be working. Looking forward to the weekend!
    I traded my Polk SDA SRS 2's to a guy that came in with a PC and mic then set up the entire room with some panels. (I had tile floors) I already had purchased the bass traps. But man was it worth it. Cleaned up the sound big time. Before the treatments a hand clap in the room resonated for what seemed like a full second. After it was a clap and then instant nothing. Although the room was not totally dead. Bass really came alive and sharpened up. Imaging improved drastically . It was probably the single best upgrade Ive ever done. I wish my new home had a dedicated listening room. Unfortunately it does not and my equipment is in the living room. I still have some nice panels I may be able to put up with out getting a frown from the wife. Although, she will let me pretty much do what I want. I just want to be considerate.
    I'm still reading through the thread, but I hope you really enjoy the treatments.
  • gmcman
    gmcman Posts: 1,839
    edited March 2024
    Been away from the 2CH rig for a few months, but after a few tracks I started hearing some "artifacts" for lack of better terms. Sometimes a "double sound" in the left speaker, like a mirror image of the right but in small increments.
    I was thinking it might be the dimensional circuit unable to fully cancel a signal at times. After a few weeks I wanted to poke around while on vacation and see if I could possibly kickstart any upgrade ideas.... B) .
    I can clearly hear the speakers go to "normal 2CH" with the IC removed, then back to being dimensional with it connected...but I opened up the left speaker today and removed the crossover. All looked good until I lightly tugged on some leads.
    Big coil lead somehow came loose, I obviously botched that solder connection. It was snug enough to make contact, but it pretty much fell right out.
    Been also debating re-wiring the tweeter header to some type of copper connection as those pins are phosphor bronze. The 4 and 5 pin header are avail in a copper alloy but not the 6-pin.
    All my current headers are bronze but the gear sounds good at the moment.
    pitdogg2 Posts: 26,922
    Did you crimp AND solder those connections? I always do.
  • gmcman
    gmcman Posts: 1,839
    I did not.
    The leads are Cardas Litz so I had to tin the ends in a solder pot to melt the coating, this somewhat keeps them from forming in a crimp. Generally I never have an issue with a soldered connection but this time was different.
    For the time being I went ahead and removed the connections and soldered the leads directly to the tabs.
    Gotcha, that makes sense.
  • gmcman
    gmcman Posts: 1,839
    I ordered a few parts to modify my crossover upgrade to the 2.3 TL's. When I assembled Gimpods boards I didn't pay too much attention to the materials in the header sockets and pins I ordered. May not make much if any difference, but worth a try.
    My current 4,5 & 6 pin headers are
    tinned, phosphor bronze pins with tin pins on the speaker wire harness. I am going to try the copper alloy headers with tinned copper pins for the speaker harness.
    Only issue is there isn't an option for a 6-pin header in copper alloy, so I may just use copper male/female pins under heat shrink bypassing the 6-pin header socket.
    Always fun to tinker, will definitely report my findings.
    VR3 Posts: 29,384
    If you plan to keep them installed forever... Would be a pita but you could just directly solder the wiring to the board if it was that much of a concern
  • gmcman
    gmcman Posts: 1,839
    VR3 wrote: »
    I hear ya, and really the only next step would possibly be point to point wiring but it would surely be a pita to remove if needed but not terribly so.
    The only part that bothers me, is not knowing....so it's worth the labor. Solder wick makes very quick work of removing PCB components..... B)
    Got a little sumphin' delivered today.
  • bcwsrt
    bcwsrt Posts: 2,362
    Nice! Once you do the first one or two, it's pretty easy to hang the rest and keep them all level. Ceiling ones are a little more work, but the brackets help. A laser "tape" measure comes in handy, too.
    These are GIK, right?
    Look forward to your impressions!
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
    Yup. Just got done opening the first box and setting it up as a floorstander. They look great! Only issue is the one I just built was damaged in shipping (but I think it really slipped by QC because the box on both sides in that area were in perfect shape).
    These first two are part of the Impressions Series, 6".
  • Jetmaker737
    Jetmaker737 Posts: 1,103
    Is that the walnut veneer? That looks so much better than it does on their website.
    Yes, it is. I wouldn't exactly call it "veneer" though. It's barely even 1/2 a MM thick. Still, it does look nice. The other 3 came today but I won't be able to hang the ones for the ceiling until the support hangers come in. They are on BO right now.
    In the meantime, I can experiment with them simply placed in different areas of the room, just to see how they change things.
    FWIW, they do look much better in person than they do on their website. I almost didn't order the Walnut because of the photos they have on the website. They don't really do them justice at all.
  • bcwsrt
    bcwsrt Posts: 2,362
    edited March 2024
    What the heck?! They were on back order when I got mine a year ago, too! Freakin’ simple bracket to be so hard to get all the time! Never could get a good date when to expect them, either. They just showed up out of the blue about six weeks after the panels did.
    Frustrating as all get out! Hope you don’t have as long a wait.
    Brian
    Duly noted and thanks man. I am done with adult chores, so back to experimenting and listening to some good tunes.
    I can't wait to hear what the one behind me does, seeing as my head sits about a foot or so from the back wall. It's a 1x4 Impressions series diffuser/absorber.
    Time to go have some audio fun!
  • CH46E
    CH46E Posts: 3,595
    Wow, those are next level man. Look incredible!
  • Geoff4rfc
    treitz3 wrote: »
    LOVE the CD rack
  • gmcman
    gmcman Posts: 1,839
    Crossover parts arrived today, I want to experiment with changing out my tin pins to tinned copper, as well as the 4 and 5 pin header from phosphor bronze to copper alloy.
    New copper pin on right, tin on left
    Tin on bottom, male and female copper above.
    No 6-pin tweeter header avail in copper, so I may just use the male and female under heatshrink.
    The copper looks a bit bigger, how do you plan on crimping that down on the wire? Where did you pick them up and stock number would be cool...
  • Gardenstater
    Gardenstater Posts: 4,725
    To me, "copper alloy" could mean anything from brass to bronze to tellurium copper. Too vague for me.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    Well we all can't be as drool cool as you George.
  • Gardenstater
    Ahh you misunderstood me Ivan. I see many sellers, especially Chinese, using that "copper alloy" and it is a pet peave of mine. Not criticizing gmcman in the least.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • gmcman
    gmcman Posts: 1,839
    I think the angle of the pic is making it look larger than it is, I will solder the pin then close the tabs.
    My original female pins that are tin are Mouser P/N 571-3505501
    New copper female pins are Mouser P/N 51-926901-3
    New copper male pins are Mouser P/N 571926900-3
    The new copper alloy header does not have a split opening so it cannot apply tension to the pins so this might be a no go.
    I was thinking the same, could be just an expensive way of selling a piece of bronze, but I feel the material has a fair bit of copper in it. Either way, the header pins are solid and not split so it barely has tension. I will still change the pins on the harness to the copper on the input and I have enough length on the new internal wiring to possibly allow me to solder to the board.
  • Gardenstater
    edited April 2024
    I checked out the datasheets and they are saying those female and male pins are actually made out of CuSn4, which is phosphor bronze. BUT the datasheet ALSO says the contact zone is supposed to be 0.8um gold plated over nickel?
    Beryllium Copper is probably the best material for spring contacts as far as I've been able to determine so far:
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • gmcman
    gmcman Posts: 1,839
    Interesting find, I see that the copper content states "remains" possibly signifying the remaining 90+% of materials?
    Haven't looked up my original tin pins, but the new ones are tinned copper so could explain the data sheet.
    Given the added length of internal leads I may scrap this idea and remove the headers and solder all the leads to the board. I don't have any plans to remove the crossover unless I upgrade the large inductor.
  • Gardenstater
    edited April 2024
    Datasheet just linked to a Tyco catalog. Old ones were brass with tin plating. Unspecified brass alloy
    Brass has pretty good electrical conductivity (better than phosphor bronze) but not as good for keeping a tight grip in a spring contact(?):
    Post edited by Gardenstater on
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • gmcman
    gmcman Posts: 1,839
    I decided to solder the crossover harness to the pcb.
    Thanks Trey @VR3 for giving me the push to do this. I wanted to for awhile but just wasn't ready to commit, I have no plans to remove the crossover anytime soon but removing will be easier than this was.
    It was a pita for sure, but once I had it setup, it went somewhat quick, the Panavise was definitely a huge help.
    To answer a couple possible questions, the Erse in the background was/is for A/B testing, and the .5 ohm Path resistor is mounted under the pcb.
    I figure with the labor involved in fabricating the Cardas Litz harness, it's worth the try to take 3 connection points of bronze and tin down to 1, including removing a friction fit, the speaker tabs were soldered as well when I installed the harness.
    One down, one to go.
