POLK Magfi Mini - Turns off when volume is changed
DG_Atlanta
DG_Atlanta Posts: 2
edited November 2022 in Troubleshooting
Hi,
Every-time I change the volume on my magfi mini it turns off. The problem persists whether I connect via bluetooth or via Aux-in, the later is what I mostly use. I do not use Optical Audio or HDMI/ARC or chromecast so not sure if the problem occurs with those inputs too.
I have tried re-setting, using the power/volume button reset procedure I have read on some forum, but nothing helped! I did write an email to customer service, but nothing come off it either.
If you guys have found a solution, please let me know.
Regards
DG
PS: Other posts I have referred too, but none of them have a solve.
https://forum.polkaudio.com/discussion/194902/sound-disconnects-when-we-change-volume-press-pause-for-a-movie
https://forum.polkaudio.com/discussion/195517/magnifi-mini-opt-volume-change-mutes-sound
Answers
