Let’s see some Tube Glow!
  • invalid
    invalid Posts: 1,560
    Very nice
  • WagnerRC
    WagnerRC Posts: 2,228
  • jbreezy5
    jbreezy5 Posts: 1,141
    A little EL34 Mono showing off
    Can we get a mini-review? Always wanted to hear those.
  • Faustin
    Faustin Posts: 1,151
    Love all the tube glow. But, in some cases,, I don't know what I am drooling over. Some info like manufacturer, tube type etc would be awesome. B)
  • verb
    verb Posts: 10,176
    Peachtree Nova in the Living Room. The blue led at the base of the tube is switchable on/off.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    jbreezy5 wrote: »
    VAS Audio Citation II Monoblocks were purchased directly from Steve @ VAS. He's also the Importer for Cayin, I'm 99% sure that the Citations are built in the same factory that Cayin and Prima Luna are manufactured in, but I can't say for certain.
    50 wpc in Ultra Linear, I'm thinking a little less in Triode. Amazing little amps that are deceiving in their size and weight, the Transformers are hand wound and extremely quiet. Tube Rectified and also 12AU7 and 12AX7 small signal tubes, along with all P-P wired.
    I have them driving the 3.1TL's as they are a favorable load for them and they sound exceptional. With some NOS Svetlana Winged -C- EL34's the transparency is very good, along with that intoxicating EL34 midrange. But what really stands out with these little guys is the Bass. For an EL34 Amp, the Bass is as good, or better than what a pair of Quicksilver Mono 120's (KT-150's) outputs.
    I also hook them up to a pair of CRS+'s occasionally when I'm needing a change up. They will drive the 2.3TL's, but are a little shy on current to really get the best out of the larger pair.
    I've had them for close to four years and that's saying something for me ;) I rolled through 3 different S.S. Amps in the last couple of years and the Citations are still in the mix.
    pitdogg2 Posts: 27,921
    WOW I'm sure those were not cheap! From what I've read those are "holy grail" tubes
  • Mike Reeter
    I actually received a quad of those when I bought a Rogue Audio Cronus Magnum several years ago, the seller included them in the sale. They still test exceptionally good, the Cronus is long gone but the Winged C's are still with me :)
    You can still buy NOS pairs for around 2 bills, much less expensive than some NOS Mullards that have gotten completely out of reach, for me anyway :#
    https://www.ebay.com/itm/203700965733?hash=item2f6d861165:g:T3UAAOSwh0thk-xC
  • verb
    verb Posts: 10,176
    Antique Sound Labs monoblocks in the office rig (forgive the dust). No tubes visible on the EAR 834L preamp but nice reflection from my lighted keyboard!
  • DividedSky
    verb wrote: »
    Verb your equipment list and multi-room approach is giving me bad ideas! :#
    Primary: Doshi V3.0 pre and phonostage, Vandersteen M5-HPA, Vandersteen Quatro CT, AMG viella, Goldfinger Statement, AQ Niagara 5000, AQ IC and power cords, Mapleshade Samson V.5
    Secondary: Nakamichi PA7, Nak CA5, Polk LS90, Sota Sapphire, Sumiko MDC800, Van den hul Crimson
  • TEAforONE
    TEAforONE Posts: 1,102
    I swapped in a Winged C 5u4g in the Motherlode II.
  • invalid
    You should get this to plug into your motherlode's rectifier socket.
  • verb
    verb Posts: 10,176
    DividedSky wrote: »
    verb wrote: »
    Lol yeah, all gotten with a lot of encouragement from our fellow Polkies!
  • jbreezy5
    TEAforONE wrote: »
    You gotta keep the bedroom talk off the forum! 😂
  • TEAforONE
    invalid wrote: »
    I’m looking on my phone,can’t make it out.
  • invalid
    edited December 2021
    It plugs into your rectifier socket and replaces your 5u4g, it has its own power supply you can run 2.5 volt 5 volt and 10 volt tubes. I have the scaled down version that can only take 2.5 volt and 5 volt tubes up to a 6 amp heater current.
  • WagnerRC
    More glow
  • verb
    verb Posts: 10,176
    Verb’s basement rig!
  • TEAforONE
    invalid wrote: »
    That is Kool and The Gang! Now the gears are turning…. Tell me about the sound improvements.
  • oldrocker
    oldrocker Posts: 2,590
    And now, the frontrunner in the "cheapest/wannabe" category of tube amp :D
  • oldrocker
    At least there's something decent downstream.
    NOT the new R200's as u know who done took them to her house :'(
    mhardy6647 Posts: 35,562
    oldrocker wrote: »
    Careful! You'll give Bob Carver Frank Malitz ideas! :#B)
    Meanwhile, on Yuletide E'en Morning, in grey northern New England, the mournfully joyous strains of Jillian Ladage's utterly unique interpretation of The Holly and the Ivy echo through the hall via the big boy hifi. Gorgeously. :)
    https://youtu.be/5IYYyG0qEjg
    EDIT: Looks like one of my ol' General Who-Lectric 6SL7s is a bit ill-suited ill-seated. Need to fix that; but not on the fly :#
  • oldrocker
    Yipper Doc, you might be correct... :D
    I did align the 6SL7 later on today. :)
    I mean... after all... @clipdat wouldn've been able to sleep tonight if I hadn't ;)
    I actually woulda reseated it "live". The 6SL7s are just warm to the touch, of course --- but it prolly woulda generated a bit of a pop, and the replacement value of the pair of (currently borrowed) Altec 515B woofers in the Frankenaltecs is high enough that I'd be googlin' "sell my kidney" if it was a wee bit too much of a pop. :#
    49625004197_e5d5b5c346_b.jpgDSC_8292 (2) by Mark Hardy, on Flickr
  • invalid
    New 866 mv rectifier tube, the tube in the back position.
  • gidrah
    gidrah Posts: 3,050
    Make it Funky! :)
    SCompRacer Posts: 9,408
    edited October 2022
    From some tube gear in my journey.
    edited October 2022
    I was listenin' to some just a few minutes ago. B)
  • Joey_V
    Joey_V Posts: 8,606
    Toolfan66 wrote: »
    verb wrote: »
    WagnerRC wrote: »
    More glow
    I believe all 3 of those are Cary 05…. I might be wrong with verb. But that’s pretty crazy how many have this end game preamp.
  • Joey_V
    Joey_V Posts: 8,606
    Here’s my tube glow for the night.
    As you can tell by the time, I’ve been listening for 5 hours.
