1142143145147148200
    VR3 Posts: 29,427
    Isolation cups for an adult beverage... Aka coasters 👀
    xschop Posts: 5,164
    I believe only Barry or George can explain. 😁
  • verb
    verb Posts: 10,176
    This post could happily reside in my other thread, but many other updates coming in there soon!
    Finally got the L200s installed in the garage! 1.5" maple butcher block, and 2 x 8's behind the drywall in between the studs for secure mounting of the brackets.
    Detail of in-wall speaker cable trim. I ran analysis plus silver oval 2's.
  • verb
    verb Posts: 10,176
    Did some re-arranging in the basement and made a nice little niche at the far end for my secondary rig.
    1C's running now, but can easily swap out for others!
    Also currently hooked up is the VTL pre and CJ amp, clean power from a Shunyata conditioner, and Marantz CDP.
    Have not re-arranged the wall art yet !!!
    nooshinjohn Posts: 25,918
    Where are the L800's?
  • verb
    verb Posts: 10,176
    All this to make room for the big rig.
    Finally setup everything on the solidsteel double rack!
    Spikes added just so @Clipdat would not give me any more grief !
    Full disclosure, Micro Seiki TT and Project Tube Box are not hooked up yet!
  • verb
    verb Posts: 10,176
    edited August 2022
    L800's located kinda where the 1.2TL's were (subject to fiddling around a bit), and the MC300's running as monoblocks!
    Detail showing Pangea AC9's coming from a dedicated 20amp circuit to the MC300, with MIT Shotgun XLR IC's and MIT Shotgun Speaker cables. Mirror that to the other speaker.
    View from across the basement. This really opens up the room when guest are over, but also allows me to place a nice comfy chair in the sweet spot when doing critical listening.
    Still wip, but I try to get down to the basement as much as I can, despite all the other projects going on, and work, to enjoy my newly configured big rig!
    treitz3 Posts: 19,991
    Dave, looks like you have been busier'n a whorehouse on nickle night. Fantastic bro'!
    audioluvr Posts: 5,915
    edited August 2022
    verb wrote: »
    @Clipdat is a hack! :D
    Good to hear you are doing well brother!
  • GlennDog
    GlennDog Posts: 3,152
    Look'n good, bro!
    Make time to cruise Woodward before Saturday
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • verb
    verb Posts: 10,176
    GlennDog wrote: »
    Look'n good, bro!
    For sure Dog! I'm on vacation starting this evening through Friday! If you get a chance, Berkley classic car parade is Friday! The 59 will be in it!
  • verb
    verb Posts: 10,176
    treitz3 wrote: »
    Thanks Tom! So much to do, keeping me super busy! But having fun in the process, tinkering around in the new garage, and playing with the rigs!
  • verb
    verb Posts: 10,176
    audioluvr wrote: »
    verb wrote: »
    Thanks bro! Gotta love Drew! But yeah he ribbed me on the spikes for sure! All good fun!
    xschop Posts: 5,164
    edited August 2022
    The design goal of under 1.00" full sandwich height was achieved as well as 3" rad. and 2.5" OD will handle even the heaviest SDAs...
    Few more to go for a full set of 12....
    Post edited by xschop on
  • Gardenstater
    Gardenstater Posts: 4,780
    Did you hold them in a sacrificial soft jawed chuck which you bored to the same O.D. as the blanks? How did you do the outer diameters of the blanks? Looking good!
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,164
    edited August 2022
    Thanks Gstater. I made 1-off hard jaws to re-use, that's why the small groove is on the OD. Will help when picking them up and placing. :)
    I have 60mm Round Double-Sided 3M pads that I'll use to mount the pucks to the bottom of the speakers.
    Wonder what Barry would say...
  • Gardenstater
    edited August 2022
    Barry would say those are some bad.azz. hip joints!
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • verb
    verb Posts: 10,176
    GlennDog wrote: »
    Look'n good, bro!
    Heading out tomorrow and Friday is the Cruise Fest parade in Berkeley! When are you going?
    xschop Posts: 5,164
    I cut down the jaws a little shorter and programmed the bit to get closer and remove the groove....
    VR3 Posts: 29,427
    Bitching
    xschop Posts: 5,164
    I have some 60mm pads left over from another footer project and will try these first. They look to be 0.075" thick and still won't raise the cabinets a full inch when installed...
    xschop Posts: 5,164
  • jbreezy5
    jbreezy5 Posts: 1,141
    They’re reproducing!
    xschop Posts: 5,164
    Yeah, I had to go scrounging around the shop for another piece of round to make the last two I needed for a 2nd set.
  • dromunds
    dromunds Posts: 10,125
    edited August 2022
    Very nice. I am and always have been a friend of Denon tables. Mr Spock. P.S. I mean the platters and plinths, not the Denon arms which are usually the weak link. Getting just the motor unit and plinth like you did and mounting a separate arm is the way to go.
  • jdjohn
    jdjohn Posts: 3,354
    Thanks, guys! I do wish the platter itself had a little more heft to it. It weighs just under 2.5lbs. I may look into adding some Dynamat onto the underside. The run-out time for the spindle bearing is really good.
  • DaveHo
    DaveHo Posts: 3,583
    Very nice! Love the look of those Denon tables.
