Good looking setup!Speakers: Polk 1.2TL w/VR3 mods and Dreadnaught interconnects
Amplification: ARC Reference 110 w/KT150s; Cary Audio SLP-05 w/Ultimate Upgrade
Vinyl: VPI HW19 MK III (Heavily Modded); Origin Live Silver Tonearm; Hana ML Cart; Pete Riggle VTAF; VPI TNT Platter; SAMA; Iphono3
Digital: Aurender N100H; Benchmark DAC1 -
I appreciate the compliment! lots of hard work over the years and smart purchasing allowed me to assemble it2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
I applied a new system firmware update on my Gustard R26 DAC. No more magnifying glass needed when changing settings!
https://www.mediafire.com/file/qwq9ih7azboh55y/Gustard_R26_CT_m2.1_via_type-C.zip/fileSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Holy moly! That's one heck of a change....should have been there in the first place IMO. Wow.
stangman67 wrote: »Got a Lumin U2 Mini from Skip and got it installed along with an AQ Cinnamon ethernet cable. First couple hours were rough as it was very very bright, and my right ear is very sensitive to harshness and will start to buzz badly (medical community says there’s nothing wrong with me of course)
I let it play constantly for 30 hours and re-evaluated and like what I am hearing now. Haven’t done the Sbooster yet, not real comfortable voiding the warranty right now.
Refresh my memory . . . what were you using prior to the U2 MINI ?
TYAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
TY
Cambridge 851N, after the initial brightness scare the Lumin is worlds more refined than the Cambridge (although I still thing the 851n is a friggin steal of a value)
Ah yes . . .
I think you may find the MINI does very well with usb. If you can score a lightly used WireWorld Platinum 7 or 8, I think you might find nirvana
Happy listening!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Added these Auralex Mopad Isolation Pads under the Center but tilted upwards instead of downwards like in the picture that Focal sits on.
This is a spare room for watching a little TV slapped a piece of plywood I stained to match on to two cheap tv stands I got at a garage sale stained a old wooden album holder to match. I got more in the can of stain and the Isolation
Pads. I needed only $70 to put the whole thing together. I need to spread the pads out a bit more like on the sample picture.Home Theater
stangman67 wrote: »Not really today, been in the stereo for a week but I’m comfortable enough with it now to speak on it a bit. Got a Lumin U2 Mini from Skip and got it installed along with an AQ Cinnamon ethernet cable. First couple hours were rough as it was very very bright, and my right ear is very sensitive to harshness and will start to buzz badly (medical community says there’s nothing wrong with me of course)
I also have a U2 mini that I picked up from Skip. I paired it with the Norma USB DAC and a AQ Diamond USB. It’s a nice setup.
2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
Having actually managed to re-home
some stuff at the big NEVEE fleamarket this past weekend, I've been playing with some of the second and third-tier loudspeakers around here lately. Hooked up a pair of ads L470 that have been here for a while -- and these are danged fine sounding little loudspeakers, in that classic ads/Braun way.
Cat-proof grilles, too!
Unfortunately, this pair (which were given to me, years back) is missing one grille. Fortunately, there're no cats here any more.
Rich, sweet, smooth sounding loudspeakers that are easy to drive and also surprisingly sensitive (for small sealed boxes). The worst thing I can say about them is that the "image" doesn't exend much past the loudspeaker' outside edges. Otherwise, they're nigh-on perfect.
Everyone, I will opine, should have a pair (or two) of -- or at least spend some time listening to -- ads (or Braun) loudspeakers as part of one's hifi apprenticeship/ear training!
Closeup of the grille-less (and slightly worse-for-wear) L470. I apologize for the schmutz on the tweeter, which looks like masking tape residue and has no audible effect (and I figure I'll do more harm than good if I try to remove it!). I also apologize for the upside down logo, which I only noticed when I cropped the image to upload to Flickr.
I should probably fix that!
PS I sold the ELACs Sunday! Kind of glad to move them along -- they just never did it for me, bargain price notwithstanding.
I swear, you have more hidden gems than an African diamond miner.
Sprung and got an upgraded umbilcal cord for the Lumin.
Listened to a couple of new songs. One of them was trippy, yet awesome.
That sticky dome appears to suffer from pterygium.Don't take experimental gene therapies from known eugenicists.
Swapped out my subwoofer IC's that have been in my system (subs) for 14 years. Tried a Transparent Misic Link on them.
Was very surprised at the difference it made.
The entire system is very cohesive and the synergy is off the charts.
Pulled the trigger on the lhy sw- 8 switch
It has a lps and a 10mhz clock .
Very good reviews. Made from a solid block of aluminum. -
Picked up some Acoustat Spectra 11s for $50.
They dwarf my Infinity Prelude P-FRs.
Infinity RS-1Bs / Bryston 7B STs / Sonic Frontiers Power 2 / Jeff Rowland Consonance / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
Added ifi powerx cords to the modem/router and the cable box
Installed the Soundocity outriggers on my new to me Salk Encores. Glad to be back in the Salk fam.
Added a hard-to-find Dolby 422 noise reduction unit (Dolby B, C and S capability):
@Gerres26 Dynaudio Mid Bass Driver and Satori Beryllium Tweeter?
Jim and the new Fam at Salk will attempt to make anything (within reason) to satisfy clients . . . so it might be different from the standard offering. This is what it "most likely is"
https://salksound.com/model.php?model=Song3+EncoreAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
CFarrell_SoundUnited wrote: »@Gerres26 Dynaudio Mid Bass Driver and Satori Beryllium Tweeter?
Satori Be Tweeter, Audio Technology mid(used by Dynaudio in some models I believe) and the the 9.5” Satori woofer
It most definitely is this! -
Fine looking speaker, if I do say so myself.
Very nice! Welcome back!
@Gerres26 - I actually looked up that company that did the outriggers. Would you recommend them? How was the quality of them and do you feel like they can handle the job?
I contacted them and asked to be put on their wait list, as it looks like they are enjoying a couple of months abroad. Just wanted a real review of the quality/other aspects, if you wouldn't mind sharing.
I dig the looks of the steel outriggers with the nickle plating (might powder coat the outrigger part though and do some custom work on the spikes...whether they do it or not). Thanks in advance for any thoughts you may have on them.
@treitz3 - Build quality wise they are very nice. The adjustable knobs on top of the spikes are great, much easier than trying to use washers or a jam nut with a normal set of spikes to make fine adjustments for level or tilt. That’s actually the original reason I bought them, as the concrete under my basement flooring in my new listening spot isn’t the most level thing ever poured. Using them paired with Herbies gliders has made it a breeze to move the speakers around and then re-level as I was trying to find the best placement for the Salks. Not to mention the added stability of a wider base….and I think they look pretty sweet too.
When I was researching outriggers there wasn’t a ton out there and Soundocity kept coming up as the go to. The outriggers from Dayton/parts express looked okay but the reviews said they were a little too thin and flexed some so I crossed them off my list. These Soundocity ones are pretty damn beefy so I don’t think you’d be disappointed Tom. Of course as you saw, they are taking some time away from the business so you’ll have to be patient. Although, I got lucky and found a guy selling a pair of Tekton speakers that had these outriggers on them so I shot him an offer for just the outriggers and he accepted. So I skipped the wait lol.
Danny -
Thanks, Danny. Much appreciated.
Fwiw, making outriggers is actually really easy. If you can find the spikes you like, cutting metal and powder coating is fairly simple.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
