This joint needs some more vintage hifi
1565758596062»
    SCompRacer Posts: 9,121
    edited October 2023
    One recently refurbished HH Scott 340 with some vintage friends. All electrolytic and film caps were replaced, some resistors. Some cans were stuffed with new caps, others installed in chassis. Selenium rectifier was replaced with diode bridge.
    "Introduced in April 1962, the HH Scott 340 "Stereomaster" tuner-amplifier is rated at 27 watts per channel for a total of 54 watts RMS (advertised at 60 watts output and later 70 watts). The set essentially combines the Scott 350 FM multiplex tuner with the Scott 299C amplifier. It has a total of 20 tubes including four 7591A output tubes and a pair of 5AR4/GZ-34 rectifiers. Advertised price for the 340 was $379.95. The optional case was an additional cost. The set is now often identified as a Scott 340A to distinguish it from the very different 340B."
    It bears some scars but sounds really good. Not sold on the blue LED look. Could be I'm stuck in the past with the #47 bare bulb look. They pulse too. You can't see it with your eye but the camera catches it.
    The Mitsubishi LT5V is in partial disassembly as the auto return stopped functioning. I had replaced the bulbs in tonearm carrier with LED's (with step down resistors to reduce brightness) last year so it could be a photocell issue. It got knocked off the bench by the 340 and now the Scott 399.
    Post edited by SCompRacer on
  • rceagan
    rceagan Posts: 15
    mhardy6647 Posts: 35,166
    rceagan wrote: »
    Several times, in different contexts.
    Mostly to illustrate the zenith of decor in early 1960s Britain.
  • SCompRacer wrote: »
    /quote]
    Ooh! one of them there new fangled tuners with the built in multiplexer! That's cutting edge!
    edited November 2023
    You young guys had it made! We had to wait until June 1, 1961, for stereo FM. :D We just had the short-lived, not the greatest simulcast. Left channel on FM right on AM.
    "The FCC authorized regular stereo FM to start June 1, 1961. WGFM (now WRVE, Schenectady, N.Y.) was the first station to go stereo at midnight Eastern time. WEFM Chicago, had to wait an hour later until midnight in the Windy City, as the implementation order specified local time, making them second to go on-air."
    The first cutting edge??? An external FM multiplexer, the HH Scott 335. Also available as a partially assembled kit, the LM-35 with black faceplate. Scott had built in multiplexer out/in connections on the 399 so it was ready for FM stereo. I am currently in FM alignment hell....sounds great in mono, FM is distorted.
