Network Audio Players/Streamers
2456
    VR3 Posts: 29,624
    The u1 mini with the s booster is as good as the stock u1
    nooshinjohn Posts: 26,058
    I run USB, and have the Oppo for a transport on a coax. I don't care for the sound quality of ethernet...
  • WagnerRC
    WagnerRC Posts: 2,218
    I would not invest in anything until you give a listen to a Lumin. It's a winner
    txcoastal1 Posts: 13,519
    Going with Tom's advice with a company that does primarily streaming
    That means progressively upgrades firmware and apps for improvement to keep them in their nitch
    I've been though NAD with their nodes V1 as they scrapped as it failed
    Same with Simaudio as I owned the 780D and they to moved on leaving their Gen1
    Lumin has been in the game for a while now and that's what they do
    You can buy a progressive companies streamer and add a DAC that you can flip around
    If you ever decide to move up a chain, or sell, purchasers will be looking for all the features, not just the brand
  • mantis
    mantis Posts: 17,607
    edited April 2023
    https://www.sonypremiumhome.com/high-resolution-audio/HAP-Z1ES.php
    Check out the HAP-Z1ES which is stupid good. You also can get the smaller unit which I had in the
    HAP-S1. This unit has a built in Amp which you can use if you want or use it as a source to your system. It has a smaller hard drive and still sounds incredible.
    https://www.sonypremiumhome.com/high-resolution-audio/HAP-S1.php
    Dan
    treitz3 Posts: 20,203
    Not sure what you mean by that....(in bold)
    All streamers (unless running optical/fiber) have an E cable somewhere in the system, no?
    edited April 2023
    In my rig, only at the PC.
    I pull my signal directly from the computer and send it out on either HDMI or USB to the other gear in my rig.
    Ah, carry on...
  • pearsall001
    pearsall001 Posts: 5,359
    Another plug here for the BS Node 2i. I've had it in my system for a few years now & not even a single hiccup with it's performance.
    I recently got the itch to upgrade but decided to go with the LHY Audio upgraded PSU for the 2i. I must say I'm glad I did! Later I added the iFi iPOWER ELITE PSU along with the iFi LAN i Silencer.
    With each addition the performance was kicked up enough that it had me scratching my head about what I was now hearing! The BS app & Tidal app are also tremendous & I love them both. Winner winner chicken dinner!!
  • jbreezy5
    jbreezy5 Posts: 1,141
    @treitz3 - No doubt that a stock Bluesound Node won’t sound as good as an Auralic. Did you happen to upgrade the power supply on the Node you had? That is a significant improvement, imo.
    No disrespect to, or hyperbolic claims against, Auralic / Lumin at all. I just enjoy tailoring the sound by swapping DACs with the Node. I didn’t care for the internal dac, as it sounded very 2-D to me.
    Cheers!
    Toolfan66 Posts: 18,278
    edited April 2023
    treitz3 wrote: »
    Ah, Cary on...
    :smile:
    JB, when I had the BS Node2? I had it and accepted it for what it was. No upgrades other than an upgraded PC.
    The internal DAC left a lot to be desired, which is why I upgraded immediately to a MF TV21.
    It still left me wanting.
    I am no longer wanting, if that answers your question. The price difference was....a lot.
    Mine to, USB to the OPPO..
    Just throwing this out there....
    Computers and CDP's are inherently noisy environments.
  • motorstereo
    motorstereo Posts: 2,391
    For those in the know for streaming (I've barely gotten my feet wet) is ethernet from the router then to the streamer a preferred connection method or is there something much better?
  • Dr_Wu
    Dr_Wu Posts: 356
    I've tried wifi, usb, and ethernet. Have had virtually no glitches with Qobuz via ethernet to Lumin. Had fairly frequent issues with Tidal via wifi and usb to Auralic. YMMV.
    Also, budget permitting, consider putting an Uptone Audio EtherRegen switch between the router and the streamer. New version due out soon; v.1 can be found used (audiophilestyle.com).
  • jbreezy5
    Dr_Wu wrote: »
    On my Bluesound Node 2i, I’m using a backup SSD plugged into the Node’s USB input (no computer noise, no wi-fi buffering/jitter issues) and using the Node app on my iPhone as remote control for song selection.
    If you run ethernet direct from your pc you may (likely will) have noise from your pc come through ethernet.
    Wifi from your router should eliminate the pc noise, but buffering and/or jitter issues will be introduced. There are some ways to mitigate the former, but I’m not aware of any for the latter since the signal is not being directly transmitted. I’ll let others speak to these issues, though.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    treitz3 wrote: »
    That and there are some amazing high quality Ethernet cables out there! How well I know ! I have zero use for USB in any of my gear !
    VR3 Posts: 29,624
    Streamers from esoteric brands are the receivers of the 90s and 2000s for audio in 2020s.
    They may support them today, but will they support your large acquisition 5 years from now thus making it a gigantic paperweight
    VR3 wrote: »
    Agreed, but that really goes for any of these brands as things change so rapidly, they all are in business to sell the next big thing. No different than a CD/SACD Player, it can easily be a big paper weight just the same after 5 years. There is no guarantee in any of this, one can only hope a shop can acquire the parts to service it.
  • engie490
    engie490 Posts: 445
    edited April 2023
    I don't disagree with you, but Cary is catering to the high dollar crowd with small numbers. Personally, I would steer towards a low dollar investment in a streamer (aka Bluesound) and use the digital output to drive a separate DAC. More boxes may not be the direction you want to go though and I would understand that issue.
    Infinity RS-1Bs / Bryston 7B STs / Sonic Frontiers Power 2 / Jeff Rowland Consonance / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
  • tophatjohnny
    VR3 wrote: »
    That can and should be said about ALL brands and things for that matter!
  • rooftop59
    rooftop59 Posts: 8,120
    edited April 2023
    I recently acquired an Arcam sa30 interested amp/streamer and love it. Here is the delicated streamer!
    https://www.whathifi.com/reviews/arcam-st60
    Game Room 5.1.4:
    Bedroom 2.1
    Well, I didn't pull the trigger on anything yet.. :#
    My advice? If you are looking for something for the long haul with all of the criteria you want in a streamer? Keep asking questions, looking and researching.
    If you want something to get your feet wet while you are looking? You can't go wrong with the BS Node units (with an external DAC). The resale on those are horrible, so when and if you do upgrade, put that either somewhere else in your home/office/camper or take the hit when you go to unload it.
  • Emlyn
    Emlyn Posts: 4,864
    There are other options for streaming music content. Any Amazon Fire TV product can stream music from the Amazon service. Apple has their own. Most mid grade and up receivers and AV processors have built in music streaming capability. Some integrated amps have it now too.
    For now the Bluesound node streamer seems most appealing to me for a standalone product since it's not too expensive, has a good user interface, and can be hooked up to an existing DAC that doesn't need to change when the interface device gets outdated.
  • monepolk
    monepolk Posts: 1,154
    You must have made a decision.
  • engie490
    engie490 Posts: 445
    edited April 2023
    Keep in mind that you can dip your toe in for less than $1K. Buy a streamer such as Bluesound Node (~$450 used), Auralic Aries (~$800 used), or any number of others and just run SPDIF over coax into your Oppo. You can then get an idea of what you like in your system without making a major monetary investment.
    Or you could buy the Cary from TMR, try it for 2 weeks, and return it if you don't like it.
