You get those when you stopped by Josh's the other day?
Yes, got to spend a nice afternoon with Joshua spinning vinyl and talking audio. -
Can't ask for more than that. He's a great guy to hang around with and he has great taste in music. I'm planning on a couple of extra days when I'm down that way next year to do just that.
Nelson Pass Amp Camp Redux kit
Completed build
Unusual looking heat sinks. Is there a schematic you could share?
the circuit is from Nelson Pass 1.6 build. Here is the schematic. A couple of changes from the black box build are the round pin heat sink build uses 2SK370 and IRFP048.
Thanks!
Any idea why the positive output terminal is tied to ground?
For the dedicated 2 channel enthusiast:
SeleniumFalcon wrote: »Any idea why the positive output terminal is tied to ground?
The circuit Q1 is taking the signal from the drain and not the source, so the signal is inverted. -
Makes sense, thanks!
Did a little customizing. The base holds a fan.
I gotta admit, I have seen a lot of unique amps in my time but this one? This one may take the top spot.
Working on my next set of near-fields....
Don't take experimental gene therapies from known eugenicists. -
Got my TeCu binding post prototypes done...
Think I should coat entire plug with dielectric grease, or just add it to the banana plug port?
I like Mapleshade Silclear silver platelet contact enhancer grease. Just a trace amount.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Added some speakers and power improvements.
2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Signature 21 w/Hana Umami Red, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables -
Very nice, Todd. If you don't mind me asking, what type/brand of rack is that?
Hey Tom. It’s a SolidSteel.2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Signature 21 w/Hana Umami Red, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
Thank you sir. I am having to look at rack options for the new room. There is no way I can utilize my current rack.
hey Todd,
Rosso is new to you? what were you rock'n before?
Your ears gotta be in heaven!
edit; I've really been wanting to roll Norma IPA140 into the mix . . . someday!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
hey Todd,
I had Legacy Focus SEs. Sold them about 8 months ago. Skip let me borrow his Volterras for the last 2 months. The ones you see in the picture are mine with Dark Grey Sand finish. They look and sound great. Need a couple hundred hours on them.
Glad to see your pair arrived. I know you’re excited to finally get them. Shipping issues stink.Things work out best for those who make the best of the way things work out.-John Wooden
We've moved into our/my 'final resting place'. I've got the new room pretty close to where I want it and quite happy with the sound I'm getting. I sold my 2.3TL's as I knew they wouldn't work in the room and picked up a Cary Audio SLI-80HS Integrated, along with some new Revival Audio Atalante 5 Speakers to celebrate my 70th.
A big relief to achieve good sound in the new room
It's not as large as my last, but I've got room for everything. I still have the 3.1TL's and the CRS+'s in back reserve atm, but will always be in rotation.
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
Mike Reeter wrote: »along with some new Revival Audio Atalante 5 Speakers to celebrate my 70th.
You don't need a Big room for Big sound. Congrats brother, looks great ...
Happy belated 70th Mike!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
did you score the Legacy's from @tonyB ? . . . if so, that was a killer deal
those Volts are awesome . . . I gotta get my ears on themAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
No I purchased my Legacy’s direct from the factory.
The Volterras are awesome.2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Signature 21 w/Hana Umami Red, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables -
Thanks for vacuuming @Mike Reeter ! I was starting to worry.See my profile for list of gear.
I got a couple of Rhythmic L12's to go with my Audio Physic Avanti III, a perfect match.
