The Grande Utopia Project
That mid does look like it is already designed so as to minimize reflections back at the cone, even though the spokes are wide, because of the angle of them and the absence of a lip around the spider between the spokes.
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Understand, the foam gets a little pricey.Don't take experimental gene therapies from known eugenicists.
Crazy talk. Next, you're going to say you won't even be Dynamat'ing themI really don't want to lead you on... That's probably not going to happen 😜
Seriously, though, are those red pucks on the woofer individual magnets?"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
So.... no mids in these pictures. That is the 10" woofer and the 15" subwoofer.
The 15" has 16 neodymium magnets and is a real tank at over 40 pounds!
No foam or dynamat!
Edit: I *might* consider dynamat- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Made some room last night!
That rust can't be good.
It may not be rust. Could be that the electrolytes have seeped out over time. This is an older speaker, so there is that...
Upon closer inspection it does look like leakage:
New wiring team for the bass network and this officially preps them to be a 4 way active loudspeaker!
Next to install the remainder of the parts
Getting closer!
Well you have a 3 day weekend..."getter done"...
Haha yeah right, quality daughter time ahead! I might be able to squeeze in some late night work though! 😅- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Do you mean 'active', as in 'powered'? Sorry if I missed that earlier.New wiring team for the bass network and this officially preps them to be a 4 way active loudspeaker!"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Phase plugs are in the works...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
So the main push behind this build was because I was absolutely consumed with this idea of what it would look like if the Grande could be a 4 way active loudspeaker... I mean like... consumed just mulling it over back and forth. Eventually I was just like... eff it! I took that idea, the user swappable resistors, etc and essentially decided to fully rewire, fully mod AND make them a 4 way active loudspeaker.
So in maybe 30 minutes... disconnect some wires, relocate some jumpers... the grande will be capable of fully bypassing the internal crossover and ready to be hooked up to an external active crossover and 8 channel of amplification...
The only missing piece will be the new binding post array, I will need 16 x WBT posts (8 per side)... that is a hefty investment. (the existing WBT posts have some corrosion on them)
I dont have the immediate goal to try active, I just wanted to see what that looked like in reality and have the option when I am so inclined in the future.
I can of course go partially active/passive. Running the bass fully active would be an easy achievement to accomplish!
Anyways... this has been a brain racking project... between thoughts, design, building, tear down, etc... easily hundreds, maybe a thousand plus hours invested! lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Ah, so active crossover, not active/powered speaker."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Correct, active crossover capable. Many years away! But I like the idea its capable!nooshinjohn wrote: »
lol, zero benefit of phase plugs on subwoofers.
The mids already have phase plugs though :-D- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My plugs don't phase me.
Looks painful...
Bass resistors installed and wired up!
The cheetohs add texture brother!
The next part is mounting the 168uf midrange cap cluster... Already 3 hours into the design and still working out the details, will be tough- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Faster bass response because of the large drivers?Don't take experimental gene therapies from known eugenicists.
using multiple smaller caps (5 x 33uf) plus a small bypass cap (.022uf) should translate into faster transients and response compared to a single large 168uf cap).
The other issue is you cant find a CMR or higher quality cap in that value and I doubt it would fit if they did! lol!
The CMR 168 is for the midrange and the CSA is for the bass. The bass network is pretty straight forward with the cap/resistor for a zobel network.
The 168uf and 75uf in the midrange network are directly in line with the positive amplifier terminal and the drivers so I wanted to go as high of quality as I could.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Nice work again. Midrange/midbass transients are always the first notable improvement when doing mods, whether electrical or physical.Don't take experimental gene therapies from known eugenicists.
Thanks Rob! I agree, I don't think I will be able to experience the true benefits until I'm able to change the 75uf... Should be here beginning of February or so I hope!
Very challenging project with the space constraints- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
