Snake River *possible* demo for Club Polk members poll....
treitz3
Hello all and good evening to you. This is more of a feeler than anything but Jonny (the owner of Snake River cables) is entertaining the thought of doing what we have done in the past. That is, a demo program where Club Polk members get to try out something that they may not have otherwise considered.
In this case? We are talking about a power cord provided by a high end company. Many of you have read about it. Maybe you haven't. With that said? I have one simple question for the folks on this forum.
If a demo program was to commence? What would be the one power cord you would want to choose in order to get a glimpse into what I have been experiencing?
Please vote and thank you very much for taking the time to read this post.
This is a public poll: others will see what you voted for.
Regardless of the type of cable offered? It will be a standard 15 amp to the wall with a 15amp IEC connector.
Sanke River Power cord for Amplifiers?VERY nice Tom.
I think one of their entry level models would do, it would give us a chance to check out the build quality, fitment and overall performance.
Count me in.Dan
Bump.
Sanke River Power cord for Amplifiers?I'm down for checking out a Snake River Power cord for Amplifiers. Any idea what the wire gauge of this product will be?2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
Hmmm, not really. That's something I never inquired about, to be honest with you. Here's why.
Snake River Audio builds their Signature Series "Amp Series" Hybrid power cables using a hybrid recipe of pure 24k Gold, pure 0.999 silver, and pure red copper conductor, along with their own US/IEC connectors. They do use heavier gauge conductors (67% more precious metal per inch) within their "Amp Series" PC's. As to what the "actual" gauge is? I have no clue.
They are a mix of pure gold, pure silver and pure red copper in a proprietary blend. None of the precious metals are diluted with inferior conductors/metalurgies. They are all pure and solid conductors. Then, they do what they refer to as an "Eddie Twist".
The Eddie Twist maximizes the effects of two principles, dielectric and surface area (or skin effect). By maximizing the surface area of their conductors, they greatly reduce the opposing eddy currents an A/C signal can create. It's very time and resource consuming, and ends up utilizing more precious metal wiring.
The pic's below that can help illustrate the design of said Eddie Twist...
Versus the Eddie Twist...
Now, the dielectric. As you may know, a dielectric is a non-conductive material that's used around and between your wires, to keep them from touching each other and shorting out. The problem, is that most non-conductive dielectric materials out there also absorb electrons, I.E., your music signal. Spread out along the length of your cables? That could be a problem. It's common knowledge that the absolute best dielectric possible.. is air.
They designed a method to take advantage of their Eddie Twist configuration, to create an 85%+ air dielectric in their cables. Here is an example...
Versus the Eddie Twist design...
On top of that, at the molecular level, all metals are cryogenically treated. So, with all of that said, I don't believe it's the gauge that matters with these PC's. It's every thought and the design philosophy's that were put into the Snake River PC's to begin with. THAT's what makes the real difference. It's that difference that I would love for you to hear with your own ears. Jonny, the owner of Snake River Audio is willing to entertain the thought of actually making this happen for Club Polk members in good standing.
It appears to me they aren't using solid gold wire. Rather, the copper wire is gold plated.Political Correctness'.........defined
President of Club Polk -
One further note....
It doesn't really matter which cord y'all choose. The connectors will be the same. This just boils down to what you would "prefer" to use in your own system.
Snake River Power cord for Components?My only limitation would be if the cable is too large. Where my rig is has to make quite an "S" bend right after the wall socket and then again into the back of the amp. If it's long enough I could make a smoother bend.
Just food for thought in case others hadn't thought about it. If whatever the majority choose doesn't work for me that's fine.
This should give you an indication of how they bend. This is "pretty much" how they are shipped...
This is a shot I took a while back on the PC that goes into the Lumin. The support isn't needed, I just put it there to help support the nearly 3' drop to the plug. FWIW.
Sanke River Power cord for Amplifiers?Very nicePio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Hmmm, you are digging deeper than I did. All I care about is the end result as to what hits these ears. With that said....
I actually called Jonny about this one. He is getting ready to sit down and enjoy dinner at the moment. I relayed to him to take his time in getting back to me (us). Family time is important, especially as we are approaching the holidays.
I just sat down to listen to the rig myself and forget about my new PIA client (OMG, words can NOT describe) So, if I don't respond tonight? Rest assured, I am listening to what I have been talking about for some time.
Time for some Big Daddy Wilson! Walk a mile in my shoes....
All, I spoke to Jonny for almost 2 hours tonight about Jesse's comments (Along with other things). He is correct and this is not a secret.
Admittedly, I tried to simplify the metallurgy based upon the Snake River Audio website. I was incorrect in my simplification. This was MY interpretation, not theirs. Let the record reflect that. The facts are...
80 microinches of 24k pure gold plating on top of pure red copper is what they use.
Tom.
Post edited by treitz3 on~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
10-12 gauge on the "Amp Series", 12-14 gauge on standard. Also, the silver strands are 99.99999 pure silver throughout, NOT silver plated like most audiophile companies.
One other aspect? They are made in the USA. 😉
Sanke River Power cord for Amplifiers?Considering that the surface is the most vital as that is where the actual current is traversing, a great conductor over another great conductor should provide ample quality signal path.
While I do agree, Gold is less conductive than copper. To me it seems silver over the copper would be the better of the two. -
Sanke River Power cord for Amplifiers?I’m game
Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Would like to compare to what I have and get an idea
Silver and gold? SweetMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Considering I run mono block amps, one cable won’t work..
You can still run an amp Series PC on one of your sources or Pre-amplifier. Just because it's an Amp Series PC (if that's what it ends up being), does not mean that this isn't something that you can't use.
As mentioned before, the connections will be the same.
Count me in.
Here is the thing. There are no, "entry" level cables when it comes to Snake River cables. There is no deception, no tiers. Just a quality product that offers differing metallurgies, for your listening pleasure.
Ivan, while what may make sense from a conductive standpoint? The end result that hits your ears is an eye (ear) opener. Jonny definitely knows what he is doing. He is truly a master at his craft.
I started with his offerings available to the public. What he has done beyond that is simply nothing short of incredible to the end result. I could not be more pleased.
There are theories, their are measurements, and then there is an, "artistry" to what can be. He has never heard my system. He has no clue what my system is capable of. Yet, when I asked of him what I wanted my system to go? He nailed it on the first try.
Please excuse my, "French"....the man knows his chit!
Tiers
EntryFor our Cottonmouth Gold series of cables, we only use pure 24k gold, overlaid a minimum of 80 microinches onto pure oxygen-free, high-density red copper.
PremiumOur Signature Series of products use a hybrid recipe of ALL THREE metals. Pure gold [plating], pure silver, and pure red copper.Political Correctness'.........defined
Look at the cost.
$1275 and $1545, so $270 more for the added silver wire. I suppose one could look at the Signature version as a bargain. Regardless, it's still 2 tiers.
Edit: I'm going to add that implying there is pure gold wire by not stating it is pure gold plating on the copper wire for the Signature version strikes me as deception.Political Correctness'.........defined
That is incorrect, though. It's not two tiers, it's two completely different power cords, each utilizing their own blend of differing metallurgies. Neither one is considered an entry level PC. Neither of the two PC's sound alike either.
Oy veyPolitical Correctness'.........defined
I think what Tom is trying to say is all the **** is awesome but he offers different series which sounds different and utilize different metals etc etc
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sanke River Power cord for Amplifiers?All I know is I’m in
This will go into a classe delta stereo ampMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Well, now that Thanksgiving has passed us by and I am no longer swamped with family obligations? Back to the grind.
Jesse, I simply don't think it's a tiered system, it's more that different systems fit better with different recipes. Think of this...
If you go to an Italian restaurant, you can order Shrimp Scampi or Spaghetti Al Carbonara - they are both meals, not on different 'tiers'. They are just different recipes with different ingredients that cost differently. In the case of these power cords, it's the same thing. Differing recipes/ingredients yield differing prices.
___________________________________________________________________________________________________
Okay folks. The fat lady hasn't sang quite yet on this but it is now official.
There WILL be a demo program here at Club Polk for the Snake River Power cords!!! That's right. Some of you may have picked up that I stated that in the plural sense. Jonny has been following the results of this poll, as it has marched on and he has decided to offer up not one but two power cords up for the demo program.
One "AMP Series" cord will be 3 meters long (leftover from the recent CAF event). The other one will be a component power cord. The other is a 2 meter component PC. Both of them will be the Hybrid Signature Series.
Larry, we may have something special lined up for you. You are running dual mono block amps. I'll get up with you privately about your situation. We may have come up with a solution for you.
Here is what I need from all of you that are interested in the demo program;
Full legal name
Moniker
Valid and current email address
Phone number
Emergency contact (preferably someone that lives at your home)
Shipping address
Please include which PC you voted for/requested for demo in your PM
Please PM me with all of this information (None of it will be released to the public).
The demo time each person will have will be for a period of two weeks. At the end of your demo period, you must ship the cables (pack them carefully and well protected, so they are not damaged in any way) INSURED to the next person on the list. The list will be created when I get everyone's information in.
You will be required, as is tradition with demo programs, to offer your review of said cable on a dedicated thread that is nothing but reviews and discussion(s) about said cables. To make this easier for you, you may want to jot down notes of initial impressions and what they are being compared too, what locations and equipment they were plugged into/evaluated on and how they sounded on certain tracks, albums or even a general observation.
Only members in good standing will be accepted into the demo program and a minimum of posts/trustworthiness/reputation will all play into whether or not you qualify to be admitted into the demo program. That determination will come from the "old guard" of the forum, as well as myself.
If anyone simply cannot live without the cable(s) after listening to them, they will have the opportunity to keep them (provided they are promptly paid for). If that does happen, a delay of two weeks will happen, as a new custom cable will have to be made, burnt in and shipped.
I am probably missing something, as a demo program hasn't been done in a while, so I reserve the right to change the rules/qualifications at any time moving forward.
A novel is not necessary but your observations (good or bad) do need to be posted.
I would start a new thread to officially start the program- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Stop digging, you're not getting anywhere.Jesse, I simply don't think it's a tiered system, it's more that different systems fit better with different recipes. Think of this...
If you go to an Italian restaurant, you can order Shrimp Scampi or Spaghetti Al Carbonara - they are both meals, not on different 'tiers'. They are just different recipes with different ingredients that cost differently. In the case of these power cords, it's the same thing. Differing recipes/ingredients yield differing prices.Political Correctness'.........defined
