One can dream, can't they? - Audio Exotics
I wish they did. The insight, the wisdom of trickle down technology would help. That is, of course, if they were into the music and not the brand.
Rom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
If you had the wallet that spoke otherwise....and this was still your hobby, the bills were paid and you had a plethora of leftover? Would this still be the case?
For some folks out there? This is literally chump change. Not to us, obviously but...
Fair question, and yes, supposing I was a billionaire (or more) my listening preferences would still steer me to other speakers that cost far less for a couple reasons:
1) From a moral standpoint, I think spending $1.5mm on a pair of speakers reflects a gross lack of perspective regarding what is important in life.
2) From an engineering standpoint, I don’t like what I see going on with the mids/tweeters in this design, as this arrangement will reduce the listening sweet-spot.
Massive multi-driver speaker towers impressed me when I was younger, but through the years I learned that simpler designs please me the most.
I also prefer to use subs for bass rather than large cabinets in the main L/R speakers.
3) Even now, I find a lot of enjoyment listening to equipment that costs significantly less than I’m able to afford.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Rom
None of the above would help any of us, since most of us aren’t using equipment in the same universe as these speakers appear to be. Right?
But persons with even bigger budgets already have done scientific research that does/has helped even we lower-level listeners.
Unfortunately, that research is dismissed as a bunch of bunk and replaced by unreliable subjective impressions by many audiophiles.Post edited by jbreezy5 onCD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
When I was buying my Magico m2, I spoke to a guy buying an M6. The difference in income was about 10 fold.
My suspicion is someone buying a $1,500,000 Veyron probably has an income x100 of mine.
Speaking to the guy with the m6 in British racing green carbon fiber being made at Magico… I could not completely understand his lifestyle as it was so different to mine.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
This page needs more peeechers.
These may be the little brother or the same speaker, either way I've heard them at Axpona several times. They remind my of big PVC tubes with drivers at each end. Not bad but definitely not my cup of tea.
I built a sealed 12" sub years ago out of thick-walled PVC main line pipe. Sounded pretty good too. Got the piece from the City's Line Maint Dept I was working for at the time.Don't take experimental gene therapies from known eugenicists. -
Svs started out using concrete Sonotubes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Until the last few years some of the best subs I've ever heard were homemade Sonotube based. My good friend before he passed away had made a huge dual 12" driver Sonotube tuned to 17hz. That thing could flex a room very well. It was impressive! -
Those rooms by @treitz3 are I believe DFW Rhapsody dealerMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Various Rhapsody dealer locations but yes. DFW is one of them.
Lawd, have mercy!
GeezMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Where did you get that picture from? I have not posted a single picture of my new setup yet…The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
One might get the impression that the owner has neither friends nor family.
Sooo what I heard you say is......... that's some serious tornhub surround sound!
WHOA! -
Big screen, one chair.
All those blue lights would drive @BlueFox nuts2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
--Gary--
I just snagged the pic off of some random FB group that popped up as “recommended for” me. Tried to find it again, but can’t even remember the name of it now.
Brian -
I saw that too
I wonder if it’s a personal system or a dealer. I see a commercial vent up in the ceiling
I’m not too impressed with dealer set ups as much as if it were a personal set up. If that’s a personal set up, that’s very impressive indeed
The cards/plaques below the speakers and on the right wall tell me this is a dealer setup vs a home setup unless you are Kex2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Lol, imagining someone who puts model numbers and prices next to their gear definitely brought a chuckle- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
txcoastal1 wrote: »The cards/plaques below the speakers and on the right wall tell me this is a dealer setup vs a home setup ...
Sheesh! I didn't see that until you mentioned it ... and now it's so obvious. Lol
Brian -
I sure would hate to power these on and off, but that's it LOL.
https://www.youtube.com/watch?v=4b2IOOhJmxw
https://www.youtube.com/watch?v=Wof74IUmVx0 -
A few Audio Exotics popped up on TMR recently:
Nagra HD DAC X D/A Converter - $39,999 (MSRP $65,000)
Dan D'Agostino Momentum Stereo Preamplifier - $18,999 (MSRP $32,000)
Dan D'Agostino Momentum M400 Mono Power Amplifier; Pair - $32,999 (MSRP $65,000)
MSB Technology Select II DAC; Black; PowerBase - $59,999 (MSRP $89,999)
emm Labs DA2 V2 DAC; D/A Converter - $17,819 (MSRP $30,000)
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
