1000 VA Dreadnought
  • westmassguy
    westmassguy Posts: 6,850
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    xschop Posts: 5,682
    Must be for Faraday cage effect. Looks great.
  • stangman67
    stangman67 Posts: 2,330
    VR3 wrote: »
    I lined ptroopers enclosure in copper foil as per his request
    But did you put the whole thing in a Faraday cage? You know to block 5G warfare?
  • Sitka
    Sitka Posts: 77
    Thanks guys - FYI, coming soon I'll be posting results of my head to head apples to apples comparison of SDA 2B vs RTA 12B. The 2B is in burn-in, and to be fair it needs a Dreadnought.
    Thanks westmassguy for the excellent pics, although it's unclear if the 8 zip ties are part of the hold-down for the coil, or if the bolt somehow holds it in place. It is clear that I should not use the included steel plate or steel bolt. Pics to come when I get my aluminum box.
    pitdogg2 Posts: 27,663
    Most of used stainless steel hardware to hold the torrid to the enclosure. I do not think Dave's zip ties are holding the torrid to the enclosure. I thought I remember @westmassguy (Dave) using copper foil on the enclosure.
  • westmassguy
    The enclosure is cast aluminum, good for RF shielding. I applied 2 coats etching primer and two top coats on the interior, then full copper foil for EMI shielding, followed by the Dynamat. The Toroid is mounted to a 1/2" MDF disk using either 80 or 120 lb wire ties. A single Stainless 1/4-20 through bolt holds the assembly to the back wall, and is also glued down.
    xschop Posts: 5,682
    Ok. Thanks for those pics. I was thinking a 1/4" alloy disk like that on top with a sheet of neoprene in between and non-ferrous stainless bolt.
    Will be ringing Avel this week.
    xschop Posts: 5,682
    While waiting on reply from sales@avellindberg.com, positing a question before I forget. Looked everywhere and can't find a definitive schematic for dreadnought, but from the replies figured how to wire to PIN/BLADE when time comes.
    The real question is if the Dreadnaught is still wired the same for the dual-board BLADE/BLADE models?
    I will always be on the lookout for a set of Blade/Blade SDA 1A's to mod if they ever appear locally.
  • Sitka
    Sitka Posts: 77
    Thanks @westmassguy - that really helps! Pics to come when this comes together.
  • Schurkey
    Schurkey Posts: 2,122
    xschop wrote: »
    SDA 1, SDA 1 Signature, SDA 1A, SDA 1B CANNOT USE AN ISOLATION TRANSFORMER in the SDA cable.
    That is, I put an isolation transformer into the cable on my 1Bs, after reworking the internal circuitry to make that possible...but it sounded bad. For all practical purposes, it can't be done.
    The only blade/blade speakers that can use the isolation transformer are the few SDA 2B and 1C that were equipped with blade/blade sockets. Polk has a serial-number list of those speakers. The internal circuitry is compatible, but they're missing a foot of wire and the correct pin-blade sockets.
    edited January 2024
    I'll also add the two tweeter dual blade socket CRS and MAYBE the first CRS+ if it has the two XO boards.
    xschop Posts: 5,682
    Hmmm. Very interesting and thank you for expounding. I don't recall seeing that info here. So I'll just wire this up with Neutriks then, and just machine 2 spots on the case. I will have to drop in CRS+ crossovers and experiment on the 1A's. 2ea 6502's in series for the stereo drivers and 2ea 6503's in parallel for the SDA circuits. B)
    edited January 2024
  • Schurkey
    He was specifically asking about SDA 1-series speakers.
    The SDA SRS 2 blade/blade (electrically almost identical to SDA 1B) is not compatible. Essentially any generation of speakers older than SDA 1C, 2B, SRS 1.2, (and I have never learned the chronology of the CRS units) is not compatible with an isolation transformer.
    Only the models that (when not using an isolation transformer) use a single powered conductor in the SDA cable to connect the SDA circuit on the two cabinets are compatible with an isolation transformer.
    xschop Posts: 5,682
    edited January 2024
    TB1 plug adapter?
    The large copper donut is now inbound. :)
    edited January 2024
    xschop wrote: »
    TB1 plug adapter?
    Plug adapter is for those speakers that came with the B/b socket that were wired like the Pin/blade socket. That is why the serial numbers were also included. it is a Blade/blade plug that plugs into the speaker then the Pin/blade AI-1 plugs into the end of the adapter.
  • Schurkey
    edited January 2024
    xschop wrote: »
    TB1 plug adapter?
    I'm thinking that there is also 8 inches or a foot of wire that goes from one side of the original blade/blade socket, to the negative speaker binding post on those speakers that need the plug adapter. A length of wire needed for each speaker cabinet, so two short pieces of wire, perhaps Polk supplied the appropriate ends on the wire for easy connection.
    I don't know why Polk installed the "wrong" SDA sockets on some SDA-1C and 2B speakers. The best guess I've heard is that they had a bunch of those "obsolete" blade/blade sockets left over from the previous generation of speakers, and figured that it was cheaper to use 'em up, if purchasers complained about not being able to put an isolation transformer in the SDA cable, they could send out a relatively small number of upgrade kits to the few customers that cared. But I've never heard that "officially".
    Toolfan66 Posts: 18,320
    edited January 2024
  • Schurkey
    edited January 2024
    THANK YOU for that. VERY much appreciated.
    I knew there was a wire going to the negative speaker terminal in there somewhere. I thought it would be inside the cabinet instead of outside. Silly me.
    What's funny--or evidence of my senility--is that I've seen those photos before, and even commented in the other thread. I remind me more of my Dear Old Dad as time goes by.
  • 70hemicuda
    Just got my 800 today. Still waiting on the box and other parts. Is heat a concern with these? I bought a plastic electronics enclosure and also got a vent I can cut in. Wasn't sure if these produce alot of heat.
    70hemicuda wrote: »
    They produce no heat, and trade in your plastic enclosure for an aluminum one..
    F1nut Posts: 52,227
    70hemicuda wrote: »
    No vents required.
  • 70hemicuda
    Toolfan66 wrote: »
    70hemicuda wrote: »
    This enclosure was $20 on amazon, going to use it for version 1. The plan is to make a really nice aluminum and wood one to match the speakers.
    xschop Posts: 5,682
    100% sealed aluminum at least 1/4" thick should block any errant RFI.
  • Schurkey
    During the time the transformer will be in the plastic box, wrap it in several layers of aluminum foil as shielding from electromagnetic interference.
    Naturally, you'd not allow the aluminum to touch any of the conductors.
    70hemicuda wrote: »
    Toolfan66 wrote: »
    70hemicuda wrote: »
    There was a company that made an aluminum enclosure for just a few dollars more. It fit the 800va torrid very well and clamped it in place, its still a good idea to bolt it to the box.
  • gyosa
    gyosa Posts: 770
    Toolfan66 wrote: »
    Any interest in selling it ?
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    edited January 2024
    gyosa wrote: »
    Toolfan66 wrote: »
    Bk
    No B)
