50 year anniversary r200 signed by matt polk
    VR3 Posts: 29,631
    I mean if one wanted to... definitely resistors and maybe internal wiring.
  • Braddles63
    VR3 wrote: »
    Hmmm. I will get my people to talk to your people later.
    txcoastal1 Posts: 13,519
    Braddles63 wrote: »
    VR3 wrote: »
    With the space on that board, upgrading resistors would be easy
  • SIHAB
    SIHAB Posts: 5,670
    Do you hear any hash? What would replacing the resistors
    do? I think I would wait till after the warranty. :)
  • Braddles63
    I don’t hear anything yet. Still haven’t arrived. Just thinking out loud.
    mhardy6647 Posts: 35,394
    SIHAB wrote: »
    you silly -- you're not supposed to hear hash...
  • GlennDog
    GlennDog Posts: 3,158
    The very small print on the can says “Blonde Lebanese”
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    GlennDog wrote: »
    Wouldn't Christmas bud be tis' the season...asking for a friend
  • Braddles63
    Braddles63 Posts: 191
    edited December 2022
    VR3 Posts: 29,631
    Yes!!
  • rebelsoul
    So straight out the box these sound better then stock L200 ?
    VR3 Posts: 29,631
    For the money I would go with these over the l200. The reserve series is voiced a little warmer but long term these are an excellent platform to upgrade on where as the l200 is fairly complex to tweak
  • Braddles63
    Sound pretty boomy and bloated so far. Hopefully that settles down.
    Not sure why Polk try and make stand mounts sound like a floor stander.
  • dromunds
    dromunds Posts: 10,160
    Don’t try to assess the sound before a long break-in period. They’ll sound like crap, then good, then crap and it could be quite a long break-in.
  • Braddles63
    Yeh my R700s took ages to settle down too.
    I don’t like it.
    It makes me nervous.
  • dromunds
    Nothing to be nervous about
  • Emlyn
    Emlyn Posts: 4,871
    The better crossover components may take a while to settle or “charge up” too but I suspect it’s mainly the drivers needing to smooth out.
    heiney9 Posts: 25,589
    Braddles63 wrote: »
    Once broken in with the right gear these will blow you away and your question will be moot. :D Gorgeous speakers. I love my "standard" L200's and I was skeptical before I bought them (because of all the rave reviews). I think they are fantastic speakers.
  • Braddles63
    Giving them a run in the big room
    treitz3 Posts: 20,208
    Nice setup my man! Love the artwork.
  • Braddles63
    Cheers Tom.
    Yes my wife brought them as they looked like a big set of speakers. 😅
  • GlennDog
    Wish these were on Promo . Me thinks I’m becoming a bookie fan boy .. Buchardt Zebra are ROCKING IT
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    msg Posts: 10,546
    Quit wishing. Start buying.
  • Braddles63
    Bass has tightened up to some extent but I have to place them around 900mm off the wall to get some sort of tonal balance. Top end is quite refined but also veiled unless you really open the power tap. But they look nice. 😅👍
  • Braddles63
    This is a great speaker if you are onto your 60s, 70s and 80s. It is that refined in the top end that it will smooth out all the thin recordings from the era and has the bass to fill in the bottom end that was missing.
    msg Posts: 10,546
    Braddles63 wrote: »
    I think that veiling is going to clean up for you. How many hours do you have on them?
    What's this 900mm stuff? Wait, what's that, like 3 grade school ruler lengths?
    The R200 series speakers were awful to me when I first got them, but that doesn't speak to the AEs. @VR3 do you find the AEs to be any different out of the box?
    I later discovered, like others, that R200s do much better further out in a room. Once broken in and placed out in the room, I found them to be very pleasing, and I supplement a little with a sub.
    But yeah, they were all over the place at first, especially with closer proximity to walls. Bass was overpowering, not very well balanced in general, and seemed a bit cold to me.
    Re: the veiling, the air didn't come until later, and with plenty of room around them. I think it was a combination of break-in/burn-in and placement.
    Try pulling them way out, and get maybe another 450mm to 900mm around them.
    VR3 Posts: 29,631
    The Ae do need some break in.
    I enjoy their sound, great air and depth in the top end.
    Low end is a little less refined than I am used to but very respectable for size and price point.
    The midrange however compared to the grandes and Wilson's is insanely veiled. B this is not a dig on the r200 considering the dramatic price differences but just the reality of the speaker.
    For the price I paid for a brand new set of speakers, I have no real complaints. They perform very well and are built very well.
  • Emlyn
    Emlyn Posts: 4,871
    The true sign of an audiophile is doing speaker setup to the millimeter.
    B)
    Braddles63 wrote: »
    Speakers shouldn't really be adding or subtracting anything. If there little bass in a recording then the bass on a good rog should sound thin. The R200s don't add anything to the signal that I've noticed. Placement can mess with the output a bit.
