SDA SRS new to me
189111314
  • skipshot12
    skipshot12 Posts: 2,092
    edited November 2022
    VR3…
    What is the manufacturer of that 91uf cap?
    VR3 wrote: »
    Nvm, found a pic.. You can kind of tell what's up in the photo
    VR3 Posts: 29,545
    Solen
  • invalid
    invalid Posts: 1,525
    I think solen is the only manufacturer that makes the 130uf film caps
  • Clarity Cap PX 250V comes in 100 and 30. I've never heard it explained exactly what the reason is for wanting them to be close to or equal when combining two or more caps.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    VR3 Posts: 29,545
    Remember they are actually making 260 and you can use any variation... Like 4 x 65uf etc
    pitdogg2 Posts: 27,290
    Because the lesser cap will act like a bypass cap.
    VR3 wrote: »
    I used multiple Axon caps for the SDA2a I did.
  • invalid
    VR3 wrote: »
    I just used 2 solen 130uf, but that's the only thing I would use solen for.
  • Gardenstater
    Gardenstater Posts: 4,803
    Reliable Capacitors Audiocap PPMF-AC could be a good option for you. They make custom values, or you could parallel a 60uf with a 70uf.
    Oops forgot the link:
    http://www.reliablecapacitors.com/products/audio-cap.html#audio-cap-ppmf-ac
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • skipshot12
    ^ thank you.
    Just ordered my first two caps.
    Two 130uf Solen 400v.
    From reads sounds like solen ok for that application.
    F1nut Posts: 51,985
    Yep
  • skipshot12
    Have a question y’all…
    Is this a bad practice, electrically, to put my two 130uf caps at this position so close to the inductors?
    Trying to make the most room on the pc board that I can for the rest of the large pieces to come.
    Need your input…
    F1nut Posts: 51,985
    Put them in the L under the board.
  • skipshot12
    That was my other thought.
    F1nut Posts: 51,985
    skipshot12 wrote: »
    ^ As in this….
    This, but put the right one on the L.
    VR3 Posts: 29,545
    Remove the inductors, drill holes in the metal mounted then zip tie the caps to those mounts
    txcoastal1 Posts: 13,519
    edited December 2022
    @skipshot12 ....use the attach image instead of attach file...so images are public on thread. If you are using your phone then click the choose file under imnage and it will direct you to choose photos on your phone
    Jesus who's that fugly mucker ...... in that picture?
    :D:D:D My daughter sent me that pic tonight...It was from a few years ago while I was telling a joke
    It's a classic! Love it!
    audioluvr Posts: 5,986
    Boy, @Hermitism is going to have a heyday with that one come next Halloween.
  • skipshot12
    Was ordering resistors and caps and would like opinions please.
    Ok to do this or not recommended….
    All Sonicaps or a mix of Sonicaps & ClarityCaps?
    Those four 20uf Sonicaps are right at $280.
    I can get the 20uf Clarity Caps at a little less than half that.
    Mix, don’t mix?
    Can also get all values in the ClarityCaps except the 4.4uf, would have to do two 2.2’s in parallel.
    Thoughts, opinions & recommendations y’all….
  • skipshot12
    ^ All the resistor values @ Sonicraft as recommended…
    F1nut Posts: 51,985
    Don't mix unless you absolutely have to.
  • skipshot12
    Thanks Jesse.
    That's what I was thinking too.
  • JayCee
    JayCee Posts: 1,509
    +1 to Jesse's advice. Sonicaps in all my SDA's.
    I used to live in the same town as Jeff, owner of Sonic Craft (designer of Sonicaps), and spent a little bit of time w/him when I picked up an order. He's a great resource and knowledgeable as he l l if you get him on the phone. He knows his stuff and worth chatting with.
    Good to see your progress, Skip!
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    True that @JayCee. Jeff gave me a call one night after I inquired about a product he couldn't answer right away. Holy cow Batman we talked for almost 3 hrs. The dude is smart as a whip and funny as ****! It all started with a question about Rhodium 😆
