1176177179181182208
  • bcwsrt
    bcwsrt Posts: 2,672
    I thought there was a possibility it could just as easily sound like crap to me since my auditory memory had been totally erased and reset in that amount of time. I was pleasantly surprised.
    Brian
  • Jetmaker737
    Jetmaker737 Posts: 1,146
    I did a couple of things. I have a difficult room. I moved my speakers further apart. Even though the placement looks wonky in the photo the diagram shows that it's correct for my listening position. Also noticeable in the first pic are some GIK panels I placed in front of the fireplace behind the rack. The results are good. Much better soundstage and imaging with the speakers at nearly an equilateral triangle. The GIK panels have knocked down some of the reverb and high frequency energy in the room. I am considering more panels now. Also, I have placed an order for a REL T/9x Red subwoofer as my room tends to attenuate the bass.
    This is the new setup:
    Diagram:
    Old setup:
    VR3 Posts: 29,729
    nice woofers in those speakers
    pitdogg2 Posts: 27,876
    LOVE the Sansui tuner !! I tried and tried to buy one, it just didn't happen for me.
  • bcwsrt
    bcwsrt Posts: 2,672
    Damn fireplace. I'm curious what the GIK folks recommend for your space? The open entryway on the left should be to your benefit to reduce reflections, but the glass table and window behind your sweet spot are likely problematic for the high frequency issues you mentioned.
    Definitely a difficult room, but you are on it with the GIK and REL additions. Keep us posted! That T/9x Red is a beauty!
    Brian
  • Jetmaker737
    edited February 2024
    bcwsrt wrote: »
    The GIK advice I got was not stellar. They recommended I buy 12 24x48 inch 244 panels and distribute about the room. I sent them that diagram above plus many photos which when studied would clearly indicate that a dozen of those panels is not an option. I also told them I only had 3" max available behind the rack where 244's would not fit. So I will piecemeal it and do the best I can.
    I may move the glass table but the hippos are cast bronze and very heavy so I've procrastinated.
    Any recommendations on room measurement apps/mics?
    That TU-9900 tuner is a special piece. I bought it in August, 2011 from Club Polk member @starkiller. It came with original box and manual. In 2018 I had it thoroughly upgraded by Joseph Chow. It's hooked up to a directional antenna up in the attic. Sounds very good!
  • bcwsrt
    bcwsrt Posts: 2,672
    That is similar to my experience with them, which was why I wondered. They recommended about 2x the panels that I could ever find room for. They make a good product, but I adopted the same approach as you ... piecemeal it ... which has worked out fine for me. I have a combination of 244s on the side walls and 242s on the ceiling.
    I've not measured my room with any accuracy, but the Decibel X iPhone app (which has a spectrum analyzer) has been helpful in identifying obvious areas for opportunity, as well as results from the changes I've made.
    Nice to see some discussion on room treatments!
    Brian
  • jdjohn
    jdjohn Posts: 3,437
    Coda 06x phono preamp:
  • newbie308
    What cartridge are you running with it? Wow! Nice phono stage!
  • jdjohn
    jdjohn Posts: 3,437
    Thanks! I got it at a steal. Based on the internal load settings that were in place in this unit, I'm not sure the previous owner was using it correctly, so maybe he was frustrated with the sound, and just decided to dump it. That's pretty sad, if true.
    Last night, the cartridge I was using is basically a Nagaoka MP-200. Technically, it is a Well Tempered Lab TLC MM cartridge, but it is really just a re-branded Nagaoka. Eventually, I'll incorporate a nicer MC cartridge from my stable of carts.
    I've only listened via headphones so far, but really liked what I was hearing! I just wanted to test functionality, and not adulterate my setup while demoing the Snake River amp cord B)
    Coda, IIRC made some fantastic gear for Legacy Audio I used to salivate over.
  • engie490
    engie490 Posts: 447
    Coda also made the electronics for Innersound and Sanders. The latter did spec a few things differently than Coda. For example, Innersound's ESL amp is basically the Coda Continuum Stage amp, but with different binding posts and balanced input impedance. Coda's balanced input impedance ran at 1Kohms, which is unusually low, vice 100K for the Innersound version.
    I have the Innersound phono preamp, which is essentially the Coda FET-03p with a different faceplate. Looks similar to the innards of the FET-06X above. Very nice performer!
    KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
    treitz3 Posts: 20,346
    Are there dip switches to adjust it?
  • jdjohn
    jdjohn Posts: 3,437
    Yes, Tom. In my pic, on the left side, the red strip boxes with white rocker switches (one is partially hidden) are where capacitance and impedance are set. You can even see the legend/guide in gold lettering for the settings on the inner side of the case/chassis. There are also a few slide switches for gain, balanced/unbalanced.
    Oh, my. I completely missed that. Hard to see on the phone when you don't blow up the photo.
    SCompRacer Posts: 9,377
    I had the Innersound Phono stage made by Coda. Mine had a noise issue. Easy fix, they missed soldering the ground to the PCB.
    EDIT: Coda makes excellent gear. Some folks were bothered by the fact they rebadged gear for others, like InnerSound.
    When I had Innersound ESL's, I had the Innersound/Coda panel amp and the bass amp with the active crossover in it. To make room for components, they removed two pairs of the big filtering caps. I fixed that too.
    Active xover bass amp same design as panel amp, just with active xover. They removed four large filter caps to make room for the active components.
    Panel amp, it had 8 filter caps.
    VR3 Posts: 29,729
    Love the color
  • bcwsrt
    bcwsrt Posts: 2,672
    Brian
    nooshinjohn Posts: 26,135
    edited March 2024
    @Clipdat… how do you like the Michi preamp?
    Clipdat Posts: 13,104
    edited March 2024
    The Michi X3 is an integrated amplifier which has a pre-out, so I'm basically just using it as a preamp currently.
    I don't have first hand experience with the Michi P5 preamp, but my experience with the X3 has been very positive, so much so that I would not hesitate to recommend any of the Michi components. They are a great value for the level of performance they provide, imo.
    (FWIW I don't use the X3's built in DAC. I believe the quality of the DAC is the same between the X3 and P5. Like most integrateds/preamps with built-in DACs, the measurements aren't quite as good as what you would likely get with a standalone unit.)
    edited March 2024
    Today I crossed into the Blue... my new to me Mcintosh 2300. This is the first preamp I have tried that pushes beyond that performance wall I kept running into with my L800's. This preamp is very affordable on the used market and is absolutely stunning. More to come later as this has only been running for 30 minutes, but already is blowing my mind.
    Once you go Mac you don't go back!
    Clipdat wrote: »
    You might be right about that. This is easily the best sound I have ever heard in my room. Pass Labs is not even close.
  • bcwsrt
    bcwsrt Posts: 2,672
    Brian
    The Mac just gets better and better.
  • motorstereo
    motorstereo Posts: 2,422
    It's nice when things work out like that. Is this your first Mcintosh piece?
    No, I had an MS750, but it was a real boat anchor as that is one of the rare pieces McIntosh no longer supports.
