So I plugged the ANK 5.1 pro back up
The lampizator has a slightly advantage for top end detail retrieval, ever slight for sure.
The ANK 5.1 is just a complete package. It has 98% of the details but tonality, dynamic range capabilities is just leaps and bounds over the lampizator.
I would however like to hear a newer high end dac from lampizator in the future to compare against the ANK.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Are the components in the Lampizator on par with those used in the ANK?Enjoying the journey while never attaining the destination. -
The build quality appears better in the ANK as well. The Lampi looks like it was built on a kitchen table…The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I mean the lampizator is a mix of PTP and circuit boards so... PTP on a build like this is very tedious to make it look like it was built somewhere other than a kitchen table.
Both very good DACs but the ANK is just a better sounding DAC for my setup from low end to top end, dynamic, spatiality, etc.
The ANK is based around a $60k Audionote DAC as well...
The Lampizator sounded well enough in the time I was playing it that I was browsing the lampizator website checking out the newer models but once the ANK was plugged back in I knew this particularly lampizator would not be replacing the ANK.
I would like to hear a newer, high end Lampizator... but it looks like similar build to the ANK is north of 10k so... will be a long time short of an amazing deal!
nooshinjohn wrote: »The build quality appears better in the ANK as well. The Lampi looks like it was built on a kitchen table…
The serial number 313 on Trey’s Lampi would indicate that it’s about five years old. Believe me, they don’t look anything like that anymore… Fit and finish is excellent, looks very modern and streamlined, including an OLED display if you’ve got volume control.
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
What amazes me about that company is just how many different models they have. I can get mind blowingly confusing.
They might as well not have models since each unit can be customized.
Everything on the website is the base model, essentially- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Makes me wonder how they keep track of each unit...
Apparently there is a log kept off each serial number- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I’m not sure which ANK you’re rocking, but if it’s this one, that’s not comparing apples to apples.
I’m not well versed with the older units, but I’m thinking that the 313 serial # sold for less than 1/2 of this one
Betcha it’s like a VIN # ... easy peasy
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Level 5 gen 4 was around 6k msrp based on the reviews I read.
Level 4 was around 4k- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Keep in mind that ank link you used is for a diy kit.
Zero dealer network, no advertising budget, two man show that works with audio note engineers.
Lampizator has a full dealer network etc... Whole different cost overhead- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Fair point . . . I must admit, I know next to nothing about Audio Note.
I do know Koray @nostubestore.com claims his 6X5 rectifiers best the ank stock tubes (whatever ank uses, maybe EH or JJ, I dunno)
https://www.nostubestore.com/search/label/6X5
In my search down the Lampizator rabbit hole, I came across this ad claiming his serial #707 DAC was purchased in 2015
It’s probably fair to say that the 2 box Lampi technology is a decade old.
https://www.usaudiomart.com/details/649938409-lampizator-big-7-dac-with-riccardo-kron-anniversary-special-edition-kr-audio-300b-and-5u4g-tube-more/
The AN Kits are interesting, I’ll get my learn on 🧐AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Ank provides tubes that prove they work, definitely nothing fancy.. 80 dollars total.
ANK makes a fantastic product... As does lampizator!
I definitely would like to hear a newer one like the big 7 or higher, but that's a substantial investment- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The RTR NOS DACs by SW1X also look pretty nice
Wouldn't mind hearing that either haha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Make it happen, Captain!"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Well, it appears as if I am getting Trey's sloppy seconds. In this case? I don't mind. The "loser" between the fight on DAC's in Trey's system is coming my way sometime soon.
I have spent more than I care to disclose recently going a completely different route to upgrade my NAP versus spending the dough on his ANK DAC. I will say this (and I have told him this many times), the ANK is the best sounding DAC I have personally heard sub 32K. It does things that other DAC's at that price range and less don't do.
He did good with that DAC and that was the path I was gonna take. Then the Ethernet cable "thing" happened and I took a different path. While I am glad I did, that took me out for the meantime in getting the DAC of my choice (The ANK 5.1 with the quad core).
So, I still wanted to get a "real" DAC for the streamer and the Marantz, so....here we are. Now to look for an appropriate USB cable. Any suggestions for something that does not have a sonic signature? Read, "Neutral" but offers great imaging/spatial locationality cues.
Coax cable- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
What’s that tall drink of water that’s slightly right of center?
I’m considering a KR 274B rectifier for my latest acquisition
BTW ... CONGRATS! Looking forward to your impressions
FWIW I like the WW USB Platinum Starlight 7 from LUMIN into Lampi. But thinking of trying one of the offerings from Final Touch AudioAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Yeah I don't believe the lampizator usb connection is an active connection versus just a place holder which apparently is common for the earlier models.
The 5.1 uses a 5u4g rectifier or a 274b- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I am thinking of Pink Faun for a USB cable. Many folks seem to like that. I don't know anyone here that has even so much as mentioned them...
I'm playing catch-up a bit here, but I'm thinking ANK = Audio Note Kit? Straight-up Audio Note products are not DIY. Am I on the right track here?"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Ank does offer pro builds, which mine is by "Digital Pete" in flordia
Audio note does not offer any of its actual products as a diy kit however thr actual products and the kits are based on similar designs.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
60k audionote level 5 DAC- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
...only a cool double digit more in cost will get you this....
Only bad **** people have duelund caps in their water cooled computer!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Duelund caps take VERY long time to break in, no?
Is that actually a dac or an audiophile computer?
