The Grande Utopia Project
Mundorf didn't have the value I needed, hifi collective recommended powertron and given it was for the bass network should be good enough.
It is obvious the mundorf resistors uses higher quality materials in comparison
Path audio had the value but they were less wattage then stock and also to large for the space I had available- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So the mundorf wattage ratings are murky.
If you read the white paper...
Free air 3 watts
Their red heat sink, 15 watts
Large heat sink, 30 watts.
However most sites say the red heat sink provides 30 watts.
I can say with the huge heat sink I used, even playing at higher volumes for hours, they barely were above room temperature- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Shoulda went external!
With all duelund no doubt!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Refinance your house if you need to.
Broo... The enclosures to house a duelund build would be a house!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
And you are so temped to go for it!
Lol I would seriously have to win the lottery. That's Oprah rich stuff- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Hey there, Trey, nice setup! A fellow owner here .)
I need to read through the entire thread, now at page 4. Have purchased mine in 2017.
Cheers from Europe!
Hello @Machalik and please allow me to offer you a very warm welcome to Club Polk, from across the big pond!
Thanks Tom!
Found a cleaner picture from before I started the restoration of the black speakers:
Indeed the Grande is a good speaker. I've owned plenty, and I stopped with these. Congrats Trey to being among the lucky few!
I'll continue reading 2022 posts now.
Jiri -
Welcome Jiri!
Awesome setup! I need to know more about your woofers and how they became so dark! Looks awesome!
I can take detailed pics tomorrow in daylight, now it's closing on 4 a.m. They are dark grey and glossy, I am sure we have the same, might be a contrast thing with the phone camera. Do they look too dark to you?
Btw, mine are from 1996, two years older than yours.
Do you also have the original brochure thar comes with the tweeter faceplate? And have you ever obtained the wooden covers?
I have just had twins born so I must make a pair of woofer grilles with cloth on them so that they don't damage the dust caps. Have about 3-5 months I guess before they start pushing everything that resembles a button .) -
Trey definitely has advice for you on baby-proofing them. Not an issue there!
His woofers are kind of an off white. Definitely not as dark as yours appear.
Oh, my manners....congrat's on the little ones!
I have purchased any brochure or advertisement to can find on them for sure. I have noted darker woofers in other photos. Hard to tell for sure. One of mine has changed to a darker color versus the lighter gray. Here's one with darker woofers
I don't have the wood covers but I may make some one day.
I have cotton covers, then half inch foam then a double padded nylon cover for mine when not in use. Has worked well with my 3 year old for sure!
Digital deck covers sells the cloth covers, I sent the cabinet schematics focal sent to me. The covers are a perfect fit!
I don't have a photo of the cotton covers but I put those on before the foam covers
Finished reading.
Wow. What a ride! I am bookmarking this thread and will eagerly follow your further mods. I was tempted to open up mine and possibly get into xover redesign, too, but then chickened out and kept things as is and not ruin the collector's value. Also didn't want to spend another lump of money, maybe up to half of what they cost me .) How far are you cost wise if you compare the speakers cost vs. the mods cost, excl. your hours, just pure material?
Also noted your woofers are truly grey, while mine are dark grey or light black. Perhaps Focal changed the material in later SN's?
Would you mind sharing what Focal sent you, the xover schematics and enclosure diagrams etc.? I'll take pics of what I have tomorrow and upload, too. My experience with Focal hasn't been the greatest: I am missing one of the pins on the wooden covers that fits into the holes in the speaker; and if I'm building new grilles, I'll need 8 more pins, so I asked Focal twice in the timespan of 3 years and they never even came back, complete black out, no response. I reached our local dealer then who knew nothing and advised me to 3D print my own pins. So I didn't find them particularly helpful, and didn't ask for any schematics, which I'd love. I have a collection of tech papers on all speaker's I've owned except the GU's. -
Awesome covers .)) Full pyjamas set.
What a rare find to find a fellow owner!! The only other one I know is the previous owner of my pair who swapped to BE's (and wasn't too happy with them, as far as I know; I may mail him to ask if he sold or kept them). Very rare speaker indeed.
I paid right at 10 for the pair and drove 22 hours to pick them up.
Not counting labor, just parts, I would probably have 3k to 4k or so invested in dedicated parts just for the grandes. I have probably 10k in tools though that made the build possible.
I didn't change the schematic, just went higher quality parts.
I will say just changing the caps and resistors in the tweeter network netted extremely positive changes. The stock parts add alot of grain. To upgrade just the tweeter network is not to bad.
The biggest obstacle is removing those back panels. I had a guy on Etsy fabricate solid steel handles and had to use a large steel bar and a tremendous amount of force to remove them. It was no easy task. They are basically glued shut.
I had to really, really work on focal to give me what they gave me and they did not want me spreading it. Email me Vr3Mods@Gmail.com and I will send you the schematic they sent.
I would check hificollective.co.uk, they won't have the brass peg focal used but should have a plastic equivalent... https://www.hificollective.co.uk/loudspeaker-accessories/grill-cloth-and-fastenings.html
I would say though that your woofers are indeed a darker color and possibly even a completely different cone but it is hard to say. The black dots on the w cones are literally just for looks.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
If you ever wanted the wooden panels drawings, I can take measurements for you. I already have a precise Sketchup model for the woofer covers, I can make the same for all the rest.
That would be awesome. I have a set of mini utopia here that I was going to compare their wood covers but having a working model would be awesome!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I have only seen one other set for sale in the past two years in the states, was from a reseller in Florida. He has a single one still available. Very rare indeed! Welcome to the forum, hope you can stick around!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
This is the pegs used in my panels (they come out occasionally and stay in the speakers; luckily they come out of those easily, too):
I'll be def able to get something similar and fitting, my best guess is upholstery workers or veteran automobile restaurators will have an array of these, one of which will neatly fit the Utopias. -
I saw 3 pairs sell in Europe in the last ten to fifteen years, one I bought from Poland (and I have to correct myself, it was in 2019), the other two sold in Germany in 2020. The example photo you posted above of the black pair with dark woofers is one of the German ones, the other pair was wooden, same reseller, I think CJM Audio. Parallel sale, both went within a month, the wooden more expensive.
Btw, 3-4k USD in parts is not too bad! Not too bad at all.
Ha! Trying to fit them all in and the labor involved is. That's the kicker. Then there is the know how and tooling.
I am appreciating the latest conversation(s) on this thread. Does anyone know how many GU's were ever sold worldwide over the years?
For sure, I'm well into the 200 plus hours mark in labor and still plenty to do.
I doubt focal would ever release those numbers but I can't imagine it's many.
I know with the exchange rate they were more expensive than Wilson audio in the states which really hurt sales here.
The competition from Wilson was the x1 or x2 at the time.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
