Isolation cups for an adult beverage... Aka coasters 👀- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I believe only Barry or George can explain. 😁Don't take experimental gene therapies from known eugenicists.
This post could happily reside in my other thread, but many other updates coming in there soon!
Finally got the L200s installed in the garage! 1.5" maple butcher block, and 2 x 8's behind the drywall in between the studs for secure mounting of the brackets.
Detail of in-wall speaker cable trim. I ran analysis plus silver oval 2's.
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Did some re-arranging in the basement and made a nice little niche at the far end for my secondary rig.
1C's running now, but can easily swap out for others!
Also currently hooked up is the VTL pre and CJ amp, clean power from a Shunyata conditioner, and Marantz CDP.
Have not re-arranged the wall art yet !!!
Where are the L800's?
All this to make room for the big rig.
Finally setup everything on the solidsteel double rack!
Spikes added just so @Clipdat would not give me any more grief !
Full disclosure, Micro Seiki TT and Project Tube Box are not hooked up yet!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
L800's located kinda where the 1.2TL's were (subject to fiddling around a bit), and the MC300's running as monoblocks!
Detail showing Pangea AC9's coming from a dedicated 20amp circuit to the MC300, with MIT Shotgun XLR IC's and MIT Shotgun Speaker cables. Mirror that to the other speaker.
View from across the basement. This really opens up the room when guest are over, but also allows me to place a nice comfy chair in the sweet spot when doing critical listening.
Still wip, but I try to get down to the basement as much as I can, despite all the other projects going on, and work, to enjoy my newly configured big rig!
Dave, looks like you have been busier'n a whorehouse on nickle night. Fantastic bro'!
Look'n good, bro!
Make time to cruise Woodward before Saturday
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Look'n good, bro!
For sure Dog! I'm on vacation starting this evening through Friday! If you get a chance, Berkley classic car parade is Friday! The 59 will be in it!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Thanks Tom! So much to do, keeping me super busy! But having fun in the process, tinkering around in the new garage, and playing with the rigs!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Thanks bro! Gotta love Drew! But yeah he ribbed me on the spikes for sure! All good fun!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
The design goal of under 1.00" full sandwich height was achieved as well as 3" rad. and 2.5" OD will handle even the heaviest SDAs...
Few more to go for a full set of 12....
Post edited by xschop onDon't take experimental gene therapies from known eugenicists. -
Did you hold them in a sacrificial soft jawed chuck which you bored to the same O.D. as the blanks? How did you do the outer diameters of the blanks? Looking good!George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Thanks Gstater. I made 1-off hard jaws to re-use, that's why the small groove is on the OD. Will help when picking them up and placing.
I have 60mm Round Double-Sided 3M pads that I'll use to mount the pucks to the bottom of the speakers.
Wonder what Barry would say...
Barry would say those are some bad.azz. hip joints!George / NJ
iFi nano iDSD DAC
iPurifier3
Look'n good, bro!
Heading out tomorrow and Friday is the Cruise Fest parade in Berkeley! When are you going?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I cut down the jaws a little shorter and programmed the bit to get closer and remove the groove....
Bitching- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I have some 60mm pads left over from another footer project and will try these first. They look to be 0.075" thick and still won't raise the cabinets a full inch when installed...
They’re reproducing!CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Yeah, I had to go scrounging around the shop for another piece of round to make the last two I needed for a 2nd set.Don't take experimental gene therapies from known eugenicists.
Finally got this turntable setup up-and-running. It is a Denon DP-3000 turntable motor, on a DK-110 plinth. Tonearm is a Micro Seiki MA-505L.
I've had the MA-505L arm awhile, but struggled to find an adequate base/plinth to accommodate it, since it is a 12" arm. The arm did technically fit on my Technics SH-15B2 plinth, with an SP-25 motor unit, but it would rub the inside of the dustcover when closed...not ideal.
I bought this Denon motor/plinth from a Japanese Yahoo auction, and used a Japanese-based third party outfit to handle shipping/handling. The process actually went very smoothly.
Anyway, I did have to drill a new 270mm pivot-to-spindle hole in the armboard. In this pic, you can see here the original tonearm hole, which I suppose(?) I need to cover. FWIW, I used a Forstner bit to drill my new hole...it is much cleaner
As mentioned, I purchased this tt unit from Japan, so I also had to obtain a 120>100VAC converter in order to properly power the tt. I bought this 'umi' brand unit off Amazon.
In the end, I am quite happy with this setup
This Denon direct-drive motor works flawlessly, although I did have to replace the 33 speed indicator lamp/bulb. The motor is (only) servo-controlled (vs quartz), but my unit holds perfect speed, so no complaints. "This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Very nice!
Very nice. I am and always have been a friend of Denon tables. Mr Spock. P.S. I mean the platters and plinths, not the Denon arms which are usually the weak link. Getting just the motor unit and plinth like you did and mounting a separate arm is the way to go.
Thanks, guys! I do wish the platter itself had a little more heft to it. It weighs just under 2.5lbs. I may look into adding some Dynamat onto the underside. The run-out time for the spindle bearing is really good."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Very nice! Love the look of those Denon tables.
